  4. 2002 E46 M3 // Build Thread
167 Posts 17 Posters 3.2k Views 1 Watching
    Wow, Ospho is no joke and it turned out great.
    Stoked on the aluminum trim too.
      You are doing a lot of good things! Nice work! I enjoy the updates.
      Post a sound clip in the spring once its back on the road
        Added Ospho to my buy list, love the results!
        • pynaclP
          pynaclP
          pynacl
          Thanks Brian! There's quite a few things on the car that were inspired by your build, so I'm thankful for that. Especially ECUWorx, I've used the hell out of that program.
          Same, I was super impressed! It also claims to add protection to the metal to help keep rust from forming in the future, so hopefully it stays this clean.
            Dang you removed all the seasoning
            • pynaclP
              pynaclP
              pynacl
              Had to toss the car up on stands again to bleed the brakes since I messed with brake lines again. While it was up I decided to toss the new X pipe on. Overall was super easy to install, just tedious with all the metal braces that have to come off.
              Only hiccup was the pipe didn’t come with hardware to transfer over the factory pipe’s heat shield. If I’m going to do it might as well do it right so I went out and found some nice grade 8 yellow zinc hardware to attach it. One bolt had to go backwards because of the clearance, which bugs me, but oh well.
              AAA726DA-6583-496D-A50F-D64FC241B4AB.jpeg615F63EA-C8D4-4BC1-9E89-8796EA26D06C.jpegE061CF06-A6BD-489B-80BF-02C082E7807A.jpeg04D83BEA-C3C3-4707-BF11-91553BCE7CAC.jpeg
                I hope that you never forget that bolt is backwards.
                  The concours judges certainly won’t
                  • pynaclP
                    pynaclP
                    pynacl
                    Snow finally melted and we've had a few good rains in to wash all the salt away. Took the M3 out today and gave it a test drive after all the changes. Ran like a can of beans. Turns out I had crossed the two pre-cat O2 sensors when doing the header install. Finally got them swapped and it's no longer a can of beans. Tossing in a lil sound clip of the new X pipe too, sounds freakin awesome in person.
                    672284200644CAA3E68-62FE-4349-BE80-C80B6A10A6D9.jpgIMG2440.jpg IMG_2441.mp4
                      Throaty!
                        That sounds great!
                        • pynaclP
                          pynaclP
                          pynacl
                          That sounds great!
                          Thanks Pat! The tone is absolutely perfect, exactly what I was going for. The volume on the other hand is ridiculous, I'm sure you could hear it from a mile away. With that the drone is also a bit vicious at 2-2.5k RPM. Might need to go with a different muffler, but going to just enjoy it for a bit!
                          • pynaclP
                            pynaclP
                            pynacl
                            @Rekpointsnapped a couple exhaust clips this past weekend. Sounds pretty dang good for an S54!
                            • pynaclP
                              pynaclP
                              pynacl
                              Took the car out for the first decent drive of the season! Cruised along the Saint Croix river for about 200 miles to a neat stone barn pizza place down in Pepin. So happy with how the car has transformed over winter!
                                That color combo
                                Fanning Kimmy Schmidt GIF by Unbreakable Kimmy Schmidt
                                • pynaclP
                                  pynaclP
                                  pynacl
                                  That color combo
                                  Thank you!! The cinnamon isn't everyone's cup of tea, but I really like it against the steel gray's blueish tones!
                                    Exhaust sounds excellent, mellows out the rasp to a nice tone!
                                      I hate the way S54's sound. This is an exceptional exception!
                                      • AndrewA
                                        AndrewA
                                        Andrew
                                        Wow your exhaust sounds amazing.  Is it raspy at all?
                                        • pynaclP
                                          pynaclP
                                          pynacl
                                          Thank you!! This setup virtually eliminated all rasp. I installed each component one at a time and the resonated X pipe seems to be the main contributor to the tone / rasp elimination!
