  4. 2002 E46 M3 // Build Thread
167 Posts 17 Posters 3.2k Views 1 Watching
  • pynaclP
    pynaclP
    pynacl
    Will the replacement shocks need to be revalved for the spring rates? Or are they an off the shelf setup
    Yeah they are custom valved to the springs. I did give the spring rates to TCK when ordering, so hopefully the replacements are an exact match. Honestly not sure how to confirm or deny that though
    • pynaclP
      pynaclP
      pynacl
      Got the new shocks from TCK already! Time to swap the GC camber plates on and get these installed. Still not sure if the factory end links will fit. If not, maybe that'll be an excuse to replace them and upgrade front sway bar too.
        pynacl said:
        Got the new shocks from TCK already! Time to swap the GC camber plates on and get these installed. Still not sure if the factory end links will fit. If not, maybe that'll be an excuse to replace them and upgrade front sway bars too.
        I'd suggest going with a shortened or adjustable sway bar link.  The stock ones are made for the stock height.  You're going to change the pre-load on the sway bar and could impact your handling if you stick with the stock sway bar links and lowered height.
          https://groundcontrolstore.com/collections/e46-m3-sway-bars/products/bmw-front-sway-bar-end-link-adjustable-pair
            Just know that heim joint sway links can be noisy. So if that doesn't bother you, go for it! I have them on my Z3 Coupe and will be switching them out for some adjustable ball joint style sway links to quiet things down. Just an FYI
              He won’t hear it over the Ed Sheeran he listens to
              • pynaclP
                pynaclP
                pynacl
                Honestly fairly new to the intricacies of suspension tuning so I reached out to TC Kline and got this response
                someone said:
                Just so you know our take on the situation... We have never put adjustable end links on any of our track cars(specifically our E90 M3 track car). If your car is set to the appropriate ride height (equal on the left and right side) there is no need for adjustable end links. The only time you will put 'pre-load' on the sway bar is when the left and right ride heights are not set equal (and there is no reason they should be unequal).
                I could see how adjustable links could come into play with corner balancing, but I've also read BMWs are pretty well balanced from the factory. I'll definitely do my best to test out all this info and report back though!
                • pynaclP
                  pynaclP
                  pynacl
                  Waiting on some suspension parts yet so I started the header install. Have to say that this is MUCH harder than the downpipe install on my F30. Since there's such limited room to work I had to remove the coolant reservoir tank, turkey basting out all the coolant so I didn't make an absolute disaster. Still probably spilled 1/2 gallon on the floor that came out the other end though lol. Even with this and the heat shielding out of the way, access to the 18 nuts is still pretty grueling. Just kept swapping out swivel, wobble and regular extensions, as it seems like each nut requires a different approach. After a few hours I finally got the old set out, woohoo! Still waiting on new gaskets and nuts, but should be here in about a week or so and I can get the new headers installed.
                    If that's what they say then I'd go with that!  I know when KW sent me my coilovers they came with a new set of shorter sway bar end links to avoid the pre-loading and I know others that do it as well.  I'm sure it's like everything else handling related where it's heavily opinion based on independent results.  If it works it works!
                      In the future I would suggest invest in an Airlift. You can suck all the coolant out of the system without spilling much. As far as getting to the manifold bolts, I feel your pain. lol
                      • pynaclP
                        pynaclP
                        pynacl
                        Replaced the CPV o-ring with a viton one while I was waiting on parts to finish the headers. It wasn’t leaking, but seems like a PITA to replace later. While in there I noticed the cam position sensor is leaking a bit. Death by 1000 gaskets…
                        8C79A372-36E0-41C4-B2E3-934173DAA2B0.jpeg01F3D39C-7C31-48FE-AC7F-D23E575DA9DC.jpeg86B78F57-7593-4308-A91C-B1B47E5DC4F8.jpeg
                          Dont let the GF know how much you have spent in the last few months.
                          • pynaclP
                            pynaclP
                            pynacl
                            Got the ports all cleaned, fresh gaskets, fresh hardware and the headers bolted up. Now just have to sort through the O2 sensor wiring because I’m an idiot and didn’t mark them. I'll have to fire up Ecuworx too and code out the downstream O2 sensor and secondary air pump so we don't get a CEL.
                            • pynaclP
                              pynaclP
                              pynacl
                              Since I went with catless headers, I decided to delete the whole secondary air injection system since I don't think it serves any purpose besides helping in the cat heating sequence (saves 4lbs too). Got this nifty little aluminum block off plate from Achilles Motorsports that looks pretty sweet, even though it will never be seen.
                              • pynaclP
                                pynaclP
                                pynacl
                                Since it was looking pretty tired out, I decided to replace the fan blades and fan clutch with a new Mahle one. Better preventatively than to see it grenade and take out the hood or radiator. Personally prefer this setup to an electric fan swap, because it just works. No overheating in hot weather while stopped, no blasting heat in the middle of summer or messing with fan shrouds etc. Easy enough to service so I’ll keep it.
                                • pynaclP
                                  pynaclP
                                  pynacl
                                  Also got around to fixing some small oil leaks. One coming from the exhaust side camshaft position sensor o-ring and the other the oil return pipe crush washers.
                                  D987DCF1-B502-4FA2-9DE7-FA9D80030999.jpeg099DB5D9-70D6-4B45-B18C-9EF7C3A258D0.jpeg0F743750-1914-4546-A2D3-93B4EC8862A5.jpeg351FF038-1127-4A71-B905-A5CC68875DB0.jpegAA75009D-9CBA-4B36-B3B9-3B434E750CD4.jpeg
                                    Why do I feel like this is a jab at me.
                                    • pynaclP
                                      pynaclP
                                      pynacl
                                      Lol! The moment I saw you in 90 degree traffic with the heat blowing and your shirt off I said, that doesn’t look fun.
                                        Is there not a good efan solution for those cars? Is it a space constraint?
                                        • pynaclP
                                          pynaclP
                                          pynacl
                                          Great question. Most run the 16" SPAL like the one in this BuildJournal thread: https://thebuildjournal.com/diy/n15-design-e46-m3-electric-fan-mount-diy/. It seems to cover as much as the clutch fan, but maybe it has to do with the fact it deletes the aux fan and the clutch fan? Not entirely sure.
