  4. chit chat thread
chit chat thread
7.1k Posts 73 Posters 72.6k Views 4 Watching
  • JeffJ
    JeffJ
    Jeff
    Get to drive all the way to madison tomarrow:/
    I'm going to get very lost
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      Jeff said:
      How did you get IPhoto to do that I doesent on my MacBook do I have to change a setting?
      I'm running the latest version of iPhoto but this has been a feature for a while now. Just go to File > Export and the first pane is what you want to use for file export.
      post-2724-0-35143400-1362971331thumb.pn
      Madison isn't to bad for getting around unless your going downtown. Thats when things get confusing !
      • JeffJ
        JeffJ
        Jeff
        Thanks for the info I didn't even relize you could do that in iPhoto
        I have to go to a building right by the Capitol. Have to get there by 10:00am ill be there for less than 30mins so all the driving for barely anything.
        125s Webster street never been that far into madison ever so ill probly get lost.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • JeffJ
          JeffJ
          Jeff
          This drive is sucking. Well the crooked steering at least. Was supposed to get my car realigned before my trip to madison. Go there and the guy says he can't do it today.
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            I know how you feel. My car and the truck are a little lose in the steering.
            • JeffJ
              JeffJ
              Jeff
              Steering parts shouldn't be aloud to wear out.
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
              • need4speed1299N
                need4speed1299N
                need4speed1299
                Brake lines shouldn't rust out. Why not just use aluminum? Darn cars!
                • JeffJ
                  JeffJ
                  Jeff
                  Very true but then there is corrosion:( there has to be a solution to everything we just haven't found it yet
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    To reduce wear in metal, you increase hardness. When you increase hardness you increase brittleness. As long as we are limited by materials, we will have to choose our compromise.  IC engines would be far more efficient than they are now if a cooling system was not required to remove heat from the engine. A material that could withstand the heat of combustion without failing could be used to produce regular low rpm (<6500rpm) 2.0 I4 engines which could possibly produce 400hp in NA form.
                      • JeffJ
                        JeffJ
                        Jeff
                        im going to have a nightmare now
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          snap oversteer said:
                          You just got me kicked out of class. DICK. Anyways, that was god damn hilarious.
                            It happens
                              I think Hoppe got kicked out from surfing in class too once. We should start a tally board!
                                Who is Hoppe?  I didn't realize we had Kangaroos on this board,
                                  Lol Ben (GunMetalGray)
                                    Lol, KIDS
                                      Anyone wanna see some gnarly car carnage? Check out my Facebook pictures. "Mitch monopoly Rowley" don't judge on the monopoly.
                                        This is disturbin'
                                        One time on the freeway I was thinking to myself that the ideal scenario in a sudden-stop on the freeway would be to be behind a semi and in front of a sports car with an attentive driver (that way you dont rear-end or get rear-ended :P ). I was behind a semi and noted that a kia was behind me (not a sports car).  not 30 seconds later the freeway traffic came to a sudden stop. I had full faith in my E30s stopping ability but not in the reaction time or performance of the Kia behind me, so as soon as I saw the semi lock the trailer brakes, emitting smoke and chunks of rubber, I moved right onto the right shoulder to hit the brakes. The Kia slid in to the position I was just in and I would have been rear-ended and possibly submarined under the semi trailer.
                                        I generally try to avoid following semis in heavy traffic if I dont have to. The geometric mis-match can turn a minor fender-bender into something awful.
                                          ^I always head for the shoulder, its something almost no one on the road does, and if they do, they don't head for the shoulder, they ditch dive. I always fear, with how low my car is, I'll go under a car. or a car rear ending me will hit and go into the cabin of the car. That and I hate car accidents. I've been in alot of brutal brutal car accidents as a passenger.
                                          The semi thing though, fuck would that suck. I never follow behind semi's
