  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Stock shock mounts installed!
      Chasing a rough idle so I got my injectors flowed and cleaned.  They are flowing great and I threw in some new filter baskets while I had them out.  Didn't solve the problem.  Next up is cleaning the ICV & throttle bodies.
      Installed some 2006 M6 heated front seats. Need to wire up the new-to-me heated seat buttons and then I'm golden! The M3 will see some winter duty while the wagon is under the knife 💯😲
      • pynaclP
        pynaclP
        pynacl
        I can’t believe those fit in the backseat of the M3 lol. Those are going to be such a sweet upgrade going into winter, nice find!
          So rough idle was due to a bad serpentine belt.  A new belt, fan and fan clutch later I was back on the road!
          Mike installed new control arms, poly lollipops, new inner & outer tierods, power steering line, new steering wheel, wired up heated seats, new head light adjuster & mount and getting an alignment tomorrow.
            Good looking steering wheel! Who did you go with?
              These guys outta the Ukraine
                In a world of annoyingly gaudy steering wheel modifications you have done a proper steering wheel.
                For this I thank you!
                It looks quite nice!
                Did you have to send yours in and be without car for a month or two?
                  This x 100000
                  it’s a plague
                    Thanks!  Lol
                    I have a couple of m-sport steering wheels so I had a back up.  With that being said, anyone looking for a wheel?  Lol. I have 3, 1 smg, 2 e39/e46 manual wheels
                      The car still pulls to the right a bit.  We'll replace the calipers next and take it from there.  Really need to be able to text and drive with work and with this pull, it isn't ideal. Tires might be to blame too.
                      Cooling, 3rd pedal, clutch/flywheel, 4.10 wavetrac and boost bits incoming!  Stay tuned!
                        Your insurance company (and all other drivers on the road) would like to speak with you.
                          It has been awhile since I gave an update.  Lots has been happening! Popped on an Active Autowerks supercharger, 4.10 gears with a drexler LSD, CSL King Pins and new bearings, CSL steering rack and all new power steering lines and reservoir, replaced the cam bolts and did a valve adjustment (2 were out of spec), valve cover gasket, manual swap with a JB Racing lightweight flywheel and HD Sach clutch, ZHP shift knob and a short shifter, and turned 200k miles on the car (motor probably has 130k-ish on it), and some 18" Apex wheels wrapped in PS4s 245 front, 275 rears.
                            A man after my heart with those wheels!
                            I love that you still own this thing, I remember bombing around in Fon Du Lac in it when we met to transfer ownership of some parts. It's come a long way since then!
                              I remember bombing Fon Du Lac
                              Hopefully this is a memory we can all share in the future.
                                I've been chasing boost issues.  Replaced the supercharger as I got a bad one.  Still low boost.  Did a Compression test and results were bad.  All cylinders floating around 100psi. Woof. Getting a built S54 from Partee Racing and will get back at it!
                                Cooling had been an issue on the freeway. Might be the AUX fan shroud in the way.
                                  How many miles on the motor?
