550 Posts 16 Posters 0 Views 1 Watching
  • StewCrewS
    StewCrewS
    StewCrew
    Snap Understeer said:
    They wont align the cams with their respective timing marks simply because the cams will rotate to wherever they want to be due to the valve spring tension (without the timing chain to keep them held in position). So its on you to remember to line everything up to TDC upon assembly, check it, rotate the engine 360 degrees, check it again, rotate the engine by hand a few more rotations, then check it yet again.
    That's the part I'm worried about is setting the cams up right. I didn't use cam blocks (dumb.. I know) while taking the head off so I'm not sure how to set them. I'm sure it'll be fine and work itself out when I get there. All part if the learning process :)
    wasnt m3 said:
    Like I mentioned earlier, I have all the tools, including the flywheel locking pin. I got nervous when puting my head back on after MLS gasket and ARP stud install and had a bmw tech set my timing. Well worth the $100 for piece of mind knowing everything there's not going to be any piston to valve contact. I can get you his number if you need it. He came to me to do the work.
    I like this idea a lot. Yeah, send his number my way. Does he let you watch? I know some mechanics/techs don't like that. I'm all for paying someone to come do it as long as I'm able to watch and learn how to do it properly. I never believed people when they said timing your first time was intimidating, but it definitely is.
    • need4speed1299N
      need4speed1299N
      need4speed1299
      If you disassemble and reassemble your head, you can save money. Label and keep everything in order.
      • StewCrewS
        StewCrewS
        StewCrew
        Some more progress \m/
        Posted Image
        Started to clean to lower timing cover too.
        Posted Image
        Taking a break for now. Making hip up a parts store and get some gaskets ordered for it to go back together :D
        • StewCrewS
          StewCrewS
          StewCrew
          List of things ordered:
          Water pump
          Valve cover gasket
          Cam position sensor
          Crank position sensor
          Thermostat and thermostat housing
          Vanos gasket
          Left and right lower timing cover gasket
          Things I still need to order are a MLS headgasket and a 1-piece timing chain tensioner. But I got a majority of the things checked off of my list :) Im sure theres more things I notice while it is going back together, but thats okay. Im glad I got a good chunk of it ordered.
            This thing's coming along nicely Jacob! :) keep up the work!
              Between all the M50 and turbo related stuff on here I cant keep things straight. Are you eventually going turbo?
                Yes he is :D
                  Do yourself a favor and replace the knock sensors while you have everything apart. They're often cracked and are not fun to get to.
                    Rowleym said:
                    Yes he is :D
                    Not from what I've been told. Staying N/a for now, so he can beat the ever living piss out of that motor.
                    • StewCrewS
                      StewCrewS
                      StewCrew
                      Gracias Senior Rainey!
                      Rowleym said:
                      Yes he is :D
                      Hahaha I go back and forth on this every day. I just want to get it all together first and worry about boost later. There's a lot going on with the car right now and I'm going to hold off on overwhelming myself even more. But in the future a holset may be involved :)
                      Ahh good call! I wouldn't want to go back and replace them when it's all said and done.. Added to the list.
                      • StewCrewS
                        StewCrewS
                        StewCrew
                        This is true. Boost parts will be built up on the side.
                          EDIT: ^ that
                          • StewCrewS
                            StewCrewS
                            StewCrew
                            Rowleym said:
                            EDIT: ^ that
                            Indeed. Hey if you have someone else who wants to buy those injectors feel free to sell them. A mls head gasket is one of the last major things I need, so unfortunately that comes before injectors 😕
                              cool to see this motor come apart! was there something wrong with it, or did you just want to dive in? how many more miles did you put on it?
                              also, the bags of cheetos are in the transmission.
                              • StewCrewS
                                StewCrewS
                                StewCrew
                                Nothing major was wrong at all man! The very first time driving it home with the swap I bottomed it out reeaally hard (with my skid plate on luckily). I live in the middle of nowhere so I should have known. But that caused the lower timing seal to drip oil. Not a lot, but still. And I honestly only put about 100 miles on it. The motor always ran strong, but it was always one thing or another with the car itself, but I definitely got to enjoy it. Anyway I figured while I'm changing the lower timing gasket, I would freshen up the rest of the motor since I've never done an actual rebuild before.
                                That explains why no fluid came out of the trans... Clogged with Cheetos... (Totally kidding, the trans fluid looked great lol)
                                  Ever since Dan let me take a quick drive in his old car with that drivetrain I have wanted a nice shifting transmission. That thing is great!
                                  • StewCrewS
                                    StewCrewS
                                    StewCrew
                                    It really is. I can't wait to feel it with a new clutch and fresh fluid.
                                      Yea no worries man. I sold the first set I was looking to sell, but I still have another.
                                        when i offered to sell the skid plate to you and you mentioned you were going to make your own, did i make a face like 'yeah, ok'? because i feel like i would have, lol. those motors run so low in the chassis.
                                        only 100 miles? that thing is still low mileage!
                                          ^you have a 24v swap skid plate?
