  4. Build thread/running log of my E28? Guess I can do eet.
553 Posts 22 Posters 7.0k Views 2 Watching
    That      is      fucking     BAUS!!!
      yeah, I'm excited. I gotta go out sometime, mount up these wheels and fully deflate the tires, to make sure when they blow, that I won't be dragging my frame/gas tank/ etc
        I do what I can  :wub:
          ^Gunna marry that boy some day.
            Be a pitcher, a good one.  He will give you an award.
              Haaaaa. And also, I'm stoked for this burnout.
                Disconnect your rear brakes or something haha
                  Disconnect them? For what reason?
                    Poor mans line lock.
                    • JeffJ
                      JeffJ
                      Jeff
                      i see alot has gone on since i was here last love the ?open/lsd? how where you still driving if it was that bad?
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Explain?
                          If the brake pedal only controls the front brakes, you can hold down the brakes and roast the rears.  Otherwise to do a burnout you have to overcome the power of the rear brakes.
                            I'm saying what is "poor mans line lock"
                              I just explained what a line lock is.  Disconnecting the rear brakes is a way to do it (if done correctly) that is free but gets the basic same results as a line lock.
                                http://greenbay.craigslist.org/pts/3617305613.html
                                Get this haha
                                  Yeah man, alot's happened.
                                  The reason the LSD was deemed an "open diff" was because it's a clutch style LSD, the friction plates, aka "clutch" were so worn, that with the car in the air, spin one rear wheel, the other would spin the other way. yet when I would get stuck on ice, both tires would spin, I just deemed it a fucked up open diff. Till we dropped it.
                                  And also guys, disconnecting rear brakes is pointless, as the brake bias is usually 65% front, 35% rear. Even then, why would I disconnect them? I could just close the lines at the brake T's
                                    So, these are the gears I broke on the LSD.
                                    Clearly not a KAAZ LSD. Those are $1400 starting.
                                    Better picture:
                                      Is that Ethel in your sig?
                                        Yes it is. Ethel is a gorgeous fickle beast. That and I talk to A.Stirrett daily, and couldn't help myself.
                                          BMW RUNS AND DRIVES. #yay
