  4. chit chat thread
chit chat thread
7.1k Posts 73 Posters 72.6k Views 4 Watching
    DO NOT GO THROUGH ROTIFORM FOR ANYTHING!!! People have been having nothing but issues with cracking lips and barrels the past month or so.
      Bad batch of metal, Rotiform is honoring free replacements..
      • JeffJ
        JeffJ
        Jeff
        It would be nice to find a set not bent like what is on the car or at least 3 of them. But don't see any and don't want to spend $175 each rim. Found some for $250 but they are 20mm offset so that will be a problem I believe I need 40-50mm offset or something.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          What kind of rims are you looking for? Also, what is the current rim size/offset on you car? Earl and I are pretty much the wheel guru's on this forum I think
          • JeffJ
            JeffJ
            Jeff
            Rims that are aluminum have to be 17" and cheap. I believe they are 40 or 47 mm offset. there for e46 330xi. If they fit and are 17" that works for me. Can't be smaller the caliper is really close to the rim with 17's and I have new tires on garbage rims so I want to stick with the same size rim.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              Too bad.. Cause I have a set of rims and tires that' i'd let go for cheap. Came off TJ's E46 touring. 16x7 +47 offset. I almost guarantee they'd fit your car.
              one has a slow leak( not bad at all) LMK if you might be interested, I know they're not what you're looking for. But hey, they'd atleast let you drive the car around.
              • JeffJ
                JeffJ
                Jeff
                Wish they where 17". I know 16's won't fit just because the tip of my finger barely fits between caliper and rim
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  It all depends on the width of the wheel. You can fit a 17x8 et0 if you want. E46s have insane amounts of room in the fenders.
                  • JeffJ
                    JeffJ
                    Jeff
                    So you think the 17's I found with the 20mm offset will fit?
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      Yes. What is the width? I know style 5's fit and are super sunk still. They're 17x8 et20
                      • JeffJ
                        JeffJ
                        Jeff
                        They are 7.5" wide
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                        • JeffJ
                          JeffJ
                          Jeff
                          Well called the guy he sold them an hour ago
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            Those will definitely fit! An I know my rims would fit your car, they're only z 1/2" smaller all around. :3. I mean, they came off an E46!
                            But yeah, those will fit, no worries!
                            • JeffJ
                              JeffJ
                              Jeff
                              Wish I brought them up before the guy sold them
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                Jeff is correct, e46 330's require 17" wheels. The stock 330 brakes are slightly larger than that of an e36 M3. Not to mention, 16's look silly on an e46 :P
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  So will 17" 7.5 wide and 32 mm offset fit need to know ASAP
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    Yes. lol
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      Sweet thanks
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        In Milwakee woo
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          Yay! Milwaukeeeeee I wanna move there.
