<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Helmut the e21]]></title><description><![CDATA[<p dir="auto">A while back Helmut was sporting a stock m10 with the turbo big enough to disintegrate that poor motor. After two years of trashing this setup my turbo manifold decided to crack every weld and reject the turbo flange. </p>
<p dir="auto"><a href="https://flic.kr/p/2kwFS1p" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886743607_4e0f919e47_b.jpg" alt="508867436074e0f919e47b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFS1p" rel="nofollow ugc">Helmut</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><a href="https://flic.kr/p/2kwFjx3" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886637736_366c97219c_b.jpg" alt="50886637736366c97219cb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFjx3" rel="nofollow ugc">Helmut</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>, on Flickr</p>
<p dir="auto"><a href="https://flic.kr/p/2kwFS5c" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886743827_8755fc6baf_b.jpg" alt="508867438278755fc6bafb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFS5c" rel="nofollow ugc">Helmut</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto">I decided to get rid of the m10 and switch to more modern unit. I acquired the early m42 with the plan to boost it. Stock 1.8 is nice if you like it to spool at 5k rpm. </p>
<p dir="auto">Since I got family in Poland, and Poland is Europe's junkyard, there are plenty of e36,e34 and e39  m47 diesels sold for parts. I found two diesel cranks and have them shipped to the States.</p>
<p dir="auto">With M47 crank and enough bore I will have close to 2.1L. It should spool nicely especially with some efr (if budget allows)</p>
<p dir="auto"><a href="https://flic.kr/p/2isGsXo" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49528881652_1f402aa446_b.jpg" alt="495288816521f402aa446b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2isGsXo" rel="nofollow ugc">M47 diesel crank</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"> To use it in m42 the crank nose has to be turned to match the m42 chain sprocket ID. Also additional keyway needs to be cut.  M47s use same bearings as m42/m52s. I plan to use the 360 thrust bearing. <strong>Question: What is your opinion on the 360 degree oiling grooves for high (er) rev applications (8-8.5k rpm)?</strong> </p>
<p dir="auto"><a href="https://flic.kr/p/2isGsW6" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49528881577_b507ee19f3_b.jpg" alt="49528881577b507ee19f3b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2isGsW6" rel="nofollow ugc">M47 diesel crank</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto">With power goals that I got in my mind the whole stock drivetrain was not up to the task.</p>
<p dir="auto">I had the e28 subframe modded to fit e21 from my previous project. I had to decide  what to do with the front end. </p>
<p dir="auto">There were two options: e21 front with e12 hubs to make it 5x120 or the more entertaining way using the whole e36 front end. </p>
<p dir="auto"><strong>Front Subframe</strong></p>
<p dir="auto">I roughly chopped 3" of the middle of the front e36 subframe and welded it back together. I had to modify frme rails in order to bolt the new subframe in. </p>
<p dir="auto">Stock vs e36</p>
<p dir="auto"><a href="https://flic.kr/p/2j6oc8v" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49944026751_f5f3e104cc_b.jpg" alt="49944026751f5f3e104ccb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2j6oc8v" rel="nofollow ugc">E36 modified subframe</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a></p>
<p dir="auto">cut</p>
<p dir="auto"><a href="https://flic.kr/p/2j6pGeR" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49944319787_09940ac0d8_b.jpg" alt="4994431978709940ac0d8b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2j6pGeR" rel="nofollow ugc">E36 modified subframe</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto">Jig</p>
<p dir="auto"><a href="https://flic.kr/p/2j6oc4N" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49944026536_85d5b719db_b.jpg" alt="4994402653685d5b719dbb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2j6oc4N" rel="nofollow ugc">E36 modified subframe</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>, </p>
<p dir="auto">weld the crap out of it</p>
<p dir="auto"><a href="https://flic.kr/p/2j6kAm2" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49943519513_c089a2f519_b.jpg" alt="49943519513c089a2f519b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2j6kAm2" rel="nofollow ugc">E36 modified subframe</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><strong>Frame rails</strong></p>
<p dir="auto">I used panzer angles and tube to make it bombproof. I guess anything over 1/8" is overkill but oh well. </p>
<p dir="auto"><a href="https://flic.kr/p/2j7XmCn" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49961813893_caa439047c_b.jpg" alt="49961813893caa439047cb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2j7XmCn" rel="nofollow ugc">Untitled</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><a href="https://flic.kr/p/2j7XmE1" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/49961813988_ed5cd14ec0_b.jpg" alt="49961813988ed5cd14ec0b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2j7XmE1" rel="nofollow ugc">Untitled</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><a href="https://flic.kr/p/2kwFdiu" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886616766_7c61267cd9_b.jpg" alt="508866167667c61267cd9b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFdiu" rel="nofollow ugc">Front suspension</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>, </p>
<p dir="auto"><strong>Control arm Mounts</strong></p>
<p dir="auto">I decided to use the wider e46 arms to match the increased rear track width. SLR adjustable lollipops were used to center the wheel.</p>
<p dir="auto"><a href="https://flic.kr/p/2kwFdie" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886616751_a455de2872_b.jpg" alt="50886616751a455de2872b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFdie" rel="nofollow ugc">Front suspension</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><a href="https://flic.kr/p/2ksBcP6" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50840568687_5d7e31d5b5_b.jpg" alt="508405686875d7e31d5b5b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2ksBcP6" rel="nofollow ugc">E46 arms and lollipop mount</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><a href="https://flic.kr/p/2kwBuy5" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50885890988_5f5cfe165f_b.jpg" alt="508858909885f5cfe165fb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwBuy5" rel="nofollow ugc">Front suspension</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto">I set the arms parallel to the subframe for the neutral anti-dive. I can always add some spacers under lollipop mounts to increase anti-dive</p>
<p dir="auto"><a href="https://flic.kr/p/2ksHim5" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50841757976_4bc73c20ee_b.jpg" alt="508417579764bc73c20eeb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2ksHim5" rel="nofollow ugc">Control arm angles</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><strong>Trailing Arms</strong></p>
<p dir="auto">The rear end is as problematic as the front. to fit wider wheels i needed to move shock pickup points almost 2" in. Shock mounts are from <a href="https://www.aa-mfg.com/" rel="nofollow ugc">https://www.aa-mfg.com/</a></p>
<p dir="auto"><a href="https://flic.kr/p/2kwFhxX" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886631061_626f20a59d_b.jpg" alt="50886631061626f20a59db.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFhxX" rel="nofollow ugc">Trilingarm</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>,</p>
<p dir="auto"><a href="https://flic.kr/p/2kwFqxF" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886657957_17753aa121_b.jpg" alt="5088665795717753aa121b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFqxF" rel="nofollow ugc">Rear suspension</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>, </p>
<p dir="auto"><strong>Brakes:</strong> </p>
<p dir="auto">Stock e46 330i up front and e32 rears. </p>
<p dir="auto"><strong>Suspension:</strong></p>
<p dir="auto">Koni race single adjustables. Front and rear e28 swaybars. Not sure about the spring rates.</p>
<p dir="auto">I modded the front e36 strut housings. I chopped the tops and welded volvo 740 threaded top portion of the strut tube.  </p>
<p dir="auto"><a href="https://flic.kr/p/2kwFujH" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50886670661_d52e31b31c_b.jpg" alt="50886670661d52e31b31cb.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwFujH" rel="nofollow ugc">Strut tubes e36</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>, </p>
<p dir="auto"><a href="https://flic.kr/p/2kwBLJG" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/50885945428_d2aaec5510_b.jpg" alt="50885945428d2aaec5510b.jpg" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2kwBLJG" rel="nofollow ugc">Strut tubes e36</a> by <a href="https://www.flickr.com/photos/186931632@N07/" rel="nofollow ugc">w grync</a>, </p>
<p dir="auto">Progress might be slow but I hope to build the motor over the summer and maybe even have it on the road this year.  </p>
<p dir="auto">pe that it will</p>
]]></description><link>https://wibimmers.com/topic/6307/helmut-the-e21</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:47:03 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/6307.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Jan 2021 05:12:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Helmut the e21 on Thu, 19 Feb 2026 13:52:01 GMT]]></title><description><![CDATA[<p dir="auto">I had some timing cover leaks that I had to fix. </p>
<p dir="auto"><a href="https://flic.kr/p/2rVMDR1" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55086293382_428908deb6_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Brakes are done. I used stainless hard lines which do not seal as well at the fittings as NiCopp lines. I had couple small leaks. A bit more torque at the fittings fixed the issue. </p>
<p dir="auto">Clutch hydraulic lines are done and it looks like clutch works ok.</p>
<p dir="auto">I put driveshaft, diff and axles in. Tightened whole front suspension minus tie rods. </p>
<p dir="auto">I still need to shorten stock e36 tie rods for this setup to work.</p>
<p dir="auto">I have a z4 manual rack that I will put in I just need to figure out the splines. I hope they are the same as e36 rack so I could reuse my Woodward u-joints.  </p>
<p dir="auto">Valve cover lost its beautiful blue color for the more modest wrinkle black</p>
<p dir="auto"><a href="https://flic.kr/p/2rWRP55" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55098421360_b181bcb4cd_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">The stupid intake manifold flange was warped. And my shitty welds were full of pinholes. No wonders that I could not set the idle below 1.2k rpm. </p>
<p dir="auto"><a href="https://flic.kr/p/2rXkiHp" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55103785741_1295b79d1d_b.jpg" alt=" " class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2rXkiHE" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55103785756_aa36d232a5_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"> 2 hours later and the flange started too look flat again  </p>
<p dir="auto"><a href="https://flic.kr/p/2rXmE2S" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55104049204_52b77725b0_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I spent whole evening chasing pinholes. I think I got them all.</p>
<p dir="auto">I welded new downpipe and rest of the exhaust. Its a 3" going into borla XR-1 muffler to Vibrant super quiet resonator and side exits on the driver side. </p>
<p dir="auto">I still need to weld a beauty ring for the side exit. I got a 4" stainless  pipe for this. </p>
<p dir="auto"><a href="https://flic.kr/p/2rWRP5a" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55098421365_35c06ff0c5_b.jpg" alt=" " class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2rWRP4y" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55098421330_fe8f0b7643_b.jpg" alt=" " class=" img-fluid img-markdown" /> </a><a href="https://flic.kr/p/2rWQXv3" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55098254608_3dbc7e1ce4_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/123286</link><guid isPermaLink="true">https://wibimmers.com/post/123286</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Thu, 19 Feb 2026 13:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Tue, 10 Feb 2026 13:35:17 GMT]]></title><description><![CDATA[<p dir="auto">It’s alive.<br />
 </p>
<p dir="auto">Priming oil pump was a pain. Had to use sprayer bottle to pump some oil thru the galleries to get the pump going.</p>
<p dir="auto">Its loud<br />
I need to fab up down pipe and exhaust. Zf 320 was sitting dry for couple years and now have detent issues.<br />
I hope some atf and heat will loosen things up.</p>
<p dir="auto">Redid the oil drain with the flex</p>
<p dir="auto"><a href="https://flic.kr/p/2rTmp4A" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55058732860_336d9a4276_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I painted some brackets and added intake manifold brace.  I also finished steering shaft for the e36 PS rack. But in the meantime i got my Z4 manual rack and will have to shorten that shaft a bit, or make a new one. The splined bits are from Woodward and are fairly cheap so might as well make a new shaft. </p>
<p dir="auto"><a href="https://flic.kr/p/2rTkt9V" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55058551513_6bfecb66ed_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I reused the timing guides that came with the motor. I was putting the motor together 3-4 years ago and stupid me instead of changing the guides i said fockit. So one of the guides, the lower horseshoe one is cracked.  So i replaced this guide and I am still fighting timing case covers. They just did not want to seal. Stock metal gasket and RTV didn't do much. I used copper spray this time and a set of new gaskets. </p>
<p dir="auto"><a href="https://flic.kr/p/2rTZzGs" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55065987782_6413559380_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rVSddX" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55087182751_bc6dd1d5c3_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I cleaned up some interior wiring and tuned idle a bit, I mean recalibrated TPS. It was idling at modest 3700rpm before adjustment <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue:" alt="😛" /><br />
I also reassembled rear hubs and put the calipers and new rear disks.</p>
<p dir="auto">I tried laminating carbon for the first time. Overall it was not that bad (i guess we will se results tomorrow once it cures. Stretching carbon fabric around corners is a bit tricky and corners came out kinda meh. I will try again tomorrow to see if i can make it better.</p>
<p dir="auto">I used Epon 828 epoxy resin and epikure 3200 hardener from Westlake. Also used 3m 77 spray adhesive to hold fabric in place. I did 2 layers of "amazon special" carbon fabric (3k twill weave) covered it with peel ply layer and breather and used storage vacuum bag.<br />
Mold was prepped with 5 coats of release wax and 3 coats of PVA.</p>
<p dir="auto"><a href="https://flic.kr/p/2rUsc2f" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55071179524_bb6a580f74_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rUsc2v" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55071179539_21dfe0142e_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rUrTNb" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55071121578_8d6a1a655c_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rUR4Ee" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55075642333_d9b9197507_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rURTEz" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55075803825_2678e3523e_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I mounted brake and clutch reservoirs. It is incredibly tight but it works. Engine an transmission has poly mounts and there is barely any movement so I should be fine</p>
<p dir="auto"><a href="https://flic.kr/p/2rUR4pz" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55075641483_c7deba76c9_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Temporary exhaust <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue:" alt="😛" /></p>
<p dir="auto"><a href="https://flic.kr/p/2rUQ2nP" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55075439541_e675627f2b_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rUR4q1" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55075641508_729a46013c_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I needed to resurface intake manifold flange. Flange had a high spot by cylinder #2 and was not sealing and vacuum leaked like crazy. A bit of a sand paper, new gasket and my all time favorite copper spray and its fixed. </p>
<p dir="auto">I got my ADU display. It integrated with MaxxEcu over can bus very well.</p>
<p dir="auto"><a href="https://flic.kr/p/2rVCH7T" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55084548387_60342bd9fc_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I am waiting on some bolts for brake caliper carriers, some m10 brake line fittings and v-band flanges to fab the downpipe and the rest of the exhaust.</p>
]]></description><link>https://wibimmers.com/post/123265</link><guid isPermaLink="true">https://wibimmers.com/post/123265</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Tue, 10 Feb 2026 13:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Tue, 03 Feb 2026 23:15:54 GMT]]></title><description><![CDATA[<p dir="auto">Nice progress!</p>
]]></description><link>https://wibimmers.com/post/123229</link><guid isPermaLink="true">https://wibimmers.com/post/123229</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Tue, 03 Feb 2026 23:15:54 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Tue, 20 Jan 2026 15:04:17 GMT]]></title><description><![CDATA[<p dir="auto">I decided to go with ADU5 digital display in the middle and will use 80mm analog tach and speed. </p>
<p dir="auto">I started making some molds to build CF cluster bezel. I will receive my ADU in two weeks. </p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55037457636_e632fcc2ac_b.jpg" alt="55037457636e632fcc2acb.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55037712889_e647b146cd_b.jpg" alt="55037712889e647b146cdb.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55037712879_5b907f50b1_b.jpg" alt="550377128795b907f50b1b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am trying to make the car drivable and somewhat reliable so I can take it to Vintage. The goal is to have it on the road first week of March and shake it down and fix whatever falls apart.</p>
<p dir="auto">I finished engine harness and tested all circuits. Bought new wally world AGM battery and amazon special battery tray.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55036553927_8b9337fa86_b.jpg" alt="550365539278b9337fa86b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55050745739_454d60e936_b.jpg%5B/img%5D" alt="img%5D" class=" img-fluid img-markdown" />[/url][</p>
<p dir="auto">I got a nice deal on ID 1050x injectors. I was a bit disappointed with fitment and the fact that I will loose beautiful stock m42 injector harness box/cover. But I could not find ev6 sized injector that would flow 1000 or more cc's. </p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55050832305_f933d2cc9e_b.jpg" alt="55050832305f933d2cc9eb.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55050745764_e2f7299949_b.jpg" alt="55050745764e2f7299949b.jpg" class=" img-fluid img-markdown" />[/img][/url]</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55050676558_2cc5975516_b.jpg" alt="550506765582cc5975516b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I finished all oil lines and coolant lines. I used stainless hardlines for turbo coolant and turbo oil feed.</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/54976606366_5fcf3b6bf1_b.jpg" alt="549766063665fcf3b6bf1b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Radiator hoses are generic amazon silicone 90's joint with stainless tube. </p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55037637268_9f8589d069_b.jpg" alt="550376372689f8589d069b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Cheapo bead roller struggled a bit with stainless tube but it got the job done. </p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55037637253_6518674363_b.jpg" alt="550376372536518674363b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I finished welding exhaust manifold</p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55049586177_174f2a7852_b.jpg" alt="55049586177174f2a7852b.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Added some vacuum ports to the intake. </p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55050832270_9923cda01b_b.jpg" alt="550508322709923cda01bb.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Don't mind the welds I forgot what to do when welding a massive heatsink of aluminum could not get the welder dialed. </p>
<p dir="auto">160 amps was to low. 200 amps was destroying the tungsten and it would weld like crap. It is sealed and will be covered and not visible <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue:" alt="😛" /></p>
<p dir="auto"><img src="https://live.staticflickr.com/65535/55049586162_eaf9b5b76d_b.jpg" alt="55049586162eaf9b5b76db.jpg" class=" img-fluid img-markdown" /><img src="https://live.staticflickr.com/65535/55049586162_eaf9b5b76d_b.jpg" alt="55049586162eaf9b5b76db.jpg" class=" img-fluid img-markdown" /><img src="https://live.staticflickr.com/65535/55049586162_eaf9b5b76d_b.jpg" alt="55049586162eaf9b5b76db.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Need to redo the turbo drain. It will most likely crack when the manifold expands due to heat. I will add flex section closer to the oil pan. </p>
<p dir="auto"><a href="https://flic.kr/p/2rSDsM8" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/55050745769_4b5130c6ae_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">To do list. </p>
<p dir="auto">1. Start the motor and if it doesn't explode immediately bring it to temp and fix leaks if any. </p>
<p dir="auto">2. Fab up Turbo to IC pipe. </p>
<p dir="auto">3. Fab up downpipe and rest of the exhaust. </p>
<p dir="auto">4. Fab up clutch hydraulic lines</p>
<p dir="auto">5. Mount brake fluid reservoirs</p>
<p dir="auto">6. Assembly all brakes. Buy braided steel brake lines.</p>
]]></description><link>https://wibimmers.com/post/123184</link><guid isPermaLink="true">https://wibimmers.com/post/123184</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Tue, 20 Jan 2026 15:04:17 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Fri, 16 Jan 2026 05:20:40 GMT]]></title><description><![CDATA[<p dir="auto">I vote either full analog with a tiny digital, or go full bore on digital and make it fit nicely and look as sleek as you can. A hybrid approach I think would kinda clash?</p>
<p dir="auto">Whoo progress! This thing is gonna rip!</p>
]]></description><link>https://wibimmers.com/post/123167</link><guid isPermaLink="true">https://wibimmers.com/post/123167</guid><dc:creator><![CDATA[P_Roloff]]></dc:creator><pubDate>Fri, 16 Jan 2026 05:20:40 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Mon, 29 Dec 2025 17:12:13 GMT]]></title><description><![CDATA[<p dir="auto">Would be awesome to keep analog gauges, but have some sort of P3 digital vent gauge that is subtle/matches the BMW amber color. Wonder if you could hack up an OEM vent to fit one of these <a href="https://p3.io/" rel="nofollow ugc">https://p3.io/</a></p>
]]></description><link>https://wibimmers.com/post/123092</link><guid isPermaLink="true">https://wibimmers.com/post/123092</guid><dc:creator><![CDATA[pynacl]]></dc:creator><pubDate>Mon, 29 Dec 2025 17:12:13 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Mon, 08 Dec 2025 14:54:22 GMT]]></title><description><![CDATA[<p dir="auto">Update once every 3 years <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue:" alt="😛" />  I am committed( at least for now ) to get that thing on the road.</p>
<p dir="auto">Turbo manifold is done. Just need to finish welding the wastegate take off. I am still waiting for 3" stainless for the downpipe and exhaust and will finish the wastegate and manifold once I get it. Surprisingly my old downpipe from m10 fits but upside down :P.<br />
It's been a while when I left off the engine wiring harness. I restarted the process couple days ago. I took me a while to go thru my documentation to figure out what goes where. I just have to terminate the harness with two circular connectors and should be good to go.</p>
<p dir="auto">I also started working on coolant hoses. I got the heater core connection figured out. Turbo coolant hoses are also planned. I have bunch of stainless tube to hardline the turbo coolant and oil lines.</p>
<p dir="auto"><a href="https://flic.kr/p/2rKxETe" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/54970400347_ea9528fb5a_c.jpg" alt="54970400347ea9528fb5ac.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rKD89G" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/54971464268_4b82a72da8_b.jpg" alt="549714642684b82a72da8b.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2rKCetv" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/54971290431_0b40b1ee75_c.jpg" alt="549712904310b40b1ee75c.jpg" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Now the question:</p>
<p dir="auto">Dash/gauges?</p>
<p dir="auto">1. Do I do digital dash<br />
2. Digital Dash with analog tach<br />
3. All analog with small 2-3" screen to display can bus data from ECU. i.e. EGT's, Timing, boost, oil T, oil P</p>
<p dir="auto">Did a little rendering. I looks kinda meh but gives you some idea.</p>
<p dir="auto"><a href="https://flic.kr/p/2rKDFpj" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/54971572764_ff06a11a6a_c.jpg" alt="54971572764ff06a11a6ac.jpg" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/122964</link><guid isPermaLink="true">https://wibimmers.com/post/122964</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Mon, 08 Dec 2025 14:54:22 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Wed, 14 Jun 2023 15:08:44 GMT]]></title><description><![CDATA[<p dir="auto">Chassis harness is done and 99% functioning. There are small things to correct, like fogs and low beams control wiring is wrong and I need to move some pins around in the bulkhead connectors. </p>
<p dir="auto">Fuel lines, flex sensor etc is done i just need to mount the fuel filter.</p>
<p dir="auto">ECU is mounted and one of the bulkheads is terminated.</p>
<p dir="auto">Will finish second bulkhead and engine harness sometime this and next week. The goal is to start the engine this month. </p>
<p dir="auto">I cleaned the motor, slapped new gaskets including a headgasket and it should be ready to go. This thing sat for 4 years behind my shed. Damn chipmunk lived in the motor and stored bunch of chipmunk food in the head port. </p>
<p dir="auto">Hopefully everything cleaned fairly ok. I will pull this motor anyway and drop some forged goodies over the winter. </p>
<p dir="auto">I welded drain plug and turbo drain  and oil pan is now ready to go.</p>
<p dir="auto">My arp flywheel bolts from bmw m10 are a bit too short. I will need to replace with 28mm bolts.</p>
<p dir="auto">Also the tilton hydraulic throw out is 2mm too long and I will need to swap the TO piston for the shorter one. </p>
<p dir="auto">I got the steering shaft mocked up with some woodward u-joints. Will finish it once i get the e36 column in final position.</p>
<p dir="auto">I decided to not run the motor NA and go for boost. I got the intercooler setup and i have a log manifold from my friends Volvo. The cylinder spacing is spot on i just need to redrill the flange for m42 bolt pattern.  I got some green top injectors that should support 200-250whp which should be more than enough to test the chassis. </p>
<p dir="auto">I also pondered the idea of running e90 cluster in  my car. I got the arduino setup with can shield and was able to control most of the cluster. Cluster talks at 100kbs and maxxecu supports 500kbs i will need to setup arduino with dual can to translate the messages from maxx to BMW but that should not be a big issue. </p>
<p dir="auto"><a href="https://flic.kr/p/2oH9HwB" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974218371_545a3712f1_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oH9ERb" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974209356_9e6dd9a85b_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oH9Hqj" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974218006_e1551d1b71_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHc3ix" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974671753_b77bda3654_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHcfma" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974712273_90d0a91251_b.jpg" alt=" " class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2oHbzZC" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974583250_4ffb5aafc6_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHbZuM" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974662313_4b08f0d4cb_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHbzWw" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974583070_f40ef58115_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oH9EQ4" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974209291_f0ed706b83_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oH6SgY" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52973662462_757a09d2cc_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHbQzQ" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974632330_82db6690cc_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oH6ScK" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52973662217_c67b9053e7_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHcfeM" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974711903_321d2826c3_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHc3my" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974671928_90991844dc_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2oHcfko" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52974712228_7cf9a8360c_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/116346</link><guid isPermaLink="true">https://wibimmers.com/post/116346</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Wed, 14 Jun 2023 15:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Fri, 17 Mar 2023 04:13:05 GMT]]></title><description><![CDATA[<p dir="auto">Electrical work is progressing well. I decided to abandon the Littlefuse integrated fusebox and build my own using TE fuseboxes. It allowed me to bus the power to the components the way I wanted.</p>
<p dir="auto">I left the original rear harness and terminated it with the 20 pin deutsch connector. It will connect to the front harness.</p>
<p dir="auto">Body harness is 90% complete. Almost everything under the hood is done. I am still adding some wires under dashboard for gauge power, glovebox lights or radio power and finishing up some grounds. It should be ready this week.<br />
I get the set of cheapo rock auto parts e28 axles , brake discs and some pagid brake pads. I also got the gasket set for the m42. </p>
<p dir="auto">I got a set of cheapest VAG coils of amazon to see how they fit. I think i will whip something to retain the coils. Once that thing moves out of garage under it own power and suspension aligns I will replace all el cheapo parts with something of better quality. </p>
<p dir="auto">I spent some bucks on the Radium FPR and it fits beautifully with the nuke fuel rail.</p>
<p dir="auto">Next:</p>
<p dir="auto">Finish the fuel system: I got PTFE lines and fpr AND now its time for Flex fuel sensor and some AN fittings</p>
<p dir="auto">Finish the steering: I ordered woodward u-joints and will need to whip a steering shaft. I still have to mount the column in final position. And lastly will need to sort the tie rod situation. I am thinking shorted e90 inners and e36 outers? </p>
<p dir="auto">Engine: I have a second m42 which was sitting (covered) outside for almost 3 years. Damn squirrel lived in that thing for two years before I chased her out of there and sprayed 2 cans of pb blaster into the motor. It made very interesting, kind of crunchy noises when turning so I am pretty sure that it will work great. I got a gasket set for it  and I am ready to dingleberry the shit out of the cylinders if needed and re-ring the pistons.</p>
<p dir="auto">Who knows maybe it will  make it to the Vintage <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue:" alt="😛" /> </p>
<p dir="auto">Beginning of the new fusebox</p>
<p dir="auto"><a href="https://flic.kr/p/2omXhRh" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52745659202_6fd35eeaa5_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">New fusebox</p>
<p dir="auto"><a href="https://flic.kr/p/2on2gmT" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746434639_c527baa9ca_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">And the guts : power first</p>
<p dir="auto"><a href="https://flic.kr/p/2on3xsn" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746683893_ecf37b477a_b.jpg" alt="Elektryka" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">And the outputs</p>
<p dir="auto"><a href="https://flic.kr/p/2omZZEg" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746186711_7b27207ec5_b.jpg" alt="Elektryka" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Radlok for incoming power: This thing is well........... very rad. Possibly best power connector I've seen so far</p>
<p dir="auto"><a href="https://flic.kr/p/2omZYxw" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746182956_010964347f_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2omXj1g" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52745663087_c700bce919_b.jpg" alt="Elektryka" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Finished product with chassis harness attached. Still need to shrink the boots but first will need to test and verify all circuits. I already found horn connected to the radiator fan output and vice versa. Hooooooonk you overheated <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /></p>
<p dir="auto"><a href="https://flic.kr/p/2omZZFi" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746186771_64911bb5ff_b.jpg" alt="Elektryka" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">FPR. works really well with Nuke rail. Looks like this part was meant for m42 with my manifold</p>
<p dir="auto"><a href="https://flic.kr/p/2on38Lg" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746604195_75d5aeaf23_b.jpg" alt="Elektryka" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2omZZBv" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52746186551_b5c0e8551a_b.jpg" alt="Elektryka" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Chinesium coils</p>
<p dir="auto"><a href="https://flic.kr/p/2onvc9G" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52751883612_651c8b67d5_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2onA3PJ" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52752831160_cb9247f08b_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/115779</link><guid isPermaLink="true">https://wibimmers.com/post/115779</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Fri, 17 Mar 2023 04:13:05 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Wed, 18 Jan 2023 14:16:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the wiring source! I had trouble finding oem style colored wiring last time I looked.</p>
]]></description><link>https://wibimmers.com/post/115397</link><guid isPermaLink="true">https://wibimmers.com/post/115397</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 18 Jan 2023 14:16:43 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Tue, 17 Jan 2023 06:01:34 GMT]]></title><description><![CDATA[<p dir="auto">h my that is what happen when you have 4 other projects ehm ehm. kids, wife and house and poor bimmer had to wait again. Oh well I got a bit of motivation so I will try to keep the momentum going. Vintage 2023 I am coming <img src="https://wibimmers.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=6c9209168ce" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":stuck_out_tongue:" alt="😛" /></p>
<p dir="auto">It is wiring time. I ordered bunch of tefzel wire a while ago but could not get myself to start the wiring process.</p>
<p dir="auto"><a href="https://flic.kr/p/2obWXBx" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52632429529_4466138220_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2obXV19" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52632615860_431311b959_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">And of course when i started checking circuits and what wires I will need I found that I forgot to order roughly 20-30% of needed wires.<br />
I fixed that and I am getting the remainder tomorrow.</p>
<p dir="auto">Since I could not continue wiring for about a week focused on other things. Fuel tank was partially modified (read cut but not welded), so i tackled that. I will run just the right side tank (measures roughly 7.5 gallons). Range will be amazing escpecially on e85. Space left after the left tank will be occupied by the exhaust.</p>
<p dir="auto">Don't mind my ugly welds it doesn't leak  and its temporary until I get the fuel cell</p>
<p dir="auto"><a href="https://flic.kr/p/2obXUZC" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52632615830_0b36b7864e_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I also got the main power feed done. It is 1/0 splitting into 3x 4 gauge. Black thingy is the main 70A relay that will power up the "run" bus of the fusebox</p>
<p dir="auto"><a href="https://flic.kr/p/2obXUYR" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52632615785_0a81a869e5_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I painted front calipers black and inspected rear e28 calipers that I sourced from the lemons e28. Rears will need rebuild which will be done as soon as I get my rebuild kit from rockauto.</p>
<p dir="auto">This week I will try to finish fuel lines (6AN ptfe for that corn juice power) and continue the wiring challenge.</p>
]]></description><link>https://wibimmers.com/post/115384</link><guid isPermaLink="true">https://wibimmers.com/post/115384</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Tue, 17 Jan 2023 06:01:34 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Tue, 26 Jul 2022 13:50:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/113883">YoungCR said:</a></strong></p>
<p dir="auto">This is the same one Eastwood sells and I highly recommend it, perfect flares every time. There are few other brands listed on amazon with the same thing a well and available with prime shipping but I got the K Tool years ago. </p>
<p dir="auto"><a href="https://www.amazon.com/Tool-International-Vise-Mounted-T-Handle-KTI70081/dp/B004IKRO34/ref=sr_1_2_sspa?crid=2OU0JBPMK20XS&amp;keywords=brake%2Bflare%2Bkit&amp;qid=1658685329&amp;sprefix=brake%2Bflat%2Caps%2C107&amp;sr=8-2-spons&amp;spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyMkQ4RUpFM0xKMEk2JmVuY3J5cHRlZElkPUEwMjQ1MDg2OVpaNUNQSVdNTkNGJmVuY3J5cHRlZEFkSWQ9QTAxMzE5NDI2UEJIMFZCUVNCS0Mmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&amp;th=1" rel="nofollow ugc">K Tool International Brake Line Flaring Tool, 45 Degree Set. Single, Double, and Bubble Flares, Vise-Mounted, T-Handle Screw Clamp</a></p>
<p dir="auto">Yup just ordered it from amazon it is a TGR brand but otherwise looks the same.</p>
<p dir="auto">What is the preferred way of doing fuel lines? </p>
<p dir="auto">I got enough -6AN PTFE hose to run both supply and return but I thought that maybe going with stainless hardline would be a better option.</p>
]]></description><link>https://wibimmers.com/post/113909</link><guid isPermaLink="true">https://wibimmers.com/post/113909</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Tue, 26 Jul 2022 13:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Sun, 24 Jul 2022 17:59:13 GMT]]></title><description><![CDATA[<p dir="auto">This is the same one Eastwood sells and I highly recommend it, perfect flares every time. There are few other brands listed on amazon with the same thing a well and available with prime shipping but I got the K Tool years ago. </p>
]]></description><link>https://wibimmers.com/post/113883</link><guid isPermaLink="true">https://wibimmers.com/post/113883</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sun, 24 Jul 2022 17:59:13 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Sun, 24 Jul 2022 05:06:25 GMT]]></title><description><![CDATA[<p dir="auto">Pedals are done. </p>
<p dir="auto"><a href="https://flic.kr/p/2nA1qUp" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52237029311_8291303cd2_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Dual master ready to be plumbed. I am using stok e36 325i front brakes and stock 528i e28 rears. Front master is tilton 0.7" and rear is .75". Clutch is wilwood .75" I must say that Tiltons look much beefier and beter quality than wilwoods. </p>
<p dir="auto"><a href="https://flic.kr/p/2nA2Sud" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52237310484_0c2d9fe9ba_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I bolted front and rear suspension and set the car on jenga blocks. I need to order new brake line flaring tool since cheapo amazon one crapped out on the second try.</p>
<p dir="auto"><a href="https://flic.kr/p/2nzVp2c" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52236047417_37d4f876bc_b.jpg" alt=" " class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2nA1sYm" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52237036268_54aa1f68dc_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nA1sYM" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52237036293_e78bf3e03c_b.jpg" alt=" " class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2nA1t99" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52237036836_075d3f305c_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/113876</link><guid isPermaLink="true">https://wibimmers.com/post/113876</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Sun, 24 Jul 2022 05:06:25 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Wed, 06 Jul 2022 16:57:46 GMT]]></title><description><![CDATA[<p dir="auto">I were going to build one then i figured that I can set up the canopy thing outside but I got some stupid neighbors who would certainly call code enforcement cops so decided to move it inside. </p>
<p dir="auto">Paint came out great. Engine bays are not my favorite thig to spray. There are bunch of angles, crevices and spots that are hard to get. I got couple of spots with that dry spray texture. I did not bother using a tack cloth after I preped the bare metal so there is bunch dust spots. Its good enough tho for the engine bay.</p>
<p dir="auto">The floor around the drivers side torque box rusted out so this will get fixed next. I need to paint the driveshaft center bearing supports and diff mounts. Also will get the rear fender lips touched up since they cracked pretty badly when I pulled the fenders. </p>
<p dir="auto"><a href="https://flic.kr/p/2nwuAhB" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52197258027_38a5448092_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nwChee" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52198758175_330457e67d_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nwzHWU" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52198259356_6064e4378b_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nwuRCM" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52197309657_641ea13499_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/113648</link><guid isPermaLink="true">https://wibimmers.com/post/113648</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Wed, 06 Jul 2022 16:57:46 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Wed, 06 Jul 2022 15:30:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/113643">SteelBlue said:</a></strong></p>
<p dir="auto">Using an easy up as a paint booth frame is a great idea. </p>
<p dir="auto">It certainly is. I'm really annoyed that I spent the time and money building one when I have one.</p>
]]></description><link>https://wibimmers.com/post/113647</link><guid isPermaLink="true">https://wibimmers.com/post/113647</guid><dc:creator><![CDATA[gilber33]]></dc:creator><pubDate>Wed, 06 Jul 2022 15:30:57 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Wed, 06 Jul 2022 14:12:23 GMT]]></title><description><![CDATA[<p dir="auto">Using an easy up as a paint booth frame is a great idea.</p>
]]></description><link>https://wibimmers.com/post/113643</link><guid isPermaLink="true">https://wibimmers.com/post/113643</guid><dc:creator><![CDATA[SteelBlue]]></dc:creator><pubDate>Wed, 06 Jul 2022 14:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Wed, 06 Jul 2022 00:08:08 GMT]]></title><description><![CDATA[<p dir="auto">Always inspiring to see these diy paint set ups. Can’t wait to see the final results!</p>
]]></description><link>https://wibimmers.com/post/113632</link><guid isPermaLink="true">https://wibimmers.com/post/113632</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Wed, 06 Jul 2022 00:08:08 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Tue, 05 Jul 2022 16:08:44 GMT]]></title><description><![CDATA[<p dir="auto">After couple of weeks of engine bay paint prep. I am ready to paint it. I build a beautiful spray booth in my garage with two box fans and shoot some epoxy primer followed by some seam sealer and more epoxy. Today i will finish it with single stage urethane in original safari beige.</p>
<p dir="auto">I got the intercooler figured out. Wiring is next on the list.</p>
<p dir="auto"><a href="https://flic.kr/p/2nwnLrC" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52195926406_d07f885d97_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a><a href="https://flic.kr/p/2nwnQKz" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52195940903_88e8d097f5_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nwnLrx" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52195926401_32622dde80_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nwnLr7" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52195926376_2b73755942_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/113622</link><guid isPermaLink="true">https://wibimmers.com/post/113622</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Tue, 05 Jul 2022 16:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Sat, 07 May 2022 02:14:56 GMT]]></title><description><![CDATA[<p dir="auto">I got a monstercooler today. I think it is a bit too much @  24x12x4" core. It fits though but I think I will swap it for something a bit smaller. It will take an hour for the turbo to fill this thing with air. I think transient response may suffer a bit.  It might require some pie cutting to connect to throttle body.</p>
<p dir="auto"><a href="https://flic.kr/p/2niSfTf" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52054370772_58ce458c48_b.jpg" alt="Intercooler" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2niYQdB" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52055653579_650a445ebc_b.jpg" alt="Intercooler" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2niXCu5" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52055418996_257f241441_b.jpg" alt="Intercooler" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/112825</link><guid isPermaLink="true">https://wibimmers.com/post/112825</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Sat, 07 May 2022 02:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Thu, 28 Apr 2022 19:10:39 GMT]]></title><description><![CDATA[<p dir="auto">I got my fleabay Intercooler it supposed to e 3" core. Well  it is not. Its a 2.5" and has some shitty spoolgun welds.. I am not even mad I will just return it and get another cheapo intercooler hoping it will be a bit better. Anyone know ebay sellers/brands that might have decent 3" intercoolers? My 12x12 ebay intercooler that i got couple years back look much better with decent welds and nice looking 3" core. </p>
<p dir="auto"><a href="https://flic.kr/p/2nhjjUp" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52036824215_d450888944_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nhhXKg" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52036557929_d692ef4f85_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I made upper radiator mount/ shroud/ intercooler mount. </p>
<p dir="auto"><a href="https://flic.kr/p/2nhhXKS" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52036557964_26aa18f4d7_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nhbkqH" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52035265077_5042a8d020_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Front frame rail  brace might come handy. The e21 chassis flexes a lot. I will most likely use this brace as a mounting point for the skid plate</p>
<p dir="auto">Strut tower brace will be next. </p>
<p dir="auto"><a href="https://flic.kr/p/2nhgNwa" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52036331781_115dd5892e_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I also got my e90 gas pedal. It should work really well. </p>
<p dir="auto"><a href="https://flic.kr/p/2ngHhNP" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52029988243_8f4849c95b_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I started designing chassis electrical harness with my new fusebox. I got the inventory of all circuits including wire lenghts, colors, gauge and approximate splice locations.I will be ordering some tefzel wiring sometime next week.</p>
<p dir="auto">I had a bit of an issue with clutch master fitting in the bay, So I had to expand the bay a little bit. Half a pound of seam sealer and some epoxy primer and it will look beautiful</p>
<p dir="auto"><a href="https://flic.kr/p/2ngjffi" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52025492053_6c4081acb8_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ngdKQg" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52024420907_8292189572_b.jpg" alt=" " class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/112750</link><guid isPermaLink="true">https://wibimmers.com/post/112750</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Thu, 28 Apr 2022 19:10:39 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Fri, 22 Apr 2022 17:21:52 GMT]]></title><description><![CDATA[<p dir="auto">Pedal box is done.</p>
<p dir="auto"><a href="https://flic.kr/p/2ng1TBt" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52022105733_8afc70a70d_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ng2ZEj" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52022321194_e08bd49b3a_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I got my throttle body flange. I use 68mm Bosch motorsports TB. Its funny that you cant get that flange in the states. I had to order one from Sweden. </p>
<p dir="auto"><a href="https://flic.kr/p/2ng1HdF" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52022070771_a07e93437d_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ng4kT4" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52022584325_4182b78a79_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ng1HdR" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52022070781_5642640675_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ng1TAS" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/52022105698_1366cff763_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">I ordered my eBay intercooler. 12x18x3" core. Should be plenty to support my power goals.</p>
<p dir="auto">Next week will be finishing some bracketry and I should be ready to prep it for paint.</p>
]]></description><link>https://wibimmers.com/post/112697</link><guid isPermaLink="true">https://wibimmers.com/post/112697</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Fri, 22 Apr 2022 17:21:52 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Sun, 03 Apr 2022 14:03:41 GMT]]></title><description><![CDATA[<p dir="auto">Nice work on the firewall plate</p>
]]></description><link>https://wibimmers.com/post/112512</link><guid isPermaLink="true">https://wibimmers.com/post/112512</guid><dc:creator><![CDATA[YoungCR]]></dc:creator><pubDate>Sun, 03 Apr 2022 14:03:41 GMT</pubDate></item><item><title><![CDATA[Reply to Helmut the e21 on Sun, 03 Apr 2022 05:46:40 GMT]]></title><description><![CDATA[<p dir="auto">I welded up the manifold. It was a pain. My 200amp tig had some trouble welding 1/4" plenum with the trumpets. Trumpets were quite thick with some sections close to 1/2" or more. I could use 50amps more.<br />
I added fuel rail brackets and end cap. I also ordered bosch motorsports 68mm DBW throttle. I still need to get the weld-on flange for this throttle.</p>
<p dir="auto">I ditched floor mounted pedals and get hanging pedal setup. I whipped new firewall plate and added the e36 column mount</p>
<p dir="auto"><a href="https://flic.kr/p/2nc1353" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/51976673090_958ea91cf9_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ncdZdF" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/51979199955_63125959ab_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2nc135D" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/51976673125_d602e211a3_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ncbaYF" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/51978650811_813c8f2b01_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><a href="https://flic.kr/p/2ncbxJ6" rel="nofollow ugc"><img src="https://live.staticflickr.com/65535/51978723973_f54786157d_b.jpg" alt="Helmut" class=" img-fluid img-markdown" /></a></p>
]]></description><link>https://wibimmers.com/post/112508</link><guid isPermaLink="true">https://wibimmers.com/post/112508</guid><dc:creator><![CDATA[retoropak]]></dc:creator><pubDate>Sun, 03 Apr 2022 05:46:40 GMT</pubDate></item></channel></rss>
