Non-BMW Stuff on a BMW Forum
    Brief update:
    Still working on the new power leads. After receiving the incorrect terminals and messing up my first solder loaded terminal, I'm hoping to have better luck tonight so I can finish those. But I have done:
    New AC condenser more appropriate for r134.
    Mocked up the power distribution blocks.
    Swapped out the larger subwoofer/box for an under-seat subwoofer that I mounted on the backside of the rear seat. Now I have the full trunk.
    Replaced the super sagging muffler hangers.
    Installed new oem coolant temp sensors and thermostat.
    What's left:
    • Power leads
    • Grounds
    • Oil change
    • Coolant fill
    • AC charge
    • Replace soft fuel hoses in engine compartment
    The Recaro saga may soon be coming to and end. After the owner of shop only offered to refund me $300 or attempt to fix them again, I filed a dispute with my bank/Visa. Once that process was started and he was notified he offered to purchase the seats from me for $1500. I said he could purchase them for $1800. While I would love to save them, I think the grim reality is that it will cost me MUCH more than $1,800 to ever have those look like they should. While I recovered the cost of the front seats, I'm out the cost of the rear seats. Sadly this was an expensive life lesson and if there's a next time I know who I won't use and I know who I will use.
      Lifts putting in work!! 👍
        Looks good! I like how that one is flush mount and is out of the way when you're not using it.
          Thanks. I had the concrete guys recess a pit in the floor for it. The arms still sit above the floor for easier swing out, so not fully flush. But definitely better than when I had it just siting on garage floor.
            Good call! I was pretty reluctant on the maxjax given that I didn't want to lose quick access to the garage, but with it on the lift I can still get in and out the door OK. And they are much easier to move out of the way than I thought they were going to be.
            But on the car - it's back on the ground. I have 12v at both power leads in the engine bay. It started right up (obviously not the first time because the fuel pump was repressurizing the system). But the following starts it cranked really strong and started up with much healthier sound than it ever has.
            New ground and power wires:
            Solder loaded battery terminals worked amazing.
            And the new fusible link.
            I also replaced the fuel lines because the ones that were in there had some cracking along the tops of the hoses. I didn't know there was fuel hose and then fuel injector hose. So I got proper hose this time.
            Anyone know what this blue connector is? It's behind the kick panel in the front passenger, it was unplugged when I opened everything up.
              Drove it to my evening meeting at work on Tuesday and I got there and back without it dying!
              BUT, it developed a vibration that was very clearly coming from the tunnel down the car. Giubo was good. Everything was tight. The CSB was replaced in the last couple years. So I assumed it had to be the driveshaft. Once removed, it was very obvious the rear joint was garbage. Had "flat" spots and did not rotate smoothly. Over nighted one from FCP. Should be here tomorrow!
                Overnight parts from Japan?
                I wouldn't have thought to check them for driveshafts, but their pricing isn't bad at all.
                  It seems most of the european car sites use the Powertrain brand of rebuilt driveshafts - Pelican, FCP, Partsgeek, Autohaus AZ, etc. Pelican had it in stock and their overnight was similar to FCP, FCP was one business day out to ship it, and I have a 5%/10% off code that I can use on all my orders at FCP so they were a little bit cheaper.
                  BUT NOW, I talked to FCP this morning and it's shipping out today instead of  yesterday like it was supposed to, which means it MIGHT get here tomorrow but more likely Monday. And I leave early Wednesday morning. Not what I wanted to be doing right before I was supposed to leave.
                    Car made it to Utah and back without issue other than a vibration from the rear at 80mph which I suspect to be an axle or maybe a wheel bearing. More pictures and thoughts later.
                      Alright. So the rally was pretty awesome. I drove out to Denver the first day, and then to Mexican Hat, Utah. I did some exploring with the time I had while I waited for my friend to get there with his RS3 (in the pictures). The first day was driving from Mexican Hat to Escalante. The scenery was mostly what's in the pictures. We did the gravel switchback up one of the rock formations. The day ended in Escalante with eating at a small restaurant and a gathering at a vacant parking lot.
                      The next day we drove from Escalante to Mount Pleasant and the day ended at the Basin Drive-In theater where the Overcrest guys put together a short movie recognizing automotive films. The second day of driving was more long and winding roads outside of the desert/rocky area. Both days were gorgeous and it was amazing how much the scenery changed. I had no complaints at all. I ended up driving straight home leaving 4am on Sunday morning and getting home at 6am on Monday. The car did about 3850 miles with virtually no issues. I have a vibration over 80 and a rattle under the car which I think is the exhaust rubbing on something. Very happy with it though!
                        I LOVE those seats.
                        Looks like it was an awesome time!
                          Agreed the seats are 🔥🔥. That drive in looks amazing.
                            I LOVE those seats.
                            Thank you! It was fantastic. So much of scenery there makes everything else in life feel so insignificant. Not to sound overly cheesy, but I'm standing there looking at the landscape and can't help but wonder why I let so much dumb stuff bother and stress me out. Idk. It's nice to get away sometimes and clear your head and realize what your priorities actually are.
                            Thanks! The drive was super amazing. The cars we were driving with were amazing. It was predominantly aircooled 911s. There was one other e30 there - from Wisconsin actually. I get 911 fever quite frequently and these trips always give me a new appreciation for the e30. I had with me a suitcase, a bin of fluids and parts, a large tool bag, cooler, camera, computer, an aluminum jack and jackstands, detailing stuff, and a few other miscellaneous things. And it all fit in the trunk. You would never know I drove across the country looking in the car. But yet it the car did everything the 911's did. And at the end of the day, I rolled up the windows, turned on the AC and drove home listening to an audio book. It really is an amazing car.
                            I would like to find a way to make it quieter on the highway though. All of the sound deadening that was on the firewall deteriorated and I removed it. I did sound-deadening mat on the floor - but I know that's not so much noise but for vibrations.
                              wow great photos!
                                by nature, that's gonna be a tough one. Lots of glass, not lots of mass. basically all you can do is sound deaden behind everything. inside the door skins, under the headliner, floor pans, trans tunnel, etc.
                                  Yeah. And I understand that. I've done the whole floor inside - but I haven't done the front doors yet. Which I've read make a pretty noticeable difference.
                                  And for the record - the skid plate came in useful one time. I ran over some dead animal on the highway and it nailed the plate pretty hard. I'm not sure what it was, looked like maybe a small coyote - not a rabbit, opossum, racoon, etc.
                                    Put the car on the lift to change the oil and figure out an exhaust vibration and apparently my water pump is leaking just enough that it doesn't drip; rather the coolant turns to goo. There's even a coolant stalagmite on the bottom of the pump. lol. Anyone see that before?
                                      Yep, sounds like a solid one to ignore lol
                                        Haha. I was planning on ignoring it for the rest of the year - except once I got the skid plate off I could see it was coming from the weep hole on the water pump and not the gasket.
                                          Parked.
                                          I'm starting to put together my winter plans. Here's what I HAVE to do:
                                          • Replace water pump.
                                          • Replace RMS.
                                          • Get rid of the garbage Garagistic solid gear selector rod joint.
                                          • Replace rear DS axle and wheel bearing to get rid of the vibration.
                                          Here's what I WANT to do:
                                          • Rebuilding the HVAC box. One of the recirc flaps is broken from the rod. Confirmed last night that both motors work and the fan turns on to low speed when the button is pressed. I also would like to replace all of the foam seals.
                                          And here's what I've been contemplating. I have to take the front of the engine apart to do the water pump. I have to take the transmission off to do the RMS. By doing those two things, half of the work is done to just remove the engine/trans. And now I have a lift and could easily drop the engine out the from the bottom. With the engine out there are some places with surface rust that I would like to address within the bay. And in general, the engine bay is poor shape. I would love to clean it up entirely - not talking about a full shave here - just a clean up and spray.
                                          A question about a general clean up of the engine bay. I wouldn't be going for full a fully shaved bay, but I would take a grinder to it to clean up the surface. Are there any negative affects that would come from smoothing out the seam sealer to an extent that would allow me to  effectively prep the surface for paint?
