  4. ‘91 E30
‘91 E30
510 Posts 27 Posters 2 Views 1 Watching
    Fitting showed up. It should work. Haven’t messed with this much.
    wheels/tires ordered, should be here eventually
      New fitting on its way from chasebays, hoping this one is the golden ticket
      Fitting was still too long so I just did what I was going to do originally and shortened the first fitting. Got everything buttoned up, so far I don’t see any leaks after bleeding/idling in the garage. I’ll need to go drive it around a bunch to confirm.
        Also 2/4 of the wheels showed up, figured out a few different spacer sizes that should work depending on how wide the rt660s actually run. My assumption is quite wide based on some pics I’ve seen
          Sold the RE71/K1s, replacements showed up today
          225/45/15 Falken RT660
          plan is to slap them on these:
          konig hypergram 15x8.5
          it’s about the only lightweight 8.5” wide wheel I could find that didn’t have bacon fender inducing offset. Ordering up some spacers later today. Hoping to have this all ready to go by the time RA autox rolls around
            Haven't really been following the 200 treadwear battle, but I'm sure it's still fierce. What made you decide to go with the Falkens?
              RE71r doesn’t come in a 225/45/15
              the rt660 has been shown to be pretty much on par with the RE71r, they are also cheaper than the RE71r in similar sizes
                Cant wait to take some sexy photos of this thing.
                Good choice on wheel color.
                  It was either that or bronze, they’ll look the same shade of brake dust anyways
                    konig hypergram
                    One of us - Toy Story Alien - quickmeme
                    I look forward to pictures of the car with tires mounted up!
                      Spacers ordered, front im 99% sure will be ok after all the measuring and fitting.
                      the rear wheels bolt up and clear everything, but I ordered a small one just in case it decides to get friendly with the body during suspension travel
                      Here it’s shown at full droop with no spacer
                        The paint looks excellent
                        Anxiously awaiting photogs of the new tires and wheels installed
                          Have been driving the car for a bit, pump still makes a noticeable whine. No leaks (hooray) from the PS system, but now I have a loud pump. Checked chase bays troubleshooting guide:
                          the clamp I was sent is as tight as I can get it, so now I’m wondering if I have a clamp that is too large. I have to get them the PN off the clamp (which is facing the block and not easy to see) so they can figure out if what they sent me is correct. 😒
                          In other news my spacers show up tomorrow and I get wheels mounted on Wednesday.
                          I bought a fender roller just in case lol
                            You better believe that seeing pics of the new wheels installed is high on my list of things to look forward to this week
                              You and me both
                                So if anyone is curious, The RT660 is quite wide, the 200tw class battle is out of control lol
                                these are on a 8.5” wheel and aren’t the slightest bit stretched, could honestly probably put them on a 9” and almost be square
                                Due to the added chonk, i had to order a different sized spacer for the fronts because I was assuming an rs4-ish sized tire
                                Spacers Get here Friday & I’ll take some pics then
                                  Well then.  That's meaty.
                                    Ok so I said screw it and lightly drove it anyways
                                      Looks good!  A little drive just helps persuade the rubber to fit, that's all.
                                        Still gonna run the larger spacer for peace of mind lol
                                          We call that "self-clearancing" where I come from.
