550 Posts 16 Posters 0 Views 1 Watching
    Jake, what tire and rim setup are you using by the way? I'm thinking about doing a 15x8. I can have some decent grip and also a bit more tire to keep it cheaper. Also, are you okay with all this thread derailing? Haha
      Brian said:
      10K front, 12k rear? Should be the otherway around. higher spring rates in the front, lower rear. Unless stuff is Different in Subaru WRX STi's. But I doubt that.
      Rowleym said:
      I've been doing a ton of research on this for e30's and for some reasons all of them have lower spring rates in the front. Do not know why.
      My springs are 315 lb/in front 570 lb/in rear. The rear springs are stiffer because of the leverage involved in the trailing arm rear suspension design. If you go to a coilover design that relocates the spring onto the damper, then you need to reduce the rear spring rate to achieve the same balance (without doing the calculations I would estimate that I would need to go down to a 380-410 lb/in rear spring for example)
      A 240sx for example, typically has equal or stiffer front springs than the rear (if my memory serves me properly this morning) due to it having a multi-link rear suspension where there is little to no leverage in the suspension links that would require stiffer springs than normal.
        No such thing on Wibimmers.
        • StewCrewS
          StewCrewS
          StewCrew
          Idunno subaru motors work sideways so who knows. The BC's come stiffer in the rear, and for the most part I thought most coilovers come stiffer in the rear? But I wanted the car to feel super tight so I got higher rates, and it definitely does.
          Brian said:
          If this thing isn't on the fucking GROUND when I see it. I'll be dissapointed in you Jake.
          If these "m50 into e30 chasis" mounts let the motor sit ever so slightly higher, then yes, shit will be dropped. If they dont, shit will also be dropped.
            Idk man, S13 coils are the same way, stiffer front slightly lesss stiff in the rear. I'd assume due to fat ass engines. But hey, potato.
            Dropped or dropped. I like it. Me too. I bottom out everywhere (my oil pan and new bumper) So I'm right along with you babe!
            • StewCrewS
              StewCrewS
              StewCrew
              Thread derailing? Not giving a fuck man :) Im hopefully helpin you out with your future setup so its all good.
              The sportmaxx in the pic I just uploaded were 15x8 on a 195/45 tire I believe? The car was scrapping everywhere. It was great. But I sold those and now have these:
              Posted Image
              Posted Image
              These are 17x7 with 20mm spacer up front (205/45) and 17x9 with 5mm spacers in back (215/45). Goodyear Eagle GT's all around. These are for cruising/meets/not drift day.
              I just run all spares for drift days.
              Posted Image
              \m/
                Those 15x8's look great! I need a skid plate for sure..
                  Naw.
                  • StewCrewS
                    StewCrewS
                    StewCrew
                    Yeah I liked them, but eventually got bored and they were too small for my taste. I love how the staggered 17s look and glad I stepped up in wheel size.
                    • StewCrewS
                      StewCrewS
                      StewCrew
                      The ways of the e30 explained. This is good info! Thanks :)
                        I might step it up to a 16, but I feel like keeping them smaller would be lots cheaper for tires, and when you drift, you definitely use tires.
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          Right. Which is why I have 12 spares right now. Can never have too many spares :)
                            Just an FYI, if you're going to drift, go to a junkyard like gibsons in neenah, buy their shitty used tires, for $10 a pop. or buy new starfires. Those will last you plenty of drift days. Starfires last for eva
                            • StewCrewS
                              StewCrewS
                              StewCrew
                              ^ this. Junkyards are the best for spares
                                I think 16" tires are cheaper than 15"...
                                  Really? I feel like 15 inch is more common right? Wouldn't I find more 15" tires off like Hondas as a junk yard?
                                    It's a toss up. 16" tires NEW are cheaper, in like a 195/55/16, but if you want cheap an shitty, to destroy on drift days/back road fun, go 15's.
                                      Yea that's what I'm thinking. What do I get like 60 thick or 55 or something?
                                        For drifting? well, wait till you get your rims. Because that'll really depend on what you want, especially if you're gunna go low, you're gunna have to stretch your tires, due to cambering in.
                                        • StewCrewS
                                          StewCrewS
                                          StewCrew
                                          What wheels are you thinking of going with anyway?
