  4. Another daily driver thread: E34 525i
153 Posts 18 Posters 3.4k Views 1 Watching
    Congrats! I got plenty of grills and headlights. condition isn’t great but I have a full blue interior.
      Awesome, great to know. Provided it runs, I’ll take a headlight set and grille set. I’ll kill over the interior, I can’t decide if I want to just replace the rear seat so I can put people back there in a pinch, or if I want to go all out and put door cards and some of the other things back in. The old rear seat looks solid but has a few spots of mold at the bottom edges on the side, anyone have tips for removing that to try and save it? I’m thinking I’ll steam clean or just soap and water scrub the rest of the interior, it honestly doesn’t look bad but I want to make sure I get rid of any mold, mildew or mouse turds that are still lurking.
      Diagnosis process I’m thinking is something like this: Put a battery in and check if the fuel pumps are running, and then make sure it’ll turn over (disconnect fuel pump relay and just bump the starter), drain fuel tank and put some fresh stuff in there, and replace fuel filter. Drain and refill oil with the cheapest crap I can find just to have fresh stuff again. Crank without fuel pump to circulate oil.
      Check CPS to make sure the wire isn’t just cut or something. Make sure all other obvious things are plugged in and appear to be functional. Give er a crank and see what happens. If no start, check for spark and pull plugs.
      I’m taking a vacation next week so I probably won’t get to it for another two weekends, but I’m excited t get the old thing revived!
        That's awesome!! Congrats on the pickup!
        Also, what site did you order the heritage 6's from, directly from MOMO? I've always really liked the look of those.
        Edit: Found it! I'd have some on the way if they did a 16. I'm thinking these might still look good in 17 on the e30... hmmm
          Thanks! Long term, I’ve always wanted to try to drug that is boost, maybe this’ll be my muse…
          Do it! I think they’d look great! A bit heavy if I’m being honest, but they’re going to be pure street wheels for me and I think they’ll do that job quite nicely.
            118,9xx: First time stranded!
            Clutch pedal went to the floor leaving my neighborhood this morning, it’ll be on its way to the shop tonight. Luckily, I was close enough to walk home but definitely an inconvenience. Hoping it’s just a slave cylinder and it can be back on the road quickly, I have no time to look at it or fix it (or the e30 or e28 to drive in the meantime, I should really get on those).
            Oh well, not bad for ~60k miles of ownership so far to have this be the biggest inconvenience with it so far. VANOS is starting to rattle in addition to torque loss down low, so that along with brakes front and rear are on the docket for this fall once time becomes available. Really need to catch up on maintenance with this one.
              Original clutch? I’d be prepared to have them replace it, it’s at that mileage now. When the clutch went out on my 530i it would just go straight to the floor too and it really didn’t feel like it was going out before that.
                Yep, original clutch. That’s the plan if they have to pull anything at all, it still grabbed well but I could tell it was getting to the very end of the clutch range it felt like.
                Honestly wouldn’t be that upset, I have a whole pile of parts for them to replace if they do the clutch so it wouldn’t be that bad of a thing to happen. And then it’d be done and good to go for another 100k+!
                  Got the car back Thursday, the culprit ended up being the clutch master and not the slave (though they replaced the slave first) to the tune of around $900 all in with a wheel balance. Sheesh. They also charged $300 and some change for the system bleed so not really sure what that’s about, everything else seemed reasonable as far as labor and parts.
                  Anywho, got eh car back and everything with the clutch is fine, but my door no longer shuts well (feels like it’s bent upwards at the hinge, and that it gets forced back down to the correct position once it hits the latch) and the wheel balance is far worse than before, with some pretty violent shaking sometimes above 55-60mph. The wheels and tires were balanced very recently but had a slight vibration that I thought they could maybe fix, it was definitely made worse with their work. Had no issues with the old set of wheels so I’m thinking that it’s wheel/tire related and not mechanical, although it could be the larger and heavier wheel/tire exacerbating a worn part. All control arms and sway links in the front are around 30k old, tie rods and other steering bits are originally but felt fine last time I had it up in the air. Any thoughts from the e34 hive mind? From what I have read these cars are particularly prone to vibration from a multitude of sources.
                    Is the center bore on the wheel the same as the stock e34?  If not, buy a set of hub rings.
                      Haven’t checked with a caliper, but it should be. Ordered the standard fitment 72.56mm centerbore when I purchased, and they fit tightly when installed a few weeks ago.
                      I had the car flat bedded into the shop, I wonder if the tow driver strapped over a control arm and bent it? Or a tie rod? Anything think that would be enough to cause a vibration like this?
                        Is the shaking at all speeds?  If it's most prevalent in the 55-60 mph range that sounds like a wheel/tire issue.  When they balanced them did they road force them?  There are imbalances that can be fixed using a road force balance then re-orientating the tire on the wheel.  If you had a bent control arm/tie rod or most other suspension components you're gonna get a crooked steering wheel or a pull when you loosen your grip on the wheel.  Those components directly impact your alignment so there would be another drivability symptom.
                          Nope, really just 55+ and gets more severe above 62 or so (indicated). At 45-50 and below it’s buttery smooth, I actually didn’t even notice until the day after I got it back because I never broke 50 on the way home.
                          I’m sure they didn’t road force them, I’m guessing they don’t have the capability but I know of a few shops around that can. I just find it odd that it’s worse than when I took it in, and noticeably so. They mentioned adding a half ounce or so of weight to a few of the wheels but their general vibe was that they were pretty close so I’m a little leery of that being the cause. I wouldn’t think that much weight would make this significant of a difference, but you never know.
                          No noticeable pull that I could feel, although e34’s tracking straight ahead is kind of a crapshoot with the box anyways. Steering wheel is definitely off center, and while it wasn’t perfect before it seems like it’s more significant then before. I might swap my old (known good) wheel set back on to see if that solves the issue, and if it doesn’t it’s going straight back to them to figure out what’s up.
                            Realized I never answered the question here! Yeah, I bought them directly from MOMO, they did a buy two-get two sale this summer and early fall with free shipping on top, so it was only around $760 for the full set. They’re HEAVY though, other than the potential centerbore issue they weigh like 25-27 lbs apiece compared to the 18 or so of the m-systems, it’s definitely noticeable. More of a street wheel in my opinion, but no less cool as a result.
                              122,577
                              Oil change, 5W-40 Mobil 1 euro full synthetic. Also changed trans fluid with Redline D4, shifts were starting to feel notchier and trans fluid hadn’t been done in awhile so I went for it. Didn’t improve it as much as I’d like, unsure if it’s just wear or something with the replacement master/slave, or a worn clutch. Oh well.
                              Replaced the alternator at the same time, it was starting to whine again (voltage regulator I think) after only a year, I just sprung for a Bosch reman from FCP instead of the garbage warranty replacements I’ve been swapping out every year from O’Reilly’s. Here’s to hoping that lasts longer, the bearings were shot too already on the old alternator. I had no choice due to time when I first replaced it, but 20k miles seems pretty pitiful.
                              Flex disc is pretty well shot also, need to get that changed ASAP. Flying to Florida this weekend, so it’ll have to wait until the next. Already have the flex disc and driveshaft end bushing, just need to toss them in. I remember that bushing being a pain in the ass on the e30 last time I did one, anyone have a good trick for getting the old one out with minimal cursing?
                              In other news, I bought a truck!
                              It’s big and very rusty but was very, very cheap. It’s a V10 4x4 limited, so pretty capable, shockingly comfy and full of features, absolutely massive inside, and gets somewhere around 10mpg. Did I mention it has a lot of interior space? It’ll fit 4’x8’ plywood sheets with the 2nd row folded and the 3rd row removed 😂
                              Long story on why it was cheap, but it very much figures that the day I bought it, I got it the hour home and was running to the post office to mail the registration documents and the power steering box shit a seal. It emptied the contents of the reservoir in about 20 seconds and left a very nice snail trail in my wake from work to the O’Reilly’s parking lot. Still working on fixing that, but getting closer. Need to get one line off of the pump, then it can all go back together.
                              Side note, I’d like to punch the engineer who put this hose outlet in the spot he did right in the mouth. Can’t get it off with the pulley on. Ugh.
                              Brakes are sticky on at least one corner too, but otherwise it seems pretty okay. I’m fully expecting other things to crop up, but it was driven regularly and maintained well before I bought it so the hope is that it doesn’t become too needy. Verdict is still out on what I’ll do with it, I bought it to tow and promptly found a hidden rust hole in the hitch receiver. Tank has to be dropped to replace the receiver, so I may just do that in the spring once it proves whether it’s going to be reliable enough to invest the time into for that. Stay tuned!
                                Congrats! Welcome to the world of acquiring more shit you don’t need cause you can haul anything now 😂
                                  Thankfully, I’m out of room for the most part at my storage unit so minimal opportunities for more useless shit acquisition at the moment. Although it did come with a plow that I’m not sure what I want to do with yet, if that counts haha.
                                  Having the lumber capacity is going to kick ass though, I’d also like to do some camping trips with it if it proves to be reliable enough. I’m envisioning an air mattress in the back, screens for the rear windows, kitchen setup on the rear barn doors, and a nice big roof rack from a plumbing van (thanks @Jdesign for the e36 inspiration on that one) for hauling a canoe, bikes or random other gear. I’ve seen some awesome setups more geared towards overlanding and while this will be very budget minded and not involve off road travel I see a lot of potential for a great travelling rig here.
                                    That's awesome about the excursion. We had a diesel excursion 7.3L when I was in high school and I loved driving that thing. I piled 10+ friends in that thing and went on road trips during the summers. Was great! My dad sold it when diesel was incredibly expensive years ago and now wishes he still had it.
                                      Oh man, that must’ve been awesome. I had a grand marquis with a front bench in high school and thought even that was pretty great, rolling 6 deep to lunch was awesome. I’m betting that just about everyone that had one regrets selling with how much value they’ve gained in the last few years!
                                      The saga unfortunately continues for mine, fixed the power steering system (fought with a profusely leaking remanufactured PS pump right out of the box, super fun) and then promptly blew out a caliper piston seal two days later. Sigh.
                                      Parts should be here tomorrow and I’m hoping to fix it Sunday. Going to go through and refresh all the brakes while I’m at it, not something I want to risk happening again, especially with how many friends I might have in the car or the weight I might be towing behind it. It’s had most of the hardlines replaced, soft lines are mostly original so they’ll all get redone. Replacing both calipers on the back at once, new pads and rotors all around, and inspecting front calipers as well. One of the fronts has been replaced relatively recently, I’ll be replacing the one that isn’t new as well. Cheap insurance for preventing a breakdown far from home.
                                        126,650
                                        No notable service performed, finally got around to checking the centerbore diameter of the MOMO’s I had on the car this summer and sure enough, the ID is definitely larger than 72.56. My guess is 74.1mm e39 fitment, so I’ll be buying a set of hubcentric rings for next year. Quite frustrating considering I purchased them new and chose the correct size, oh well. Definitely explains the persistent vibration!
                                          Well that’s a bummer. Are they under warranty? I would talk to customer service still, worth a shot at maybe getting the correct wheels you ordered.
