    Rowleym said:
    Those 15x8's look great! I need a skid plate for sure..
    Naw.
    • StewCrewS
      StewCrewS
      StewCrew
      Yeah I liked them, but eventually got bored and they were too small for my taste. I love how the staggered 17s look and glad I stepped up in wheel size.
      • StewCrewS
        StewCrewS
        StewCrew
        Snap Understeer said:
        My springs are 315 lb/in front 570 lb/in rear. The rear springs are stiffer because of the leverage involved in the trailing arm rear suspension design. If you go to a coilover design that relocates the spring onto the damper, then you need to reduce the rear spring rate to achieve the same balance (without doing the calculations I would estimate that I would need to go down to a 380-410 lb/in rear spring for example)
        A 240sx for example, typically has equal or stiffer front springs than the rear (if my memory serves me properly this morning) due to it having a multi-link rear suspension where there is little to no leverage in the suspension links that would require stiffer springs than normal.
        The ways of the e30 explained. This is good info! Thanks :)
          I might step it up to a 16, but I feel like keeping them smaller would be lots cheaper for tires, and when you drift, you definitely use tires.
          • StewCrewS
            StewCrewS
            StewCrew
            Right. Which is why I have 12 spares right now. Can never have too many spares :)
              Just an FYI, if you're going to drift, go to a junkyard like gibsons in neenah, buy their shitty used tires, for $10 a pop. or buy new starfires. Those will last you plenty of drift days. Starfires last for eva
              • StewCrewS
                StewCrewS
                StewCrew
                ^ this. Junkyards are the best for spares
                  I think 16" tires are cheaper than 15"...
                    Really? I feel like 15 inch is more common right? Wouldn't I find more 15" tires off like Hondas as a junk yard?
                      It's a toss up. 16" tires NEW are cheaper, in like a 195/55/16, but if you want cheap an shitty, to destroy on drift days/back road fun, go 15's.
                        Yea that's what I'm thinking. What do I get like 60 thick or 55 or something?
                          For drifting? well, wait till you get your rims. Because that'll really depend on what you want, especially if you're gunna go low, you're gunna have to stretch your tires, due to cambering in.
                          • StewCrewS
                            StewCrewS
                            StewCrew
                            What wheels are you thinking of going with anyway?
                              I'm thinking any cheap light 15x8 et 0 rims. Definitely stretching the shit out of them. Most civics are like 6.5 rims, so I'll be using like a 195 or 185 or something. I can't figure out what rims I want yet. Suggestions?
                                et0? You can't just throw out offsets. from what I recall E30's have a factory high offset, so you're going to mexipoke like a mexicano.
                                  XXR and ESM seem to be the best style+fitment per dollar wheels you can get new.
                                  I still need to sit down sometime and figure out the best size of wheel + tire that allows for best tire availability and cost/performance ratio for track tires. I will probably do something close to 16x8 or 17x8 with summer tires for daily use. Either way, the wheels need to be light and strong. The Kosei K1 and TRM C1 wheels seem to be budget lightweight track wheel if light weight is important to you.
                                    Like this? Posted Image
                                      US factory offset E30's came with lowest offset of +30. averaging +33/40 offset. So +0 offset will be a stretch. but go for it. Hell, I can't really talk, I'm looking for 16/17x10 +5 offset wheels...
                                        Stretch indeed! I would love to fit some 16x10's or something close to that, but I don't think I need that kind of grip for drifting yet.. Wheels are definitely reasonable now a days.
                                          wheels aren' reasonable. Maybe for you 4x100 guys. 5x120 is atrocious.
