Non-BMW Stuff on a BMW Forum
    gilber33 said:
    Any benefit to using pipe VS hose to hook the two tanks together? Obviously using some short sections of hose and fittings would be much easier.
    You could, I use hose because it is portable and easily reconfigured.  I usually use a pretty short hose between the compressor and extra tank, it flows pretty fast even with a regular 3/8" hose that is 25' long.  I like to fill the portable tank and then unhook the hose and drain the compressor.  Then I can use the tank on wheels for airing up tires and little things until the pressure is too low and it needs filling again.  I would recommend thread sealant like Rectorseal 5 to make a perfectly leak free system.  Thread tape can be ok but sometimes leaks.  You can get a jar for a couple bucks at my store.
      I’ll use regular hose. I’m going to build a rack that will stack the 2nd tank on top of the compressor, so the hose will only be a couple feet connecting the two.
      First tank acquired  though!
        You will want at lease a short section of flexible.  The aircompressor vibrates when running....a lot, the expansion tank wont.  The vibration load on the connection, if all solid, will cause something to crack at some point.
          That’s a really good point. I didn’t think of that. I’ll use regular compressor hose since the distance will be so short.
            Got it all home.
              #wagonlife
              those tie-down rails are awesome. thats volvo right?
                #wagonlife
                They really are. I use them pretty regularly. And yes, ‘08 Volvo XC70.
                  How about some e30 content?
                  All cleaned up for Road America tomorrow.
                    Great weather for being at the track. One of the few events I didn’t make it to this year. Hopefully you got to see the F1 cars run. Judd V10s ♥️
                      It was a lot of fun and my girls enjoyed it which is always awesome.
                      Tonight I got the air compressor hooked up. Not super thrilled with the overall look of it but it will be fine until I redo the garage next year.
                      I still need to do some hose management, so please ignore the crazy hoses.
                        Been driving the car to work once in a while and I've noticed that the oil pressure light stays on for a couple seconds on cold starts. I'm going to get a new oil pressure sensor, but I'm just curious what people's thoughts are? It didn't always do this. I remember it turning of instantly - I think even with this engine when I first got it back in.
                          At least for the e36 its actually in the owners manual that the oil pressure light is supposed to be on for 1-3 seconds after startup.
                            If you’re worried slap an aftermarket gauge in it for some redundancy
                              I looked into this and I think I’ll add an oil pressure gauge.
                              Now I need to decide if I should just go with an oil pressure gauge and do a single gauge pod in the vent or go with three gauges and do the ash tray gauge mount. Probably oil pressure, oil temp, and something else. But that seems like overkill in a stock car.
                                Overkill?  Is that a thing?  Anyway, coolant temp is always nice, the stock gauge is all but useless with the large buffered spot in the middle.  If you add an oil pressure gauge use a T so you keep the idiot light.  A gauge is not eye catching enough unless it has some kind of programmable limit with a warning light.  Also depending on the sending unit size/weight I usually remote mount them so the large sending unit isn't hanging from a vibrating engine by a 1/8npt nipple.
                                  So far my favorite option for the oil temp and pressure is the oil filter sandwich plate. Seems to give the cleanest install. Bimmerworlds sells a nice adapter for the oil pressure sensor but at $110, I'd rather not. I can use one of the spare ports on the thermostat for water temp.
                                    I’m not too sure about the m20 stock oil psi sender location, but if it’s m12x1.5 these should work(?)
                                    https://rallyroad.net/products/oil-gauge-distribution-block
                                    TRM made a super simple one that was like $24 but it’s on back order
                                    there’s a similar one (to the trm) on fleabay for like $30 -looks like you lose the stock sensor though so probably not ideal
                                    https://www.ebay.com/i/193104157545?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=193104157545&targetid=475515225101&device=m&mktype=pla&googleloc=9019303&poi=&campaignid=6469750765&mkgroupid=79220279682&rlsatarget=pla-475515225101&abcId=1141186&merchantid=6296724&gclid=EAIaIQobChMI-bO-1KXw5AIVjsDACh1DcweoEAQYAyABEgJCdvD_BwE
                                    bimmerheads has one for the m20 for like $35  but it’s also out of stock...
                                    i used the VDO vision gauges in my e30s. They are a fairly close match to the cluster if you’re after some period correctness. Just make sure when/if you buy senders you match the sweep of the gauge (most of the visions are a 90° sweep)  and the overall range (0-250°F or whatever)
                                    https://www.vdo-gauges.com/instruments-displays-and-clusters/by-series/vision-black.html
                                    Decently priced as well. I run water temp/oil temp/oil psi where the radio used to be. There’s a lot of options for mounting gauges in these cars, but you usually give something up - a vent, center console pocket thing, radio, obc, etc.
                                      Working on removing the rear subframe to do TAB and subframe bushings. It’s read to come out except for the e-brake cables. Looks like the rubber tube from the car to the hub is all part of the cable assembly. And from reading other threads they can be a real bitch to remove. Anyone have any tips or tricks to remove these from the car or hub before I just cut them in half and buy new cable assemblies?
                                        No, you got the right idea.
                                          I think they are similar to e36 cables.  If you spray them with some penetrating oil you can wiggle them out by tapping or prying one side then the other.  It is just a tapered fit that wedges tight.  It depends how nasty everything is though.
