Non-BMW Stuff on a BMW Forum
1.2k Posts 29 Posters 20.3k Views 2 Watching
    gilber33 said:
     I also need it to be completely reliable because I would like to continue taking my daughters on adventures in it and I won't take them in something that I question if it will make it there and back without breaking down.
    yes, but, that one time you break down will be the adventure your kids remember the most.
    i still remember when the alternator died on my parents Astro in the midst of a road trip and the extra pool time we got because of it. i'm pretty sure my dad was not having fun, but we were obviously oblivious to that LOL
      The last time one of my cars broke down it was the alternator that went out while we were 4 hours north at my sisters in winter when it was 5 degrees outside and our oldest daughter was 2-ish and my wife was like 6 months pregnant. I'm still not over it. It was not a fun and memorable breakdown. lol
      Anyways - can anyone confirm if these wires work with this connector? I need to replace the harness for the aux fan switch and I need this plug:
      But I can't confirm if the 90 degree receptacle fits with that plug or if only the straight one does. The original plug for the temp switch has been discontinued.
        i suppose 2 y.o. kids and fetuses don't really fit into the category of 'kids that will remember' LOL
        that 3-pol connector is the straight plug style.
        the 90deg one would has a very distinct flat cap on the back, and I think its NLA at this point
        https://www.turnermotorsport.com/p-10467-61131378412-genuine-bmw-part/
          Correct. I have found that the 90* one has been discontinued. I found this post that labels the new straight connector but it seems to suggest the 90* plug fits? It's difficult to understand which connector works with which plug style.
          I am not confident there is enough room between the aux temp switch and the headlight cover to fit the straight plug with straight wires. It would be very tight.
            you could certainly shove the 90 deg connectors into the straight housing, but you may need to modify it, and there would be no back cap that holds the plugs in. maybe you could just epoxy them in? you could also skip the plug housing completely and plug the connectors right into the sensor, you'd just have to remember/label the locations.
            i believe the 90deg plug might also be found on e36s, although realoem barely shows the existence of the part number. someone here parting an e36 maybe has one?
              That's definitely something to look into.
              I bought the connector and pigtail from someone and when I got it, the wires were bad and the connector fell apart when i accidentally sneezed on it.
                Yes the same one is used on an e36.  You may have the same crumbly results.
                  And they're easier to find for an e36 apparently
                    If you need one I MIGHT have one.
                      I bought the centric rebuilt from turner motor sports when I snapped a bleeder on one of my stock calipers, no complaints. Everything worked well. Not sure why there’s such a significant price difference between them and FCP.
                      Did exactly the same ...for the same reason. Snug that bleeder a little more...doh
                        Mine actually broke while loosening, or rather failing to. I was actually amazed I got any of them open, it looked and felt like it had been a decade since they were last bled.
                          I definitely need one. The one on the car is trash and the spare I picked up isn’t in great shape either. If I don’t find a used one I’ll get the plug and connectors and make it fit.
                            Send me a picture of what it looks like (You have my #) and I can take a look in my pigtail bin!
                              Got a lot of the ac stuff mocked up. Need o rings.
                              Carpets are out and have one rust hole in the driver side  corner and one on the passenger floor. Looks like there was a plug there that allowed some rust to happen or something.
                              It also looks like someone tried jacking the car up by the floor pan since it was all pushed in. A couple minutes later with a big hammer and that’s all straightened out.
                              Now to figure out how to address that hole in the corner.
                                Before
                                After
                                  Anyone have recommendations for best place to get AC o-rings? FCP doesn't carry all of them. AutohausAZ and Pelican Parts do (as well as a couple other things I was going to get) but I have not shopped through either of those stores before.
                                  Amazon sells some o-ring kits, but BMW says I need a 7.65 mm o-ring and the kit has a 7.8 mm o-ring, I need a 11.1 mm o-ring and the kit has an 11 mm o-ring, or I need a 17.12 mm o ring and the kit has a 17 mm o ring. I don't know if that's a big deal or if the o-ring would still work.
                                    If you have a realoem part number search the FCP site by number rather than by car. Sometimes stuff isn't cross listed. You can also call.
                                    I've used Pelican in the past without issue. Typically would take longer to ship given west coast location.  They were bought by ECS in 2017.
                                    I've also used Autohaus AZ in the past for a few things but have not dealt with them for a long while.
                                      I've used both and the transactions were decent. Haven't dealt with Pelican since they were bought by ECS though (not because of that, just haven't as FCP has been my go to lately). If either sells a kit with the exactly correct O-ring sizes, I'd much prefer to use those in my opinion.
                                        I use FCP whenever possible. They just don't have all of the o-rings. RM European actually has the o-rings and the parts I'm looking for a little cheaper than FCP this time. With that said, I would spend a few more dollars to still use FCP if they had the o-rings.
                                          I got all the holes patched and sealed with seam sealer. Next I’ll paint the floors with Por15 to protect everything and do the same on the patches on the outside.
                                          Then need to replace the heater core, put down new sound deadening, dye the carpets and the interior can go back together.
