Non-BMW Stuff on a BMW Forum
    Man, I want to do another engine bay like that again, I appreciate you bringing up the photos again!
    I believe I used a wire wheel to strip the seam sealer off. I used Eastwood seam sealer with lacquer thinner on my finger to smooth the new seam sealer.
    Very therapeutic activity when it goes properly haha
    Do you recall how removing the seam sealer went? Was it a shit show? Did gum up or with the wire wheel did it come off pretty easily?
    Your engine bay was much cleaner and, I'm assuming because of the swap, has much less stuff in it than mine does. So I'm not even sure if the extra work to remove the seam sealer would be noticeable.
      A wire wheel on a grinder will take off seam sealer. On a drill it probably won't do much. Wear a full face shield. Also check clothing for little bits of wire that will stab you later. Can't say much about painting over it. Good so far, but my car doesn't get used...
      Seam sealer as a structural component is an interesting thought. I suspect that the flexibility of the seam sealer would allow the two panels to move slightly relative to each other before it resisted. Since the panels are spot-welded together, they won't be able to move, so the force would be transferred through the weld without the seam sealer doing much. Could be wrong, but that's the best I got.
        After taking off the intake yesterday I noticed I still had some oil getting into the throttle body...
        Figured that out.
          I think my RMS is totally fine. Looks like the leak from the bottom is coming from transmission. All of the lower transmission bolts smelled like transmission fluid (disgusting). I have ATF PTSD from a 240 I bought from @The Full Banana a long time ago that had a leaking transmission pan gasket and it took several attempts to get it sealed and that meant laying in ATF on a cold parking garage floor each time. It was awful.
          Anyways - the area behind the clutch was totally dry, but the transmission was soaked and it looks like there's a little trail where fluid looks like it's leaking from whatever this thing is:
          Edit: After looking at realOEM that circle thing does not appear to be any type of seal. It must be leaking down from the input shaft seal and making it look like that's where it's leaking from.
          Behind the clutch is completely dry:
            Hi everyone. One question (for now):
            • When I removed the master cylinder it pulled the push rod out from the brake booster. I looked at it last night and it doesn't look like it's something that can be easily (if at all) reinstalled. The OE brake booster looks to be unavailable. I know people modify or install other brake boosters for engine swaps. Can anyone recommend one that's affordable and would be close to an OE replacement and hopefully have minimal modifications?
            It looks like the 924/944 booster is the go to for most engine swaps. Is there any reason you couldn't use this with the stock m20?
              Talked to a friend who shaved their bay and their advice was fire and a scraper to get excess sealer off and then a wire wheel. Took about a half hour to do this much. It’s a pretty efficient approach. Dirty as hell, but it should move along.
              And can anyone identify this connector? I’m pretty confident I’ve never had it plugged into something. Located somewhere behind the front left corner of the lower valance.
                Given the location here’s a guess. There is an outside temp sensor that fits in the e30 325i/s drivers side plastic brake duct, the sensor plugs into a connector with wires that feed info to the onboard computer on your dash.
                  My car didn't come with brake ducts or a ambient temp sensor anywhere so I would have never guessed that! Thank you!
                    stock booster still available
                    https://www.pelicanparts.com/More_Info/34331157416.htm?pn=34-33-1-157-416-INT
                    i got the part #34331157416 from Real OEM based on a 1990 325i coupe build date 01/90
                    https://www.realoem.com/bmw/enUS/showparts?id=1113-USA-01-1990-E30-BMW-325i&diagId=34_0703
                      I should have clarified - when I said unavailable, I meant out of stock or backordered everywhere I looked. FCP has the 944 booster in stock and will pair that with the e32 7 series master cylinder which is a supposed upgrade for the e30 (and it's cheaper than the e30 MC).
                        i think I have an e21 booster on my car @B C could probably confirm lol. Also have a 7 series master
                          Yes, e21 booster.
                            Rust fixed, sanded, seam sealed.
                            Put this together for painting in the garage without getting overspray everywhere. It worked as well as it could have. In between coats I was able to hang out in the garage and watch the packer game. This morning there was a strong paint smell, but no paint dust on anything. It was a more enjoyable experience compared to painting the car.
                            Bought this on Amazon for ventilation and it worked really, really well.
                            And primed!
                            Wait a couple days and then I can wet sand it and spray color. I'll dismantle the paint booth and set it up at a later time to spray the spare hood and hood hinge thing.
                            This also happened to me. Ordered a new fuel vent pipe that goes from the charcoal canister back to the gas tank and the first one arrived bent in half (on the right) to fit in the box. 😆 They ordered and sent me a new one right away. Somebody actually thought that was an appropriate action to take to make it fit in a box.
                              That's pretty funny/sad. I expect there was a shipping department "discussion"...
                                I'm starting to go through the engine bay wiring harness from the fuse box, and there's some stuff I want to get rid of. For example this is I believe a brake pad wear sensor connector? IDK, it's never been connected to anything. But here is where it splices into the harness. Can I cut it, put a small piece of heat shrink over the individual wire ends and then another piece over the two and tuck them back into the harness?
                                Similar question for other things - the ABS stuff that I'm no longer using. Can I cut the wires, cover the ends and tuck them away? Leave the wires in the bundle in case at some point in the future, after I'm long dead, my daughters are like, "Dad sure was a huge dum dum poopy face, let's put the ABS back in the car!".
                                And a pic of the bay all painted and polished! Not perfect by any means. I believe I did not give the pre-paint prep spray enough time to evaporate and the first coat had some blemishes. But I said fuck it I'm going to gob the paint on and cover it up. Turned out fine.
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Don’t cut the wires. Presidential Debate Dont GIF by Election 2016
                                  nice progress on the bay!
                                    I’m sorry. I cut the wires.
                                    I never realized how much of this harness was for the ABS.
                                      Cut the ABS harness on the engine side and pulled it out through the firewall inside the car. A few wires left that go into somewhere else:
                                      red/yellow on engine side. appears to go to the ABS relay. however, it didn't go through the firewall and looks like it went into the twist lock connector that engine harness connects to.
                                      blue wire inside the car. wire diagrams says it makes it way to the alternator.
                                      green/red wire inside the car. power from the ignition.
                                      Red wire on the engine side. Diagram says it goes to the relay, but it seems like it goes straight to the power junction block where the main battery lead comes into the engine bay.
                                      The good news is that it seems like none of the ABS wiring is integrated into anything else. Other than receiving power from the car, it stands on its own. So these wires will likely get clipped and then heat shrinked over the ends.
                                        Found what the red/yellow wire is going to the C101 connector. Just another power supply for the ABS.
                                        Which is good news because that was really the only one I was concerned about.
                                          Non car related. Scored some free cabinets from a house my parents' are renovating. Just need to build an exhaust hood and I'll have a place to keep all my brewing stuff and start doing that again! My wife got me the Northern Brewer electric brew kettle to make indoor brewing possible.
