580 Posts 27 Posters 0 Views 1 Watching
    yeah, its hard to have a conversation on the freeway
    which i like. its just music, no blah blah blah
      My car use to make a ton of noise when I had the top down....
      I fixed it by putting a car cover on it and never driving it. SURPRISE! No more noise.
        did a rear wheel bearing a month ago, will post that here when i get a chance
        but in the mean time, cleaned the car one last time this weekend. storage wheels will go on in the next day or so and she go into the garage for a few projects over the wenterz
          so the main project over the winter is going to be to pull the rear subframe out, much like @gilber33
          i mainly need to do the bushings, and the chassis-to-subframe SS brake lines, but will be doing the 'while you're in there things', as well.
          i also dug up my previous to:do list and skimmed it to remaining items. don't know if i'll do any of this, but one can hope.
          1. find washer fluid pump/sensor wiring, or add it. reconnect washer tank to hood hoses.
          2. wire in electric fan correctly.  https://www.r3vlimited.com/board/showthread.php?t=210783
          3. Buy ignition cylinder/key to match VIN.
          4. Shadowline window trim.
            Nice festoon lighting.
            If worshiping at the church of the flaming bushing isn't your style, and you're not in a rush to get started, I could send you the subframe bushing puller that I made:
              Mike, that would be awesome. PM sent.
                I'm assuming as a seasoned e30 owner you already know how to do the entire thing blindfolded - but if you have any questions, let me know since I just dealt with it all.
                My first reaction while I was doing it was all of the write-ups online are complete bullshit and it's not as easy and quick as they make it out to be. It sucked.
                  If by any chance this is the Harbor Freight pitman arm puller (ground down a bit) plus plumbing pipe cap and you supply your own two/three jaw puller DIY tool, I've still got the first two pieces that were floating around the group as a shared tool a while back. It "works" as long as your bushing are not original and really stuck in there.  I'd be happy to send it on to anyone who needs. I even have a new cap since I trashed the old one.
                    https://www.bimmerforums.com/forum/showthread.php?1389953-A-better-subframe-bushing-puller
                    +1 on doing it with a puller tool. I had my old bushings out of the subframe in a matter of minutes with a crappy homemade tool (made from some square tube scraps) and a bit of heat from a torch to coax it free.
                      Thanks! I've done all of the jobs that separately add up to rebuilding the rear, just never at once. My car is much less crusty than average so hopefully that keeps me from losing sanity.
                        I'm almost to the rear end rebuilt project. I've been focusing on getting my garage and basement workshop setup for all the future projects so all my spare time has been dedicated to that.
                        Workbench
                        the previous owner of my house left the skeleton of a workbench which, by my best guess, was built by the original owner in the 70s. pretty basic, and the top was completely warped and trashed. it was a good size, though, so i decided to modify it instead of start from scratch.
                        before:
                        after:
                        for the work surface, I ripped 25 2x4s to 3" then laminated them together using all-thread rods to clamp and hold it together permanently. then I just hand planed and sanded the top nice and flat.  on the front face, I added some tee-nuts on the back of the first 2x4 before the glue up so I have several holes for clamping/mounting tools, etc. (you can see them as pairs between the all-threads)
                        i reused the drawers from a reclaimed walnut lawyer's desk and also added two shallow drawers.
                        the tool-wall is just a 4x8 3/4" plywood sheet. the holders are a mix of custom-made plywood brackets, hanging screws, PVC, and magnetic strips.  its hard to believe that up until this point I worked with all these tools out of tool bags, tool boxes, and bins.
                          Very nice! Love the bench top design
                            This is satisfying and inspiring
                              Very nice. Only things missing are a vice and a cold beer.
                                Etsy is a hell ova drug.
                                JK. Nice work man, I love the PVC holders!
                                   i've been trolling for a good solid vise from yesteryear, but havent had any luck finding something local, so i bit the bullet and ordered a cheapish Dewalt. I don't think I'll really abuse it to where Ill need something heavier duty.
                                  lol, i think you mean pinterest.
                                    Or This Old house, whatever you and Bob Vila feel is best for inspiration. 😘
                                    Image result for this old house bob vila"
                                      Tim the Tool Man is my inspiration.
                                        EEUUUUUHHaaa??!!
                                        Image result for bob vila"
                                          EEUUUUUHHaaa??!!
                                          I can only assume that everyone read that in Tim Allen's voice in their heads (or outloud).
