Build Thread?
Alrighty, so I did some cleaning yesterday!
The motor was gross, as most motors are.
It all looked a bit like that to begin.
ignore the valve cover, that is getting special treatment
And the pile it left on the floor was ridiculous, filled up a dust pan!
Other than that, looking at MS setups, I think I will end up with an ms3x setup!
MS3x is the shit. You know I can help you with that Ben, looking forward to what you do.
Hi jake! I will do some reading today and get at you with some questions!
Ever see a transmission that was made and then sat in the warehouse its whole life? Me either!
But I did clean mine a bit
Got the head off recently, nice easy process without VANOS! I was a bit concerned about how the inside of the motor would look, but I was greeted by this!
Honing is still there, no ridge where the piston stops, no wear on the cams ect. Super happy with it!
Ordered new piston rings and rod bearings and am currently saving for ARP and MLS!
Anyone have recommendations on how to get the rest of the stock gasket residue off?
Use a RED Scotch Brite pad and some brake cleaner. Scotch Brite pads come in different abrasives; gray = fine, red = medium and green is rough.
They do make a semi long handled gasket scraper. Gives better pressure to get the old stuff off.
Anyone interested in a freshly build m50nv? I may be trying some new things lol
Well it just got new rod bearings, rod bolts, head bolts, all piston rings replaced, the head is going to be decked the smallest amount possible to make sure it mates well. Bore is beautiful, and you can has wiring harness and ecu if you need it.
Not sure what you had in mind for price, would you need the e36 oilpan? Because I still have that hanking around.
Idk, 600?
This isn't set in stone yet
Yeah.
Anyone notice that I suck at build threads? I do!
Got the head redone, looks real nice and shiny!
Got ARP studs and a .14 MLS gasket, painted the block a lighter gun metal grey (ha, get it?) and put it all back together, along with new piston rings and rod bearings and all new bolts. I have the turbo, its a holset HX35, ordered an intercooler.
Got a ZF, lots of stuff. All good fun!
Seriously, this thread is worthless without pics
Pics later, just grabbed some more hours at work to keep funding it
Alright, so a while ago I pulled the head and took that in to get machined and hot tanked, came back like this
Was good to say the least, then the goodies rolled in!
ARP2000's and a Cometic MLS gasket!
Put the head back on, and bolted her down tight!
Cleaned and painted the block somewhere in there as well.
Soo much gasket...
oh, and this!
Cleaned up my carrier and added a new bearing to that as well!
And just because he did it...
Tis my father! Who recently bought a 330i sport! I don't have pictures of it for some reason?!
With your input, this post could be even better š
