  4. chit chat thread
chit chat thread
7.1k Posts 73 Posters 72.6k Views 4 Watching
    Jeff said:
    How did you get IPhoto to do that I doesent on my MacBook do I have to change a setting?
    I'm running the latest version of iPhoto but this has been a feature for a while now. Just go to File > Export and the first pane is what you want to use for file export.
    post-2724-0-35143400-1362971331thumb.pn
    Jeff said:
    Get to drive all the way to madison tomarrow:/
    I'm going to get very lost
    Madison isn't to bad for getting around unless your going downtown. Thats when things get confusing !
    • JeffJ
      JeffJ
      Jeff
      Thanks for the info I didn't even relize you could do that in iPhoto
      I have to go to a building right by the Capitol. Have to get there by 10:00am ill be there for less than 30mins so all the driving for barely anything.
      125s Webster street never been that far into madison ever so ill probly get lost.
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • JeffJ
        JeffJ
        Jeff
        This drive is sucking. Well the crooked steering at least. Was supposed to get my car realigned before my trip to madison. Go there and the guy says he can't do it today.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          I know how you feel. My car and the truck are a little lose in the steering.
          • JeffJ
            JeffJ
            Jeff
            Steering parts shouldn't be aloud to wear out.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • need4speed1299N
              need4speed1299N
              need4speed1299
              Brake lines shouldn't rust out. Why not just use aluminum? Darn cars!
              • JeffJ
                JeffJ
                Jeff
                Very true but then there is corrosion:( there has to be a solution to everything we just haven't found it yet
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  To reduce wear in metal, you increase hardness. When you increase hardness you increase brittleness. As long as we are limited by materials, we will have to choose our compromise.  IC engines would be far more efficient than they are now if a cooling system was not required to remove heat from the engine. A material that could withstand the heat of combustion without failing could be used to produce regular low rpm (<6500rpm) 2.0 I4 engines which could possibly produce 400hp in NA form.
                    • JeffJ
                      JeffJ
                      Jeff
                      im going to have a nightmare now
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        snap oversteer said:
                        You just got me kicked out of class. DICK. Anyways, that was god damn hilarious.
                          It happens
                            I think Hoppe got kicked out from surfing in class too once. We should start a tally board!
                              Who is Hoppe?  I didn't realize we had Kangaroos on this board,
                                Lol Ben (GunMetalGray)
                                  Lol, KIDS
                                    Anyone wanna see some gnarly car carnage? Check out my Facebook pictures. "Mitch monopoly Rowley" don't judge on the monopoly.
                                      This is disturbin'
                                      One time on the freeway I was thinking to myself that the ideal scenario in a sudden-stop on the freeway would be to be behind a semi and in front of a sports car with an attentive driver (that way you dont rear-end or get rear-ended :P ). I was behind a semi and noted that a kia was behind me (not a sports car).  not 30 seconds later the freeway traffic came to a sudden stop. I had full faith in my E30s stopping ability but not in the reaction time or performance of the Kia behind me, so as soon as I saw the semi lock the trailer brakes, emitting smoke and chunks of rubber, I moved right onto the right shoulder to hit the brakes. The Kia slid in to the position I was just in and I would have been rear-ended and possibly submarined under the semi trailer.
                                      I generally try to avoid following semis in heavy traffic if I dont have to. The geometric mis-match can turn a minor fender-bender into something awful.
                                        ^I always head for the shoulder, its something almost no one on the road does, and if they do, they don't head for the shoulder, they ditch dive. I always fear, with how low my car is, I'll go under a car. or a car rear ending me will hit and go into the cabin of the car. That and I hate car accidents. I've been in alot of brutal brutal car accidents as a passenger.
                                        The semi thing though, fuck would that suck. I never follow behind semi's
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          Why is everyone so stingy with moving on rim prices. They say shoot me an offer and say that the price shown is bottom dollar
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
