  4. T4r feat White Whale
59 Posts 10 Posters 0 Views 1 Watching
    So, I sold the e34 touring and bought a Volvo!  Pretty excited, it seems like a great car so far. I refuse to buy a Wisconsin car, so I had it shipped from Portland, OR. It was a Denver car for 1 year, then a California car for the rest of its life (no rust!)
    2005 Volvo V50, 2.5t AWD 6-speed Manual, Passion Red w/dark grey interior
    Options: Premium audio, Bixenon headlights, heated seats, aftermarket tow hitch, factory tint
    The drivetrain is a pretty rare combo, and the m66 trans is very robust. I looked for a long time for an AWD/turbo/manual Volvo and missed a couple that were out of state because they got snapped up right away. I considered v70s and v70Rs, and xc70s as well, but I'm happy I landed on this one. I also looked at small trucks but they did nothing for me - I'm really just a wagon guy.  The fiance is happy for the red color, because it looks a lot less like an old man car. 😂 It will be a great Wisconsin winter vehicle.
    I have not taken any good photos yet, as she is under the knife and in a few pieces and not registered yet.
    Photo from the ad:
    Volvo fans may call this 'not a real Volvo' because the P1 chassis platform was a joint Ford effort and is shared by the Focus and Mazda3. I agree that it doesn't have the better old boxy Volvo look, but it actually handles well, has a turbo, and its a wagon, so its good enough for me.
    Plans
    Remove drug dealer window tint
    Remove fading/failing clear vinyl bra on hood, fenders, bumper, side mirrors.
    Remove hack-job aftermarket trailer wiring, install factory trailer wiring
    Snow tires on factory wheels
    Add Yakima roof rack bars
    Repaint/dye all the black trim
    Polish headlight plastic and upgrade the bixenon headlights to better projectors.
    Add factory rear spoiler
    Add AUX input or Bluetooth
    'Stage 0' tune up
    Flush Haldex unit and rear diff, install 1/8 NPT drain plugs
    Purchase OBDII scanner
    Resist urge to modify the engine
    I'd also like to thank resident Volvo expert Tom for his invaluable advice!
      That red is perfect for a mooserarri sticker... nice buy!  I loved my Volvo wagon and our XC90 continues to run strong.  I think you'll like it!
        I think the prancing moose is hilarious, but the ferrari yellow badge is just unsightly though.
        i think you're right that i'll love it!
          Congrats on the new ride!!
            I would be surprised if you didn't think this was the best winter car you've ever had.  I think this has the Haldex AWD and if it does it is such a joy in the snow!
              All I've had is RWD BMWs, so yes.  Its Gen II Haldex on an 05 v50 - electronically controlled clutch, FWD only until it its activated by wheelspin. Is an obviously inferior system compared to other manufacturers from an offroad or extreme performance perspective, but its perfect for snowy roads. It has no traction control, which makes me so happy
              tack själv!
                Sweet! Can't recall the last time I saw a red Volvo in general.
                  Looking forward to see you at ice racing this year!
                    tack själv!
                    I'm not sure you will think  it is inferior after driving it.  You would think that you could feel the wheel slip and then engagement of AWD but you can't even tell.  It does vary the engagement as well.  Yes it is limited to a certain horsepower that it can transmit to the rear.  But on the P2R I had it would oversteer and do donuts on slippery surfaces if you were fooling around on purpose.  If you didn't want it to slide though it was very planted.  Mine also had the gen2 Haldex.  Change the fluid and filter with only genuine stuff.  Yes it's expensive but way more expensive if it fails.  And to get the pump out the driveshaft needs to be removed.  I added drain plugs to mine by drilling and tapping 1/8 NPT holes at the lowest point in the sump.  Drill while full of oil so the draining oil flushes any chips out.  I also did that for the rear differential.  The custion method doesn't nearly get all of the oil out.  Nice find with the M66, that's a very solid transmission.
                      and thanks for the advice on the fluid change and drain plugs. in all my DIYing, i've never drilled/tapped a hole so I'll be sure to practice first. volvo parts are as definitely as expensive as BMW stuff, so I'd prefer to keep it unbroken.
                      did you add a drain plug like so:
                      https://www.amazon.com/Stainless-Plug-replacement-60328-98B-60328-98A/dp/B006WNPZTK/ref=pd\_sbs\_263\_img\_2/140-3274792-3087540?\_encoding=UTF8&pd\_rd\_i=B006WNPZTK&pd\_rd\_r=36ed3cc1-c717-4680-b48e-b963abea1d9a&pd\_rd\_w=F4HeN&pd\_rd\_wg=prqZr&pf\_rd\_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf\_rd\_r=4DC1CCJ155K3Z1BKW6A5&psc=1&refRID=4DC1CCJ155K3Z1BKW6A5
                      i did really want a P2R, but i discovered a v50 2.5t with a stage 1 tune is the same power/weight and you avoid most of the expensive "R" parts.
                        https://www.amazon.com/Stainless-Plug-replacement-60328-98B-60328-98A/dp/B006WNPZTK/ref=pd_sbs_263_img_2/140-3274792-3087540?_encoding=UTF8&pd_rd_i=B006WNPZTK&pd_rd_r=36ed3cc1-c717-4680-b48e-b963abea1d9a&pd_rd_w=F4HeN&pd_rd_wg=prqZr&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=4DC1CCJ155K3Z1BKW6A5&psc=1&refRID=4DC1CCJ155K3Z1BKW6A5
                        Just a pipe plug like this.  They have tapered threads so you use some kind of thread sealant.  You can buy them at my store as well.  I have a picture somewhere, I will try to find it.
                        Tapping tapered threads is pretty forgiving.  The farther in you run the tap the farther in the plug will go.  So you can test it and then tap farther if needed.  It is aluminum so it is very soft and easy to drill/tap.  The main thing is to be careful that you drill the hole straight on and also to keep the tap straight.
                        https://www.amazon.com/Anderson-Metals-Brass-Fitting-Square/dp/B006PKKSH4/ref=sr_1_6?keywords=1%2F8+npt+plug&qid=1571414981&sr=8-6
                        You don't want a P2R.  Volvo parts are insanely expensive compared to BMW parts.  At least compared to e36 parts.  The engine isn't much different from a 2.5t to the R trim.  The R I think has lower compression ratio because stock is 1 bar (14.5 psi) boost, 8.5:1 if I remember right.
                          I can make the prancing moose sticker in any color you want! 👍
                            yeah, lets match the paint!
                            got some things done.
                            Removed the tint from all 7 windows.
                            seemed like a factory or dealer tint. the edges were shockingly far under trim/gaskets, i had to pull off door seals and remove the rear hatch trim to get at them. this was a b*tch of a job. most came off with a heat gun, razor blade, and finally with adhesive remover for the residue.  the rear window refused this method and had to be bagged for 2 days with amonia, followed by careful scraping around the defroster lines. also found that the luggage area passenger window has defroster lines, which will be nice to have.
                            Roof rack installed
                            I went with an older style rack to utilize my round bars and attachments. Yakima RailGrab, with medium clips modified per the photo below. 58" bars
                            7f5d96d0-c2ad-4325-948d-3f8d613a857d1.1
                            Modified clips:
                            Removed the poorly done trailer wiring
                            they had the power source for the controller plugged into a cigarette lighter, instead of hardwired in...
                              headlights done (well almost, still need to apply the lamin-x)
                              loving the simplicity of assembly on the volvo. the headlights come out by removing 1 pin and disconnecting 1 plug. it takes approx 10 sec to get them out of the car.
                              as you can see, the headlights were hazy and very pitted
                              polished them up first, using the pretty standard method of decreasing grit sandpaper followed by a final polish. I will be sealing them with lamin-x
                              in order to remove the big pits, i started very agressively with the grit and wetsanded 220, 400, 600, 800, 1000, 2000, 2500 followed by polishing compound with a DA orbital.
                              after all the wetsanding you are left with this:
                              hit it with the polish and here are the results:
                              of course, I am obsessed with proper lighting on all my vehicles, so even though this car came with factory bixenons, I still upgraded them.
                              these volvos actually come with an almost identical version of the AL/Bosch projectors found in e46s. their performance is not spectacular and they are known for wearing out the reflective coating on the bowls.
                              I upgraded to Morimoto Mini D2S 5.0 projectors, 3800k bulbs, and kept the factory 35w ballasts. I would have liked to use the bigger FXR projectors i have sitting in my parts bin, but I decided it wouldnt be worth my effort to crack open the headlight and possibly make the self-leveling feature of the factory lights inoperable. As a bonus, the Mini D2S setup is completely reversible to the stock setup if I ever sell the car or need to replace a broken headlight.
                              Disassembly:
                              of course the cat had to help
                              factory projector vs the morimoto (the morimoto on the left)
                              the retrofit source, where i get most of my parts, has mini D2S to Bosch/AL brackets which is normally used for people fixing their e46s, but it fits the volvo as well. it is the black bracket in the photo below.
                              used a combination of spacers to get the projector sitting far enough back to clear the plastic headlight bracket.
                              the factory ignitor fits on the back of the morimoto projector:
                              boom, done.
                              I also upgraded the 'city lights' to W5W amber LED bulbs while i was in there.
                              another bonus is that volvo left the high beam even with the factory bixenon setup, so you get quad high beams!
                                Nice!  They improved the headlight removal method from the P2R... To get those headlights out you have to take the bumper cover off...  A couple things learned from Ford I guess.
                                  more work on the clear bra removal. the process I was using was going to be too slow and drive me nuts, so I found something better.
                                  3M Stripe off wheel. Its essentially a rubber wheel that rubs stickers/glue, etc right off the paint. It was unnerving to use at first, but my test corner suggested it wouldn't be a problem. the only drawback is it is not safe to use on plastic body parts like bumpers.
                                  my guess is this bra was installed when the car was new, or soon after. very dirty, scratched, and cracking to pieces
                                  mount the stripe off wheel to a drill and run at 2000+/- rpms and just grind your sticker/bra off.
                                  after wiping the rubber residue off with a little alcohol, the paint underneath looks perfect.
                                  the nose of the hood after once over.
                                  and the final product after wipe down. despite this being a pain in the ass, the clear bra did protect the paint all these years. TxZRhsuh.jpg
                                    to my dismay, the car also arrived with a check engine light, stumbling idle and a belt squeal when the car warms up. i definately have to solve the CEL before registration.
                                    I snagged anOBDII reader with some volvo specific software in it. iCarSoft Volvo/Saab i906-II. I needed one that can also generic scan other cars(for the lady's mazda). I've learned there is a great diagnosis software/reader for Volvos called VIDA/DICE, but its stupid complicated to setup (need an old laptop still running some specific Windows version) and you have to buy shady CD software to get it working so I didnt want to bother.
                                    The scanner worked great. I was able to pull a few codes ECM-310C (Misfire, one cyl), ECM-315C (Misfire cyl 5), and ECM-313D (Misfire cyl 3). The codes suggest a spark/fuel issue specific to cylinders 3/5. I am planning on a 'stage 0' (basically getting maintenance up to snuff) so I decided to just fix spark first and go from there. I threw 5 new Bosch Iridium plugs and 5 new bosch coils at the car, and it fixed the running issue. The car pulls really good, its got more pep than the e34 had.
                                    coils and plugs are very easy on this car, no different than a bmw 6.
                                    also changed the oil (134,400) and threw in a new oil plug as the old one was nearly stripped.
                                      more light stuff.
                                      I upgraded the fog bulbs from H11 to H9s, which is merely a 10w bump. chose a yellow bulb for better visability.
                                      also had one running light burnt out, so i got some w5w amber LEDs, which look nicer than the stock halogens.
                                        I have a Vida/Dice setup.  It isn't as bad as it sounds.  I just ran it in an Oracle virtual machine on my Surface Pro (Windows 8).  The functionality is amazing.  Test fire a fuel injector, see inputs/outputs of every module, it's all there.  It's pretty cool.
                                          it sounds super helpful. i am keeping my eye out for an old free/junker laptop that has windows 7. any ideas for sources that will be reputable for the reader and software? seems like it might just be a crap-shoot ordering from Chinese companies on ebay...
