580 Posts 27 Posters 0 Views 1 Watching
    Boris3 said:
    Interesting, I've had filler in the bolt holes of both of my e30s when I did the subframes. The bushings had never been done before so maybe that's the difference?
    Great suggestion on removing the sleeves if you've got enough sticking out. I've tried the big lag bolt approach with mixed results, and when it didn't work ended up using small flat bits and other drill bits just to ream out the sleeve.
    I was thinking early/late models for the difference. I know one of the other e30s never had the subframe bushings done before I did them. The other two were 87 and 88 models
    I had the same type of clay stuff above my mounting pins also.
    I like those cribs!
    I ended up just doing POR15 with a topcoat on my rear frame+ arms.
    which bushings are you installing?
    I may do por15, but with the car not driven in the winter it seems pointless. Look how clean they've stayed for 30 years on their own.
    Powder is for odds and ends like the diff cover, subframe support brackets, etc
    I got revshift 80A poly bushings for the subframe, trailing arms, and diff
      a little more progress today.
      in my haste to remove the subframe bushing pins, i forget I borrowed mike's homemade puller tool which is a through-bolt style. this required me to backtrack and take that lag bolt back out lol
      was worth it, as the tool worked great, thanks @HipMF !
      fully extracted, no burning or mess.
      the workbench is now full of mini projects.
      the "subframe overhaul" consists of:
      clean everything
      replace passenger side rear wheel bearing
      replace subframe/trailing arm/diff bushings
      reseal differential (output seals, rear cover gasket, sensor gasket and fill plugs crush washers)
      install new ebrake cables
      install rear brake lines (body to subframe SS soft lines)
      install new rear sway bar bushings and end links
      install ebrake rebuild kit (shoes and springs)
      maybe powdercoat odds and ends
        Don’t forget new lock plates for the axle nuts 😁
          Don’t forget new lock plates for the axle nuts  :D
          optional, at best. wheres the axle gonna go if the nut falls off?
            Axle can't come out but the wheel hub can come off.  The brake rotor would probable keep it from coming totally out though :)
              my comment was sarcastic, but thanks for making sure no one tries something dumb like that lol
                putzed a bit before dinner.
                i DIY'd a subframe bushing puller so I didnt have to burn those out as well.
                1.12" 3/8 threaded rod, with a few different size washers and coupling nuts
                2. 4" 1-1/4" steel pipe
                3.a socket that fits (18mm, 19mm? dont remember)
                heat the trailing arm first to help the bushing slide
                voila.
                I also DIY'd a rear hub puller. i used a bearing separator last time with success, but didnt want to take a trip to the store for one, so this is what I put together. It uses a pair of main bearing caps, some door hinges, and two scrap pieces of steel. basically anything will work so long as its steel and doesnt shift around on you.
                just crank down the bolts to force the hub out.
                voila! this rear bearing was in pretty good shape, but the grease is definitely showing its age.
                to remove the stuck race from the hub, I dremeled a slot about half way through, heated the race, then struck the slot with a cold chisel. it cracked the race and I could slide it right off.
                finally, to pull the wheel bearing out, first remove the big ass snap ring (not shown) then attached your puller. I purchased a FWD bearing puller kit from Amazon for cheap which worked well both times Ive used it.
                had to bust out the cheater bar to get this to even budge. its not recommended to use an impact gun as you will greatly reduce the life of the threads on the tool
                voila!
                lastly, I got out all the new parts to inventory and see what I missed.
                Seen here:
                Turner Motorsports rear sway bar reinforcement plates (my last e30 torn the mounts, dont want to deal with that again)
                R3vshift poly TA, subframe, and diff bushing.
                ECS rear SS brake lines (chassis to subframe. the other 4 are installed)
                Sway bar bushings and links
                New rear wheel bearing and associated hardware
                Ebrake hardware rebuild kit, shoes, cables
                Diff resealing items
                Diff studs
                What I so far can tell i'm missing: one axle nut lock plate, new locknuts for the subframe bushings, brake fluid, crush washers for the diff fill plugs, new allen screws for ABS sensors, o-ring for speed sensor.
                Anyone know what kind of lube they include with poly bushings? I think Ill need more than they sent.
                  https://www.ecstuning.com/b-powerflex-parts/silicone-grease/pcg1~pfx/?gclid=EAIaIQobChMI_sr169606AIVyf_jBx1AAwEuEAQYBSABEgK9q_D_BwE
                  probably something similar
                    thanks! "silicone grease" - probably will try this https://www.lowes.com/pd/Oatey-Silicone-Grease/50236505?cm_mmc=shp-_-c-_-prd-_-rpe-_-google-_-lia-_-142-_-plumbingconnectionsandsupport-_-50236505-_-0&store_code=2554&placeholder=null&gclid=CjwKCAjw3-bzBRBhEiwAgnnLCqXEIvyluZ1suejDtt6F7e8iGE9Ub0bvaFkeyuO13TgQygChCxpaiRoC-ocQAvD_BwE&gclsrc=aw.ds
                      new wheel bearing pressed in.
                      hub pressed into the new bearing. smooth as butter now. both procedures done with the FWD bearing kit. antiseize applied between the bearing and the trailing arm, for good measure.
                      pulled the ebrake cables. after undoing the nut in the cabin and pushing the cables down from the ebrake lever, i found that when I went to get under the car to pull them from the chassis, they had already fallen out of the chassis. #sorrygabe
                      very little corrosion on either end. I am lucky!
                      started disassembly of the diff by cleaning some of the anti-corrosion coating off
                      just the faintest whiff of the "S" stamp left. i think ill try to repaint it nice in the end.
                        It's like deja vu looking through these last few posts.
                          stage 2 of diff cleaning complete (degreaser, wire brush, rags, garden hose) good enough to crack her open
                          cleaned up more parts, too. don't think i'll need to powdercoat anything, its all in good shape.
                          found a few of the output flange/axle bolts are too damaged to reuse.  07119919620 for my reference.
                          edit: hmm, it appears there is a torx version. this may be way better than the allen head type. however they are m10x43 vs the stock units that are m10x50 - https://www.ecstuning.com/b-genuine-bmw-parts/torx-screw-with-ribs/33207572716/
                          slightly stripped threads on a couple as well. i believe this happens because they drag on the axles when turning them out due to the rubber boots being in the way.
                          removing the stock rubber diff bushing is as easy as cutting through the outer sleeve, then tapping with a screwdriver to pop it free.
                          voila! never force this bushing, you can break the whole mount ear off the diff cover.
                          the diff oil was pretty clean. no burning, no particles.
                          another stroke of luck, 95% of the paper gasket peeled right off
                          LSD unit. not cracking this open yet to replace clutches, the diff still has good lockup.
                            Nice progress Dan. Looks like the parts were just being preserved for you by the grime lol.
                              fo sho!
                              got the output shaft seals replaced. one of the caps from my FWD bearing kit proved perfect for hammering out/in the rubber seal.
                              and the diff rebuild is done. did some more cleaning. good enough for the girls i go out with.
                                i was going to upgrade to the newer e-torx style, but they are too spendy. $15 each!
                                https://www.fcpeuro.com/products/bmw-torx-screw-m10x50-33211227279?ads_cmpid=1586641325&ads_adid=62615222609&ads_matchtype=&ads_network=g&ads_creative=298302774914&utm_term=&ads_targetid=pla-327620319311&utm_campaign=&utm_source=adwords&utm_medium=ppc&ttv=2&gclid=CjwKCAjw95D0BRBFEiwAcO1KDJndtSYrmW2gVzH1ZTHoNQN6YiVLiusiAD8sJSQlXez5pOoxJWMZVBoCemUQAvD_BwE
                                  Which diff oil are you using?
                                  I had one diff that was a little noisy and tried back to back to back fluid changes.
                                  Lucas and Royal Purple were about the same, Valvoline anecdotally seemed to run the quietest of the 3 but it wasn’t a science experiment.
                                    Install solid bushings for proper analysis.  Science.
                                      Yes. They make things sound like a straight cut gearbox!
                                        Actually I was quite surprised at how little noise I had.  That's with aluminum subframe "bushings" and nylatron home made front bushing and stock ancient rear bushings so they probably absorb some.  Maybe the Redline gear oil is just that good?  Dunno, I expected a lot more noise, especially with my trunk being bare metal.
                                          liquid moly 75w-90 gear oil
                                          my diff is not making any noise, though. thats why i didnt bother with input or output bearings or clutch packs. thats for a future day. previous e30 high mile units i've had where making the typical whirring noise.
