  4. Helmut the e21
Helmut the e21
65 Posts 12 Posters 1.5k Views 1 Watching
  • retoropakR
    retoropakR
    retoropak
    I figured out my swaybar situation. I got a set of e30 ST bars 22/19mm front fits pretty good. I will link the front to the strut housings just like e36m3.
    Helmut
    Helmut
    I started chopping the oil pan and should weld something up this or next week.
    Helmut
    I got a new torch: ck tl26  I might need the whole 200 amps to do 1/4” aluminum for the oil pan. The torch that came with my thermal arc is ok but the cables are way to heavy and stiff. New ck feels much better. Its still air cooled. I might get the water cooler at some point.
    Helmut
    I also ordered the ECU. It is Maxx ECU race unit. https://www.maxxecu.com/products/race
    It has everything that I will need and more.
    What is your opinion on the lcd dashes? I would like to run a dash instead of bazillion of gauges. I would like to have the ability to see timing, e85 concentration in addition to boost, o2, oil pressure  and whatever else I might need at the moment. Having al the information in one area also helps. You can also program whatever alarms you need and it will pull everything from ECU via can
    I like the aim dashes but the only option to have 10" dash is to go with their PDM unit. Haltech is not bad, there are couple other that are not bad but not sure about the support. ECU mater ADU is very nice but quite expensive.
    • ASTROCHIMPA
      ASTROCHIMPA
      ASTROCHIMP
      Not sure how much help this will be. But I found this today while browsing around bimmerpost looking at digital gauge options for my e90. No clue how good they are and the website has a really scammy name. But it claims to mate up to the maxx ecu.https://customdigitalgauges.com/products/race-cluster
      • retoropakR
        retoropakR
        retoropak
        I’ve seen it before. Their universal dash that talks to maxx ecu does not have bmw graphics but i am sure they could load it.
        I am not sure about the support tho.
        I like aim’s flexibiity with CAN. You can define your own can protocols. Also aim has multiple pages that can be swapped. What i dont like about most dashes is that you cant use your own graphics . Most of em have predefined graphics and will allow only changes to some parts of the graphic and maybe a font size and color.
        Maxx Ecu has built in bluetooth and they have app for apple and android. I dont know how responsive the gauges run on a tablet would be.
          Wheels turned out great, what paint did you use? I wish the style 7’s came in 16” as well.
            Would run these on my car if they did.
            • retoropakR
              retoropakR
              retoropak
              Duplicolor cheapo laquer from Oraily it comes in quart size cans.
              I sprayed that with smaller touchup gun 1.0 tip. Just stirred it and shot it.
              i was too cheap to buy a clear to go with it so i followed with rattlecan clear. I dont expect it to last.
               I will run em just for one season to see if i havent screwd something up  with suspension. If the car survives first season i will get some 16s with some beefier tires.
              I would love to have em in 16x7 and 16x8 or even 8/9”.
              • retoropakR
                retoropakR
                retoropak
                I did some sway bar fitting tonight.
                Where do i connect the links?Control arm as in e30 or strut tubes as in e36m3? Any pros or cones to either setup?
                Helmut
                I also got some goodies
                Helmut
                  Helmut
                  id go for strut tube. I’ve ran both setups. When I was setup to control arm, I would bend the adjustable endlinks, they would bind, the bar wasn’t in a great position either because the adjustable endlinks were so short.
                  Currently I’m mounted to strut tube, way more adjustment to get the bar in a better spot, links don’t bind, etc
                  • retoropakR
                    retoropakR
                    retoropak
                    Thank you sir.
                    id go for strut tube.....,
                    I whipped front bar mount today. Temporarily mounted the bar and the control arm link is a no go. Its too short and at weird angle. I will link it to the strut tubes.
                    HelmutHelmut
                    I also did one of the rear diff mounts and started to fit the rear bar. Looks like the rear will fit quite nicely.
                    Helmut
                    Helmut
                    Helmut
                    • retoropakR
                      retoropakR
                      retoropak
                      I just welded the m42 vert mount oil pan. I hope it doesn't leak. I will fill it with water once it cools down and leave overnight.
                      Helmut
                      • retoropakR
                        retoropakR
                        retoropak
                        So i water tested it and found 3 pinholes. Welded em shut and no more leaks. I got the drain plug bung and 10AN for turbo drain ordered will weld em next. Also the oil pickup will need some slight chopping and welding to fit correctly.
                        Do you think I should baffle the pan since there is no sump for the oil pickup?
                        Don't mind the welds, looks like shit but will hold. For my excuse last time I welded aluminum was 2 or 3 years ago.
                        Helmut
                        I ordered poly rear sway bar bushings and mounts and stock diff bushings. I should have the suspension ready for paint sometime next week.
                        I might even drop the motor in this month.
                        Depending how bad the exhaust situation is going to be I might skip the headers and whole NA nonsense and go for turbo manifold right away. Stock m42 should be able to put 200-250 without much problem.
                          I would think baffles are a good idea
                          • retoropakR
                            retoropakR
                            retoropak
                            Last week I test fitted the motor with the new pan. It looked cozy in there almost too ”sr20” looking when it sits straight.
                            Helmut
                            Helmut
                            Two feet clarance in front of the motor for that 4” thick  intercooler or maybe ac condeser🧐
                            Helmut
                            • retoropakR
                              retoropakR
                              retoropak
                              I finished the front suspension. Sway bar  links are done. I painted the front subframe, strut housings and spindles.
                              Suspensions
                              Suspensions
                              Suspensions
                              Suspensions
                              I’ll finish welding rear subframe adjusters today and paint the rear tomorrow.
                              Next will be the engine bay prep and paint. I will also need to paint rear wheel wells.
                              After that I can start fitting the engine.
                              I got a mixed feeling about the vert mount. It will give me much needed clearance on the passenger side but will put the shifter 2-3” to the left.
                              I can chop and rotate bellhousing but that will be not ideal in case i will ever have to replace the gearbox.
                                Good lookin' hardware.
                                • retoropakR
                                  retoropakR
                                  retoropak
                                  New hubs and dust shields. I also have a set of reman calipers and brackets. 286mm brakes will do for now. I will look into some 4 pot wildwoods if the stockers will end up not sufficient.
                                  Helmut
                                  Freshly painted rear subframe
                                  Helmut
                                  I really like that SPI epoxy primer. Works great
                                  And the part that I did not enjoy at all. Hate the prep work.
                                  I need to wait for the radiator (e36 318i) to get the brackets fabbed and welded before I paint.
                                  I will hit it with two coats of epoxy followed by couple coats of single stage urethane.
                                  Helmut
                                  Helmut
                                  • retoropakR
                                    retoropakR
                                    retoropak
                                    I did another test fit of the m42 last weekend and the gearbox will not clear the tunnel at least not tilted 30 degrees.
                                    So in order to vert mount the m42 i will have to cut and shut the transmission.
                                    The plan is to use ordinary angle grinder mounted on a jig/stand that will move/slide on the flat table where the transmission will be bolted. I don't need a lot of precision at this point. I will need a gap between the two pieces to weld it properly anyway.
                                    What is important is to have the transmission perfectly centered/ coaxial with the crankshaft and to do that i am going to use the throwout bearing guide tube that bolts to the gearbox
                                    Below is the picture of the guide tube with a bit bigger tube slipped over it
                                    the larger tube has perfect ID (1.5”) to fit snugly over the guide tube and 60.5mm OD to fit the main bearings. I will weld it together and use it to center the transmission.
                                    Then a pass or two on the outside and another one or two from the inside should hold the bellhousing without much problem.
                                    Stay tuned. I should have it bolted in the car soon.
                                    Zf jig
                                    Zf jig
                                    • retoropakR
                                      retoropakR
                                      retoropak
                                      It felt wierd for a moment to chop perfectly good zf320 but oh well got to do what you got to do.
                                      This is how much it will rotate.
                                      Chop chop
                                      A little angle grinder holder. It is also nice to have a flat table.
                                      Chop chop
                                      Chop chop
                                      chop chop
                                      Chop chop
                                      And rotated.
                                      Chop chop
                                      Now i need to pull my m42 block from e21 bolt the transmission and weld the bellhousing.
                                      • retoropakR
                                        retoropakR
                                        retoropak
                                        Transmission is welded on the outside. I will finish welding the inside tomorrow
                                        Bellhousing bolted to the block
                                        Gearbox
                                        Magic wand
                                        Gearbox
                                        All bolted together
                                        Gearbox
                                        And welded
                                        Gearbox
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          You are a crazy man, Wojtek! Looking good
