    lastly for the night, i reset my SI board lights. I actually tried to do this when I bought the car, but was unsuccessful and thought maybe it was wired incorrectly.
    however, after attempting again, it worked.
    basic steps:
    1. create jumper wire. this can be anything metal that you can stick in the two diagnostic port pins. coat hanger, copper wire, whatever. I spliced to connector pins together.
    2. per the diagram i've sloppily drawn and the picture below, you put the pins into pin receptacles #19(ground) and #7(SI control). then turn the key to position 2 and wait a few seconds. the lights on the SI should light up green and then you can turn the car off. voila!
    since I was poking around, i decided to take a look at my coolant level sensor. the check control warning light has been intermittent, despite the overflow tank being full. the plug seems fine, but when i pull the sensor from the tank, it fell apart. a new one is on order. you'll also notice in this photo that my newish overflow tank has already started its transformation into a lovely yellow butterfly, after only a couple years.
    2018 photo, showing new white tank. *sad face*:
      Almost ready for daily duty
        daily duties for now include: me standing with my coffee and staring at the e30 in the morning. its a short commute.
          How will you get to the Open WI Now rallies?
            Popemobile
            340?cb=20111211163242
              Popemobile
              how did an italian car company not get his contract?
              wait, dumb question.
                went fishing yesterday. worked on the car today. life is good.
                time to tackle my window trim. problems: 1. two pieces of trim are trying to jettison from the car. 2. chrome window trim is so 70s.
                the upper trim where it comes down to the front fenders likes to fly off of e30s at highway speeds. luckily, last year it decided to come loose when I had the roof rack on, so it couldnt fly away. i had it temporarily taped in place:
                with the tape removed, you can see how the trim was failing. those little rust spots are where the clips are supposed to be holding the trim to body seam.
                here is a set of new clips. you need (4) for one side of the car. I ordered (5) for good measure.
                old clip (rusty and the little sharp tangs are worn down) vs new.
                to fix, simply slide or pull out the old clips and push the new ones in with a screwdriver. if you cant get the old ones out, just leave them and install the new clips next to them. its not worth bending your trim to try and get them out.
                and done.
                the next trim piece that was falling off was the driver's side rear 'wing'.  you can see it here sticking out from the body.
                to remove, just carefully pry it straight away from the car. be sure to slide the little clip out of the way at the top where it meets the upper trim.
                under, you'll find four holes/grommets. if you remove the trim, you'll likely have to replace all four, so have them on hand. there are (3) 51131870459 and (1) 51141902279 which is actually the same grommet used for the hood emblems. new grommets pushed in place:
                trim reinstalled
                all lined up again.
                at the same time, I 'shadowlined' the chrome window trim. most e30s came with some amount of chrome trim. early cars, all the trim was chrome. later cars had a mix. m3s, 318is, and other special cars (Mtech) had full black trim. it may have also been an option? not sure. my car is a late car with a mix (chrome upper/lower trim, black window trim, black front and rear windshield lockstrips)
                the car has the rear pop-up windows, so you have to remove them to properly paint the trim that is under the seals. removal is easy - one phillips screw at the pop-out latch, and two 8mm nuts behind the clothes hanger hook and seat belt on the B-pillar. no interior trim has to be removed.
                i saved all my packing paper from FCPeuro orders (they overdo the paper) to use as masking paper
                starting the masking job
                masking all complete. note: unplug your battery because you'll need to leave your doors open for extended periods of time.
                sand all the trim with light grit (220) to prep the shiny chrome surface to receive the primer.
                i usually use SEM trim paint for this job, but i'm sick of tracking it down so I went with store-bought rustoleum trim paint. in the end, I was happy with the finish. it is slightly more glossy than SEM, but matches the factory trim finish well. my only gripe is the nozzle is a wide spray pattern, which is super wasteful on thin trim. i sprayed most of the trim with the can twisted to get more coverage.
                did two coats of self etching primer
                patiently wait at least 12 hours to pull your masking tape (hardest part of the job)
                and boom, done.
                i am just about wrapped up for the 'winter' projects. I took the car out, washed it, and drove it.  much smiles.
                more to do:
                replace pulley idlers (squeek squeek squeek)
                replace coolant level sensor
                adjust rear coil heights (after pulling the car out and looking from a distance I can see its not even from side to side)
                alignment
                  Shadowline makes such a big difference, looks fanstastic!
                    I appreciate the amount of effort you put into your posts for us bozos on here.
                    I need to do the shadow line trim on my car. Debating having one of buddies who owns a wrapping business do them just so I'm not committed to one color or the other.
                    What lens/body were you using on the last shot?
                      Wrapping is a great idea! In the old days before vinyl warp, electrical tape was the go to for those wary of painting.
                      Camera is a d7200 with an f1.8 35mm lens.  I set it to f1.8 for that shot
                        I had a suspicion it was a 35mm. Definitely the next one on my list.
                          Man that driveway shot is gorgeous!
                          Good to know new clips are still available! I've had a piece or two of that trim fly off before...
                            Thanks! Small DOF and dramatic lighting make a boring old driveway much better LOL
                              stopped at a couple spots while running errands and snapped a few more photos since the car was clean. tried to go to places that are now empty due to the situation where normally cars and people might be in the way.
                              my photo variety has been boring lately (lots of 3/4 wide shots), but whatever.
                                Mmmm, beautiful!
                                  Mmmm, beautiful!
                                  Thank you!
                                    Those are some wallpaper quality shots.
                                      raw
                                        scouted some night shot sites. have to process through them, but here's one for now. this was inspired by @m42b32 's night museum shot, we're going to get some of his car in MKE at some point.
                                          Can't wait!!
