  4. ‘91 E30
‘91 E30
    theyve been selling it for years. if there were some great amount of failures, shoudnt we have heard about it by now? i think they use some aluminum fittings for the brake stuff, even. cant muck about with brakes with inferior stuffs and not have a lawsuit.
      Chase Bays... More like Wait for days!  Ok I'm done.
        It actually got here quickly, albeit with parts that don’t work but you know, silver linings and such
          That's kind of what I was alluding to.  Waiting for the right stuff to show up. I'm not even offended my terrible joke didn't go over.  It made me laugh and that's all it needed to do.
          • The Full BananaT
            The Full BananaT
            The Full Banana
            It sure is. We’ll see how long the chasebays stuff lasts I guess
            Yeah, very valid point. I guess I'm just used to not having kits available for things so I'm looking at tried and true patterns that OEs abide by, and tend toward overbuilding things to avoid hassles. A friend had a high pressure PS line fail a couple years back after I warned about using garden variety AN fittings and hose on it, rather than high pressure stuff suited to the application.
            After looking at the chase bays high pressure hose for my own curiosity, it looks like they are using crimped fittings (which are much more important for higher pressure) and thicker wall 90s, rather than the thinner tube stuff you commonly see for fuel line and the like. Like you said, probably okay given that they've had the product out there, just wouldn't be the material I'd choose if assembling from scratch (which is irrelevant to this conversation 🤐).
              New fitting on its way from chasebays, hoping this one is the golden ticket
                Fitting showed up. It should work. Haven’t messed with this much.
                wheels/tires ordered, should be here eventually
                  Fitting was still too long so I just did what I was going to do originally and shortened the first fitting. Got everything buttoned up, so far I don’t see any leaks after bleeding/idling in the garage. I’ll need to go drive it around a bunch to confirm.
                    Also 2/4 of the wheels showed up, figured out a few different spacer sizes that should work depending on how wide the rt660s actually run. My assumption is quite wide based on some pics I’ve seen
                      Sold the RE71/K1s, replacements showed up today
                      225/45/15 Falken RT660
                      plan is to slap them on these:
                      konig hypergram 15x8.5
                      it’s about the only lightweight 8.5” wide wheel I could find that didn’t have bacon fender inducing offset. Ordering up some spacers later today. Hoping to have this all ready to go by the time RA autox rolls around
                        Haven't really been following the 200 treadwear battle, but I'm sure it's still fierce. What made you decide to go with the Falkens?
                          RE71r doesn’t come in a 225/45/15
                          the rt660 has been shown to be pretty much on par with the RE71r, they are also cheaper than the RE71r in similar sizes
                            Cant wait to take some sexy photos of this thing.
                            Good choice on wheel color.
                              It was either that or bronze, they’ll look the same shade of brake dust anyways
                                konig hypergram
                                One of us - Toy Story Alien - quickmeme
                                I look forward to pictures of the car with tires mounted up!
                                  Spacers ordered, front im 99% sure will be ok after all the measuring and fitting.
                                  the rear wheels bolt up and clear everything, but I ordered a small one just in case it decides to get friendly with the body during suspension travel
                                  Here it’s shown at full droop with no spacer
                                    The paint looks excellent
                                    Anxiously awaiting photogs of the new tires and wheels installed
                                      Have been driving the car for a bit, pump still makes a noticeable whine. No leaks (hooray) from the PS system, but now I have a loud pump. Checked chase bays troubleshooting guide:
                                      the clamp I was sent is as tight as I can get it, so now I’m wondering if I have a clamp that is too large. I have to get them the PN off the clamp (which is facing the block and not easy to see) so they can figure out if what they sent me is correct. 😒
                                      In other news my spacers show up tomorrow and I get wheels mounted on Wednesday.
                                      I bought a fender roller just in case lol
                                        You better believe that seeing pics of the new wheels installed is high on my list of things to look forward to this week
                                          You and me both
