  4. 2002 E46 M3 // Build Thread
167 Posts 17 Posters 3.2k Views 1 Watching
  • pynaclP
    pynaclP
    pynacl
    Titan trim sucks. Such cheap build quality it shouldn't have even been an option on these cars. Mine was peeling/bubbling on every panel like you see in the photo below. I took all the pieces out, sanded them down with 200/600 grit, then primered and re-painted. Took me two tries because for whatever reason, if you don't use primer, paint has a strange reaction to the bare material and it'll bubble instantly. I ended up using Dupli-color "Storm Gray", which I believe is a GM color. Closest match I could and honestly would be hard to tell the difference. Seems like factory has a bit more warmer hue to it, but even side-by-side it's really close. Also new trim clip pins are $5 a pop!?
    Edit: I want aluminum trim
      Looks good!
        It does look good but I like the aluminum trim as well
        • pynaclP
          pynaclP
          pynacl
          Took @B C advice and downloaded ECUWorx and modified my M3 a bit this afternoon. Most notably disabled top speed limiter, enabled shift lights (flashes all segments at 7.5k RPM) and re-calibrated the warmup light sequence to more reasonable temps that doesn't promote WOT at 140F on those poor RBs. Below is a before / after on what I changed. I wrote up a blog post on how to use the software step by step here if anyone is interested: https://www.pynacl.com/blog/tune-your-e46-m3-yourself. Thanks Brian for your work in discovering and learning to use this software!
          Stock:
          Final:
          • pynaclP
            pynaclP
            pynacl
            Was trying to get an ECS order high enough to get free shipping, so decided to scoop an LED interior kit. Figured this would be a tasteful upgrade in the lighting department
            • pynaclP
              pynaclP
              pynacl
              Finally the day has come! Pulled the trigger on tackling the subframe reinforcement as preventative maintenance. This is a project far beyond my skill level, so thank you to Austin Nelson for all his help. Decided I might as well replace just about everything nearby while the subframe is out. Here's a breakdown of what is getting replaced:
              - TMS Subframe reinforcement plates
              - Revshift 80A subframe bushings
              - Revshift 80A differential bushings
              - TMS sealed monoball RTABs
              - OE differential axle seals
              - OE differential input shaft seal
              - OE differential center support / bearing
              - OE guibo
              So far most of the rear end has been removed, making way for gasket/bushing/seal replacement. Still have yet to grind down the factory undercoating to get a good idea of current hairline cracks. A quick shot of the subframe post looks solid though, so fingers crossed everything looks great underneath the undercoating!
              • pynaclP
                pynaclP
                pynacl
                Subframe and diff support sanded, treated, re-finished and revshift bushings installed!
                • pynaclP
                  pynaclP
                  pynacl
                  Plates are welded in! Still have to wire wheel, scuff, primer and seal it off. Also differential cleaned up pretty nicely. Installing new axle and input shaft seals and ready to be re-installed
                  • pynaclP
                    pynaclP
                    pynacl
                    Also forgot I got these finally. Been back ordered for like 2 years, feel like I just won the lottery
                    • pynaclP
                      pynaclP
                      pynacl
                      Finally installed the Rogue Engineering stainless clutch line I've had on the shelf for months. Mainly did this to remove the clutch delay valve for a more responsive clutch feel. Job was messy as all hell but a power bleeder made the bleeding process a breeze. Took it for a test drive and it definitely feels more responsive. Not a night and day difference per say, but totally worth it. Frig I love this car
                      • pynaclP
                        pynaclP
                        pynacl
                        Where might a great condition cinnamon interior be hiding? In a rebuilt title, dumpster of an M3 of course! Bought this 110k Imola on cinnamon E46 M3 yesterday to be a donor car. I'm swapping the cinnamon interior into my Steel Gray M3, then selling the car for a break even price to another for the motor/trans. Free cinnamon interior 😁
                        Also found the car has a sweet Eisenmann exhaust setup. I'm donating it to @Rekpoint for all his help dismantling the interior and helping with the swap, everybody wins!
                          Also found the car has a sweet Eismann exhaust setup. I'm donating it to @Rekpoint for all his help dismantling the interior and helping with the swap, everybody wins!
                          Let it be known we were able to install everything besides the front door panels in just about an hour. Pretty fast...
                            Well that's pretty awesome
                            • pynaclP
                              pynaclP
                              pynacl
                              The seats were REAL shiny. I tried hitting them with some Lexol leather cleaner and a microfiber and it didn't put a dent in it. I know it's a sin, but I VERY carefully used a magic eraser (with zero pressure applied) and Adam's interior detail as lubricant. I was careful to only buff off the oils/grease and not damage the protective "clear coat" layer. Hard to tell from photos, but they look night and day different.
                              edit: still need to swap the front door cards, just haven't had time yet
                              Before:
                              After:
                                Looks great, its amusing that shiny seats look bad, but yet here we are!
                                The car you got them from was a sweet color combo!
                                • pynaclP
                                  pynaclP
                                  pynacl
                                  Haha right? We want everything else shiny, except for those!
                                  Definitely agree the donor was a sweet spec. Unfortunately it has rear trunk floor and major quarter panel damage from the wreck so it’s just not worth saving. Although it was “rebuilt”, and you can’t tell from the outside, the quarter panel has major bondo and the trunk floor has signs it’s folded in before. Might make a cool drift car or something!
                                  • pynaclP
                                    pynaclP
                                    pynacl
                                    Saved the door cards for last since they were going to be the most involved. The previous owner cut the door cards for some janky ass aftermarket speakers, and used what looks like wood glue and  Joann Fabrics clearance shelf felt to put it back together. So it wasn't going to be as simple as swapping door cards. The good news is the damage was exclusively the door card, and not the cinnamon insert. I was able to use a 1/2" drill to drill out the 25 or so plastic welds holding the pieces together and get the cinnamon off in perfect shape. Now I just have to do this a few more times and swap all the panels, then use some very short self tappers/glue to re-secure them in my good condition door cards.
                                    • i_love_carsI
                                      i_love_carsI
                                      i_love_cars
                                      did you get rid of the donor car yet?
                                      If not, do you think the person buying it would be ok if I took a couple bits? My imola M3 needs a new passenger rocker panel and side mirror caps.
                                      2007 Z4MR
                                      2003 E39 M5
                                      2002 E46 M3
                                      2021 X5 40i
                                      • pynaclP
                                        pynaclP
                                        pynacl
                                        I didn’t get rid of it yet, but I’ll have to check the condition of those in the morning when it’s light out. I honestly can’t remember if those are in good shape or not
                                        • pynaclP
                                          pynaclP
                                          pynacl
                                          Finished drilling out like a million plastic rivet heads and reassembled the inserts into my door cards! Probably not the best solution but I resecured them using short self tappers (3/4”) and fender washers (20mm). Fit and finish is perfect, super jazzed how the swap turned out.
