  4. E30 running problems
24 Posts 11 Posters 0 Views 1 Watching
    What ECU do you have? If you need one, I have one. I belive its a 173.
    • camarokC
      camarokC
      camarok
      Intake boot? Yes I know it's silly but check it. Air is metered before intake boot, if there are any significant cracks the car will run super lean.
      KEVIN
      BMW CCA # 416146
      sudo kill -KILL cupholders
      CDV Free, 545i Shifter and ///M Weighted Shift knob.
      Member of DSC Module Failure Club $$ :(
      deathwarden5 said:
      Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
      Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
      • K
        K
        keeperofchaos
        Not the AFM. I do hear the ICV buzzing when the key is on. This is driving me crazy. WHY is it running so rich. :( i just need to get this thing running. It runs like poo when cold, it usually wont even stay idling, when you hit the gas peddle it will die 97% of the time and if it doesn't die it just backfire. If you can get it to warm up it runs worse and backfires at idle again that is only if you can keep it idling.
          I've bumped into bad fuel pressure regulators on a few E30s. The diaphragm inside leaks and pulls fuel through the vac. line into the intake manifold. pull the vac. line going to the FPR and see if it has fuel in it. If so, replace the FPR.
          • K
            K
            keeperofchaos
            Checked fpr. It's good :(
              Are you throwing any codes/cel? Do a stomp test to see what's going on or get a code reader.
              In addition to what's already been mentioned such as temp sensor, timing belt off a tooth etc, are the plug wires new/old (arcing) and are they hooked up correctly? Clogged cat? O2 sensor?
                when I hear the rough idle, better running when warm, and stomp the gas and it bogs i think intake leak to me. get it smoke tested.
                • jockhater2J
                  jockhater2J
                  jockhater2
                  keeperofchaos said:
                  I recently purchased an e30 325is. I got the car knowing it needed a little work probably just a tune up. I did the tune up (plugs, coil, fuel filter, cleaned ICV, cleaned AFM pulled injectors and cleaned and tested them, and i even took and cleaned all the contacts on the distributer cap and rotor) and it still runs like dog shit. it usually won't stay idling and if you finally do get the RPMS to come up it will backfire like crazy shooting flames threw the exhaust. I tested the AFM and it seams to be working properly. Does anyone have any idea what to try next. I am about to give up on this thing... BTW i need this running before the snow comes, i need to get the E36 put away.
                  If your getting backfiring?
                  that sounds like the pistons are firing at the wrong time. Is the backfiring coming out of the tail pipe or up in the engine bay?
                  Do you have a Bentley manual? Biggest help is that book.
                    Just to remind everyone, we have the link for the digital copy posted on the forum.
                      Also, Steven, If you want the Bentley, you can come over whenever and pick it up. Or even when you are working I can drop it off.
                      • jockhater2J
                        jockhater2J
                        jockhater2
                        if you don't have a bentley for the car. that is where to start. That book solves EVERYTHING. such massive detail and an insane amount of information.
                          It's downloadable for free off here... And it's Stephen.. ;)
                            The Bentley is good but it is definitely not any sort of bible. The index really irks me sometimes. I remember one time looking for something ignition related and it ended up being under "Transistorized coil ignition (TCI-i) system" in the index. double-you-tee-eff mate.
                            • jockhater2J
                              jockhater2J
                              jockhater2
                              That is true. The index sucks dick.
                              but otherwise it is basically a bible.
                              I owe that book like $5,000 grand in savings for my jetta.
                              I've only had to use it a couple of times for my e21.
                                Is this thing fixed yet Steven?
                                  This thing is still dead. Stephen's just gunna have to ball hard and roll dumped in winter!
                                  • K
                                    K
                                    keeperofchaos
                                    yeah.....still no fixins due to not giving fucks. have not touched the car for 2 weeks and I'm going out west for 2 weeks this coming week. so im taking it to a shop and telling them have fun. lol. but before i take it ill try and get vid of how it was running and post that along with what they find, just to help with anyone in the future. thanks everyone for the input its just to cold to work on it and i don't really have the resources i used to working in a shop. Wish me luck :)
                                    • K
                                      K
                                      keeperofchaos
                                      the e30 does run. it was a combination of plug wires and the pulse ring :)
                                        Saweet!
