1.8k Posts 58 Posters 0 Views 1 Watching
    Got the drivetrain out today;) The only thing that gave me issues was the damn bitch clip for the shifter. I started shaving the bay as well.
    Ryan's GF Kayla and I know all too well about that bitch clip. It's Honestly not that bad, as long as you have a new one, you can destroy the old one.
      The bitch clip in my e36 parts car was actually a hell clip.
      The straight part that should have slid out had actually mushroomed so it couldn't come out at all. The die grinder came out and took care of that situation
        Here is how I hooked up the hoist:
        Posted Image
        It sucked trying to get the trans up enough to pull out. I had to be almost vertical. I also had to remove the brace before the frame rails.
        Posted Image
        Posted Image
        I also used my spot weld bit to drill off all the brackets. The battery tray will come out when I remove the seam sealer.
        Posted Image
        Posted Image
        The lighting was horrible in the shop, but I didn't care about fancy pictures at the time=) I'll need to get a nice camera instead of using my phone.
        More shaving and miscellaneous other things to come on Saturday.
          wow, thats going to be quite a project! Should be plenty worth it when its done though. When I cleaned and re-painted my engine bay I didnt want to take all the brake lines and ABS pump out, but I am so glad now that I did. Are you going to stick with the M42 for the long run?
            Right now it is staying. My money is going towards paint, suspension, and building the next wheels. The m42 isn't as horrible as people make it out to be;)
              Just ordered my Silver Project 74sha subframe, trailing arm, and diff bushings. $151 shipped from Europe. Sounds great to me.
                Score!
                  Is the subframe out yet? I encountered a few obstacles with the subframe and bushing removal that I worked through so just let me know if you need any tips or tricks with those items.
                    Burn out the bushings? Seems to be the easiest way to do any sort of bushing removal..
                      Burn out the rear bushings, I thought I would try to be smart and push them out and that was the worst mistake I ever made.
                      Torch em, let em burn then whack them with a good ol flat head and hammer!
                        Applying a torch flame at the center sleeve of the RTAB for a minute or two will allow the rubber around the sleeve to melt to the point where you can push the sleeve out with a screwdriver. Then its just a matter of pulling the rubber portion out with pliers. Takes < 2-3 minutes per bushing and causes for less cleanup and less risk of changing the heat-treating of the metal.
                        So yes, burning them out, but there are subtle details like I mentioned above which make it a bit quicker cleaner and easier on the metal. +
                          Hell yeah. Just don't let your car catch on fire.
                            I figured the subframe was out of the car ;)
                              Ask Chris how pulling the rear subframe outta the parts car E28 went. Even with the diesel truck we couldn't get that bitch out. So I think it's safe to say, mine might get burned out, while on the car.
                                Are the subframes on e28's set up like e30's?
                                I am almost scared to ask, but how did you use his truck to help?
                                  not a fucking clue. I'd assume their relatively the same.
                                  We uh. undid all the bolts, hooked up a tow rope to it, and uh. Diesel power took over. Still didn't budge.
                                    Well if its anything like an e30 you can't pull it back, it has to drop down first.
                                    I always use a 7/8" lag and a 5lb sledge!
                                      Car was on it's side.. Obviously it's gotta get pulled towards the bottom of the car. Lol.
                                        Well you can't laugh at me for not assuming the car was sideways lol.
                                          Hahahaha! ^^ right?
