  4. Diaries of a Daily Driver
199 Posts 23 Posters 0 Views 1 Watching
    We got a bunch of snow recently, had to move the M3 out of the garage to work on other things. She didn't like the cold.
    Ordered rod bearings, motor mounts, and exhaust gaskets.
    I really enjoy this thing. I have neglected all other vehicles since obtaining the M3... image.png
    • pynaclP
      pynaclP
      pynacl
      Sure the S65 is like the S54 with constant debate about which bearings are the best, coated vs non coated etc. Curious what you ended up going with?
        You are oh so correct about there being thousands of posts and debates about what is best.
        I avoided coated bearings as it seems they are typically coating stock sized bearings, which is extra not good.
        I went with BE bearings and bolts, as it seems they are the most consistent in sizing and you are basically paying for them to check and provide matched sets over something like ACL's where you want to mix shells to get extra clearance but not too much. I don't want to have to be in there twice so the extra couple dollars for QC is worth it to me.
        In looking at the journal dimensions and bearing tolerances I quickly understand why these have bearing failures, that's a damn tight clearance!
          Doing the BE bearings with the ARP install hardware is by far the best move. That peace of mind of worth the money. Best money I spent on my car.  They’re the most popular choice out there (when they’re available). I haven’t seen a single failure on the forums when they’ve been installed.
            Those are one of the best looking M3's in my opinion.
              It was a very busy couple of days for the M3!
              At 109k miles I did the rod bearings and bolts, motor mounts, header gaskets, trans mounts, driveshaft center support bearing, trans fluid, and engine oil.
              The motor mount on passenger side was two pieces, and the drivers side was collapsed and the oil pan was resting on the sway bar.
              Bearings looked acceptable for the mileage, but good to have piece of mind that they're done.
              The motor had been replaced by the dealer at around 300 miles for a stuck injector, and it looks like they didn't do the header gaskets correctly...
              The drive after felt great, significantly smoother with the engine not rocking around in there and being properly isolated from vibrations.
                Now you can rev to the moon with no fears! ALL THE RPM's!!!!
                  What's better than having 5 vehicles? Having 6!
                  A poor picture for intro, but its the only one I have right meow
                  This was a spur of the moment decision, and is planned to replace my truck and 1 series.
                  2011 x5 35d Sports package, HUD, 360 cam, premium package, pano sunroof, and a set of snow tires + to go with it
                  More details / photos later
                    Hitch installed
                    Nice an easy access to get that one installed.......
                    Got a bike rack after much deliberation. Settled on a 1up Recon 5 vertical rack. 5 places for bikes, pivots out of the way of the hatch, and weighs a cool 95lbs! I've been enjoying it vs the truck
                    Did some light off-road driving in Whistler to car camp after a day of biking (full size mattress fits perfectly with the seats folded down) and found I need to get rid of the 20's as soon as possible.
                    Went up to Mazama to visit a friend, rock climb, mountain bike, and go for a hike and brought the X5.
                    On the way back got an error for oil level over max, which I thought was odd as I had checked it after purchase and the oil level was near the top, but not over. Checked on the dipstick and it was indeed over the max mark, meaning the oil level sensor was intact. The oil smelled like diesel so the hunt was on. After pulling up the coolant temp and driving around a bit I found that the thermostat is stuck open, and am trying to find when the last DPF regen was as it likely got up to temp to be able to do a regen while climbing the mountains, but then cooled down and just dumped all that extra fuel into the oil. I can't get the coolant temp to go over 150 on the highway, with 140 being the average. Running temp is to be in the 190-195 range, so I'm getting plenty of fuel past the pistons.
                    New thermostat and EGR delete on the way! Of course with an oil change in the next couple of days.
                      Glad mine had the hitch already! Curious to hear about the delete job. How many miles on yours?
                        133k
                          Fixed the offroad issue with some 18's and 31" all terrains (Falken Rubitrek)
                          I dig the look, and will enjoy it even more once I get the 20mm spacers in the rear!
                          I've got a bit of clearance work to be doing, but nothing major!](/assets/uploads/files/monthly_2022_08_image.jpeg.060fa7122d51bfe9d5fdcf76b45b41b7.jpeg)
                            I can't tell if I like the street or over landing look more with E70's
                                I;m thinking about thos Sidewalls.
                                  I dislike the phrasing that ECS used for their lift, as there is no height issues limiting tire size. The limit to tire size is the front spindle design, the control arm ball joint mtg is over the tire instead of behind it. You are physically limited to a 31" OD tire unless you completely redesign the front suspension or run a large spacer.
                                  They're less sidewally than I wished for, but the brakes limit me to an 18" wheel, and the upper control arm / spindle limits me to a 31" tire without getting wild.
                                  I looked at the rabbit hole that was "Stuffing 33's" under it and doing what it took, but at the end of the day it's my daily driver so I should avoid that.
                                  For now 😄
