  4. Build Thread?
Build Thread?
    Actually, the bitch clip isn't that hard. Ryan's girl and I got it out relatively easily...
      Mine was F'ed up, I seriously had to punch it out the opposite way it should have come out.
      Anyway, motor is out.
        Haha gotcha. ALSO. Gibbies has a few M70's if you wanna really get ballsy with that motor swap! ;D
          Yeah I saw a few of those, thought about it.
          Silly motors really, hard to add power.
            I know.. The weight gain would be terrible too...
              Got the trans off the motor today, took the clutch and flywheel off and stuck it on the stand!
              Also was looking into clutches a bit, I think I will end up getting a clutch masters stage four setup. This would use the stock dual mass flywheel, a six puck rigid ceramic disc and an HD pressure plate. Called them up, guy was helpful and said it would be a great setup for up to 620 flywheel torque, and that the stage three would only be good to 425hp so that would be lame. The pricing is the same between the stage 3 and the stage 4 kit, so why be concerned about not being able to hold the power when its the same price?
              $585 for the pressure plate and disc..... shit, this is going to get expensive real quick!
                Lookin good man! yeah it'll be expensive. But so worth it!
                  check out "grudgerider156" on youtube
                    Alrighty, so I did some cleaning yesterday!
                    The motor was gross, as most motors are.
                    Posted Image
                    It all looked a bit like that to begin.
                    Posted Image
                    ignore the valve cover, that is getting special treatment :)
                    Posted Image
                    Posted Image
                    And the pile it left on the floor was ridiculous, filled up a dust pan!
                    Other than that, looking at MS setups, I think I will end up with an ms3x setup!
                      Let me know how you like ms3.
                        MS3x is the shit. You know I can help you with that Ben, looking forward to what you do.
                        šŸŽ¬ YouTube channel (60K+ subs): youtube.com/jakespence135
                        šŸ“· Follow me on Instagram: instagram.com/jakespence
                        šŸ Shop BMW merchandise: bimmerstreet.com
                          Hi jake! I will do some reading today and get at you with some questions!
                            Ever see a transmission that was made and then sat in the warehouse its whole life? Me either!
                            But I did clean mine a bit
                            Posted Image
                              Got the head off recently, nice easy process without VANOS! I was a bit concerned about how the inside of the motor would look, but I was greeted by this!
                              Posted Image
                              Honing is still there, no ridge where the piston stops, no wear on the cams ect. Super happy with it!
                              Ordered new piston rings and rod bearings and am currently saving for ARP and MLS!
                              Anyone have recommendations on how to get the rest of the stock gasket residue off?
                                Use a RED Scotch Brite pad and some brake cleaner. Scotch Brite pads come in different abrasives; gray = fine, red = medium and green is rough.
                                • H
                                  H
                                  Hammerdown
                                  They do make a semi long handled gasket scraper. Gives better pressure to get the old stuff off.
                                    Anyone interested in a freshly build m50nv? I may be trying some new things lol
                                      Depends on your price sir.
                                        Well it just got new rod bearings, rod bolts, head bolts, all piston rings replaced, the head is going to be decked the smallest amount possible to make sure it mates well. Bore is beautiful, and you can has wiring harness and ecu if you need it.
                                        Not sure what you had in mind for price, would you need the e36 oilpan? Because I still have that hanking around.
                                          I would need that pan, but I'm looking at a base price since I already have a ton to buy this winter.
