Non-BMW Stuff on a BMW Forum
1.2k Posts 29 Posters 20.3k Views 2 Watching
    Since I still don't have my bushings or brake lines I've continued tearing apart the car for the other things I wanted to do this winter. This is expanding quite a bit to a "while I'm in there" situation.
    I have the center console and seats out so I can remove the carpet to repair the rust hole, but now that the console is out I figure I might as well replace the heater core. I'll also remove the AC evaporator to make sure that all looks clean. So, the current list is:
    • Finish rebuilding rear subframe
    • Run new front to rear brake lines
    • New front SS brake lines
    • Install AC system
    • Remove and inspect AC evaporator and replace necessary items
    • Replace heater core and o-rings
    • Rebuilt brake calipers with new pads and rotors
    • Repair rust hole in driver side foot-well
    • Clean and dye carpets black
    • Remove rear speaker deck and dye carpet black
    • Install correct washer fluid reservoir
    • Install oil temp, oil pressure, and water temp gauges
    • Still planning on respraying the car
    I think that's mostly it. Although it's a big list, removing the engine is NOT on the list for the first time!!!! lol
    I'm still sticking with my original goal of the car that was to have something that operates as it did when new but I something I can toss around on the back roads when I want to. Something that I can drive whenever and wherever. I also need it to be completely reliable because I would like to continue taking my daughters on adventures in it and I won't take them in something that I question if it will make it there and back without breaking down.
      yes, but, that one time you break down will be the adventure your kids remember the most.
      i still remember when the alternator died on my parents Astro in the midst of a road trip and the extra pool time we got because of it. i'm pretty sure my dad was not having fun, but we were obviously oblivious to that LOL
        The last time one of my cars broke down it was the alternator that went out while we were 4 hours north at my sisters in winter when it was 5 degrees outside and our oldest daughter was 2-ish and my wife was like 6 months pregnant. I'm still not over it. It was not a fun and memorable breakdown. lol
        Anyways - can anyone confirm if these wires work with this connector? I need to replace the harness for the aux fan switch and I need this plug:
        But I can't confirm if the 90 degree receptacle fits with that plug or if only the straight one does. The original plug for the temp switch has been discontinued.
          i suppose 2 y.o. kids and fetuses don't really fit into the category of 'kids that will remember' LOL
          that 3-pol connector is the straight plug style.
          the 90deg one would has a very distinct flat cap on the back, and I think its NLA at this point
          https://www.turnermotorsport.com/p-10467-61131378412-genuine-bmw-part/
            Correct. I have found that the 90* one has been discontinued. I found this post that labels the new straight connector but it seems to suggest the 90* plug fits? It's difficult to understand which connector works with which plug style.
            I am not confident there is enough room between the aux temp switch and the headlight cover to fit the straight plug with straight wires. It would be very tight.
              you could certainly shove the 90 deg connectors into the straight housing, but you may need to modify it, and there would be no back cap that holds the plugs in. maybe you could just epoxy them in? you could also skip the plug housing completely and plug the connectors right into the sensor, you'd just have to remember/label the locations.
              i believe the 90deg plug might also be found on e36s, although realoem barely shows the existence of the part number. someone here parting an e36 maybe has one?
                That's definitely something to look into.
                I bought the connector and pigtail from someone and when I got it, the wires were bad and the connector fell apart when i accidentally sneezed on it.
                  Yes the same one is used on an e36.  You may have the same crumbly results.
                    And they're easier to find for an e36 apparently
                      If you need one I MIGHT have one.
                        I bought the centric rebuilt from turner motor sports when I snapped a bleeder on one of my stock calipers, no complaints. Everything worked well. Not sure why there’s such a significant price difference between them and FCP.
                        Did exactly the same ...for the same reason. Snug that bleeder a little more...doh
                          Mine actually broke while loosening, or rather failing to. I was actually amazed I got any of them open, it looked and felt like it had been a decade since they were last bled.
                            I definitely need one. The one on the car is trash and the spare I picked up isn’t in great shape either. If I don’t find a used one I’ll get the plug and connectors and make it fit.
                              Send me a picture of what it looks like (You have my #) and I can take a look in my pigtail bin!
                                Got a lot of the ac stuff mocked up. Need o rings.
                                Carpets are out and have one rust hole in the driver side  corner and one on the passenger floor. Looks like there was a plug there that allowed some rust to happen or something.
                                It also looks like someone tried jacking the car up by the floor pan since it was all pushed in. A couple minutes later with a big hammer and that’s all straightened out.
                                Now to figure out how to address that hole in the corner.
                                  Before
                                  After
                                    Anyone have recommendations for best place to get AC o-rings? FCP doesn't carry all of them. AutohausAZ and Pelican Parts do (as well as a couple other things I was going to get) but I have not shopped through either of those stores before.
                                    Amazon sells some o-ring kits, but BMW says I need a 7.65 mm o-ring and the kit has a 7.8 mm o-ring, I need a 11.1 mm o-ring and the kit has an 11 mm o-ring, or I need a 17.12 mm o ring and the kit has a 17 mm o ring. I don't know if that's a big deal or if the o-ring would still work.
                                      If you have a realoem part number search the FCP site by number rather than by car. Sometimes stuff isn't cross listed. You can also call.
                                      I've used Pelican in the past without issue. Typically would take longer to ship given west coast location.  They were bought by ECS in 2017.
                                      I've also used Autohaus AZ in the past for a few things but have not dealt with them for a long while.
                                        I've used both and the transactions were decent. Haven't dealt with Pelican since they were bought by ECS though (not because of that, just haven't as FCP has been my go to lately). If either sells a kit with the exactly correct O-ring sizes, I'd much prefer to use those in my opinion.
                                          I use FCP whenever possible. They just don't have all of the o-rings. RM European actually has the o-rings and the parts I'm looking for a little cheaper than FCP this time. With that said, I would spend a few more dollars to still use FCP if they had the o-rings.
