E30 running problems
Checked fpr. It's good
Are you throwing any codes/cel? Do a stomp test to see what's going on or get a code reader.
In addition to what's already been mentioned such as temp sensor, timing belt off a tooth etc, are the plug wires new/old (arcing) and are they hooked up correctly? Clogged cat? O2 sensor?
when I hear the rough idle, better running when warm, and stomp the gas and it bogs i think intake leak to me. get it smoke tested.
keeperofchaos said:
I recently purchased an e30 325is. I got the car knowing it needed a little work probably just a tune up. I did the tune up (plugs, coil, fuel filter, cleaned ICV, cleaned AFM pulled injectors and cleaned and tested them, and i even took and cleaned all the contacts on the distributer cap and rotor) and it still runs like dog shit. it usually won't stay idling and if you finally do get the RPMS to come up it will backfire like crazy shooting flames threw the exhaust. I tested the AFM and it seams to be working properly. Does anyone have any idea what to try next. I am about to give up on this thing... BTW i need this running before the snow comes, i need to get the E36 put away.
If your getting backfiring?
that sounds like the pistons are firing at the wrong time. Is the backfiring coming out of the tail pipe or up in the engine bay?
Do you have a Bentley manual? Biggest help is that book.
Just to remind everyone, we have the link for the digital copy posted on the forum.
if you don't have a bentley for the car. that is where to start. That book solves EVERYTHING. such massive detail and an insane amount of information.
The Bentley is good but it is definitely not any sort of bible. The index really irks me sometimes. I remember one time looking for something ignition related and it ended up being under "Transistorized coil ignition (TCI-i) system" in the index. double-you-tee-eff mate.
That is true. The index sucks dick.
but otherwise it is basically a bible.
I owe that book like $5,000 grand in savings for my jetta.
I've only had to use it a couple of times for my e21.
yeah.....still no fixins due to not giving fucks. have not touched the car for 2 weeks and I'm going out west for 2 weeks this coming week. so im taking it to a shop and telling them have fun. lol. but before i take it ill try and get vid of how it was running and post that along with what they find, just to help with anyone in the future. thanks everyone for the input its just to cold to work on it and i don't really have the resources i used to working in a shop. Wish me luck
the e30 does run. it was a combination of plug wires and the pulse ring
