  • need4speed1299N
    need4speed1299N
    need4speed1299
    If you disassemble and reassemble your head, you can save money. Label and keep everything in order.
    • StewCrewS
      StewCrewS
      StewCrew
      Some more progress \m/
      Posted Image
      Started to clean to lower timing cover too.
      Posted Image
      Taking a break for now. Making hip up a parts store and get some gaskets ordered for it to go back together :D
      • StewCrewS
        StewCrewS
        StewCrew
        List of things ordered:
        Water pump
        Valve cover gasket
        Cam position sensor
        Crank position sensor
        Thermostat and thermostat housing
        Vanos gasket
        Left and right lower timing cover gasket
        Things I still need to order are a MLS headgasket and a 1-piece timing chain tensioner. But I got a majority of the things checked off of my list :) Im sure theres more things I notice while it is going back together, but thats okay. Im glad I got a good chunk of it ordered.
          This thing's coming along nicely Jacob! :) keep up the work!
            Between all the M50 and turbo related stuff on here I cant keep things straight. Are you eventually going turbo?
              Yes he is :D
                Do yourself a favor and replace the knock sensors while you have everything apart. They're often cracked and are not fun to get to.
                  Rowleym said:
                  Yes he is :D
                  Not from what I've been told. Staying N/a for now, so he can beat the ever living piss out of that motor.
                  • StewCrewS
                    StewCrewS
                    StewCrew
                    Gracias Senior Rainey!
                    Rowleym said:
                    Yes he is :D
                    Hahaha I go back and forth on this every day. I just want to get it all together first and worry about boost later. There's a lot going on with the car right now and I'm going to hold off on overwhelming myself even more. But in the future a holset may be involved :)
                    Ahh good call! I wouldn't want to go back and replace them when it's all said and done.. Added to the list.
                    • StewCrewS
                      StewCrewS
                      StewCrew
                      This is true. Boost parts will be built up on the side.
                        EDIT: ^ that
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          Rowleym said:
                          EDIT: ^ that
                          Indeed. Hey if you have someone else who wants to buy those injectors feel free to sell them. A mls head gasket is one of the last major things I need, so unfortunately that comes before injectors 😕
                            cool to see this motor come apart! was there something wrong with it, or did you just want to dive in? how many more miles did you put on it?
                            also, the bags of cheetos are in the transmission.
                            • StewCrewS
                              StewCrewS
                              StewCrew
                              Nothing major was wrong at all man! The very first time driving it home with the swap I bottomed it out reeaally hard (with my skid plate on luckily). I live in the middle of nowhere so I should have known. But that caused the lower timing seal to drip oil. Not a lot, but still. And I honestly only put about 100 miles on it. The motor always ran strong, but it was always one thing or another with the car itself, but I definitely got to enjoy it. Anyway I figured while I'm changing the lower timing gasket, I would freshen up the rest of the motor since I've never done an actual rebuild before.
                              That explains why no fluid came out of the trans... Clogged with Cheetos... (Totally kidding, the trans fluid looked great lol)
                                Ever since Dan let me take a quick drive in his old car with that drivetrain I have wanted a nice shifting transmission. That thing is great!
                                • StewCrewS
                                  StewCrewS
                                  StewCrew
                                  It really is. I can't wait to feel it with a new clutch and fresh fluid.
                                    Yea no worries man. I sold the first set I was looking to sell, but I still have another.
                                      when i offered to sell the skid plate to you and you mentioned you were going to make your own, did i make a face like 'yeah, ok'? because i feel like i would have, lol. those motors run so low in the chassis.
                                      only 100 miles? that thing is still low mileage!
                                        ^you have a 24v swap skid plate?
                                          Hey stew, what are the spring rates you have on those bc's? I'm thinking about following you on those..
