  4. 2002 E46 M3 // Build Thread
167 Posts 17 Posters 3.2k Views 1 Watching
  • pynaclP
    pynaclP
    pynacl
    Very cool! Didn't know "newer" cars had the fire extinguisher option too. You could get them on E28's as well along with the spare mounted gas can too.
    Definitely is! Seems like it's only a thing on newer cars in the EU, since I think there's certain countries that require them as part of inspection. Since the US doesn't have any requirements, they stopped offering them here and getting your hands on them is crazy hard. Although I know I could just get any generic gloria style canister, having an OEM one is cool!
      Hopefully you never have to use it
      Or it’s one of those situations where it’s the only thing you save from a car fire because of how rare it is
        I told my mother if her car ever lit on fire, just to let it burn. It'll be better that way.
        • pynaclP
          pynaclP
          pynacl
          Scooped up a top speed muffler for the M3 for a great deal. I know it’s not in the upper echelon of mufflers, but it’s all part of a combo I want to try out. Installation was super easy, just have to pop off the diffuser to access all the hangers. Stock muffler is a UNIT! Has to weigh close to 60lbs. Top speed one is about 20lbs, so should be about 40lbs off the rear end. Pretty happy with how it lined up too, tips stick out an additional 2” or so, protrude the same on both sides and sit at the same height.
          4F15B4B4-788D-4ACA-A600-898308B88773.jpegDD5B47CB-8E4D-4ECC-BC6A-0216DC359DA8.jpegA459E1DF-D33D-4782-BDC4-CFA5F574A18A.jpeg
          • pynaclP
            pynaclP
            pynacl
            Here’s a quick startup clip of before/after the muffler. Both clips have the fabspeed headers installed, which honestly didn’t make a big difference in tone or volume in my opinion. Definitely feels loud, but didn’t test out revving yet since it’s in the garage. Will have to get some take off clips in the spring once the X pipe is added!
            before:
            after:
              • pynaclP
                pynaclP
                pynacl
                LOL! It really do bee like that
                • pynaclP
                  pynaclP
                  pynacl
                  Noticed a bit of oil collecting on the top of the valve cover and realized it was coming from one of the gaskets on the nuts holding the valve cover on. Since I didn't know the last time a valve adjustment was done, I figured this would be a good 2 for 1. Ordered a new valve cover gasket kit, new spark plugs and a valve shim kit.
                  Once I got in there I noticed the cam lobes had some odd wear on the tips. Checked each cam follower and they didn't seem to be chewed up, so it remains a mystery. Guessing some sort of abrasive made its way into the engine at some point. Will monitor it closely and check samples with blackstone next season. Worst case I have a spare S54 thats a bit lower mileage.
                  The valve adjustment went pretty smoothly, ended up replacing 6 shims total and got everything in spec.
                  Current mileage: 136,136
                  • pynaclP
                    pynaclP
                    pynacl
                    Also tackled a couple small things like swapping out the tired old sway bar end links (will likely get adjustable ones if I go down the path of corner balancing), and replaced all the fender liner bolts with clean ones.
                    • pynaclP
                      pynaclP
                      pynacl
                      Got everything buttoned back up in the engine bay and the hood shut for spring. Only have the rear suspension to do now, since it was delayed because of some back ordered RSM bushings. Then just counting down the days until I can drive it again. Hopefully will have my own house and garage soon after as well 😄
                      • pynaclP
                        pynaclP
                        pynacl
                        Ope I lied time to open the hood back up. Forgot that when I was doing the headers, setting the expansion tank out of the way on it's side broke the measure stick off. Since it was brittle enough to break that easily I figured it's time to replace the whole tank and hose. Installation was super easy with this huge syringe I got to suck all the fluid out and pump it back into the new tank, took no more than 15 min total. Only downside was the cost. Just the hose to the tank was $80!! Since I couldn't find any aftermarket alternatives on FCP, I bit the bullet. Also managed to fish out the loose piece while I had the tank out, thankfully it didn't make it's way into the cooling system.
                          Handy syringe, where did you pick that up?
                          • pynaclP
                            pynaclP
                            pynacl
                            Definitely! Mine is just a cheapo one from Amazon: https://www.amazon.com/dp/B0822SDKS9/ref=cm_sw_r_cp_api_glt_fabc_ZF42GD7EA138BSYKSJYJ?_encoding=UTF8&psc=1
                            • pynaclP
                              pynaclP
                              pynacl
                              Took me forever to assemble all the right pieces to finish the rear suspension. After finally getting the right sized RSM bushings that were back ordered, I realized I was also missing the reverse mounted reinforcement plate that secures the shock to the body. Since the mounts are TCK I tried to email them to see if I could order just the top plate. Crickets. Never got a response. Ended up ordering some Rogue Engineering zinc plated ones to test and they just so happened to fit!
                              So in total we’ve got:
                              - Rogue Engineering RSM reverse mount reinforcement plates
                              - TCK Single Adjustable shocks
                              - TCK adjustable perch + spring cone
                              - Rogue Engineering perch reinforcement plates
                              - Hyperco 600lb spring
                              - TCK RSM + Buna bushings
                              Hopefully will have time tomorrow to toss the wheels on and dial in fitment.
                              F6A95096-328C-4359-85B8-F05998F223CB.jpegFB98B5F6-8F8F-4F16-86F7-78333CAABCE3.jpeg4A91B782-3F23-4FF6-B6E8-26A267660709.jpeg1E67DED3-1BA1-47BB-80D0-CD2F6587654A.jpegF89E7086-2349-4308-A866-3BE4170AF65B.jpeg
                              • pynaclP
                                pynaclP
                                pynacl
                                Tackled the rear brake lines last night so the set is complete. Originally planned to do them all at once but some parts were back ordered from ECS (only chose them over FCP since they had a Rennline phone mount I wanted).
                                Lately I’ve been trying to follow the principle that when I go to replace a part, I also replace anything that connects, cushions or fastens to it as well. Otherwise I get this weird feeling I just showered and changed clothes and then put dirty socks back on (corroded bolts, nuts, brackets etc.)
                                F558A39B-B884-424A-A233-CEA0415D27FB.jpeg101FEE51-AF0A-4F92-A6D3-0F805BB79EA4.jpeg42C31A91-D552-4B07-B0F8-2A3A8611A0F0.jpeg
                                • pynaclP
                                  pynaclP
                                  pynacl
                                  Snagged myself a resonated X pipe for the section 2. This seems to be the piece that removes rasp and drastically changes the exhaust note. Guess we’ll find out come spring.
                                  I bought it used and it arrived in pretty good shape, but @Rekpointsuggested I try some Ospho metal cleaner on it. Holy shit did it do a number on the pipe, looks brand new! Definitely have to be careful with this chemical though since it’s phosphoric acid based and pretty much dissolves whatever it touches. Also need to wipe down with water after to neutralize it. But damn does it work.
                                  Here’s a few before / after of 5 min of light scrubbing:2C56D119-A26D-4F39-9E77-27B9591D5936.jpeg33E4F2B1-DBE1-4F8F-B65A-4F80B368FB31.jpeg5BFC7D26-2C5C-42FE-B8BF-0AF375BB40FE.jpeg
                                  • pynaclP
                                    pynaclP
                                    pynacl
                                    Aluminum trim set is complete! Meant to post this update earlier, but the first set I bought was damaged in shipping. Excited to have rid the car of that crappy plastic titan trim.
                                    Also picked up a Rennline phone mount, but just can’t seem to get it to fit just right. Might have a defective one 😦
                                    588AE8FB-A096-49B7-AF8D-4B558CB920DE.jpeg5D5CFF44-CF6C-47C1-975E-8CE838C34053.jpegC0423376-D6E0-47AA-A742-33608C7AC18D.jpeg72A57697-745F-4A3A-910D-66A4C8DF8257.jpeg
                                      Wow, Ospho is no joke and it turned out great.
                                      Stoked on the aluminum trim too.
                                        You are doing a lot of good things! Nice work! I enjoy the updates.
                                        Post a sound clip in the spring once its back on the road
                                          Added Ospho to my buy list, love the results!
