‘91 E30
How hard do you suppose those shorties would be to install in a car. Do the primaries block studs?
I’ll get some better pics for you
Also needed to fix the lift point. The top most bolt hole for the lift bracket was all blown apart. I wanted to just re tap the remaining area, but I Was not able to get a tap through whatever material that threaded portion was. Could barely drill it out to the right size.
Decided to buy a stud and just jb weld the cock sucker in because it only needs to work one more time anyways. Had to re tap that lower lifting bracket bolt hole as well because the threads were junk.
Also got a rethreaded brown temp sensor so the dash temp gauge will work. Had to chase those threads as well. I’m getting very familiar with my tap set lately.
Correct TOB and new reverse switch hopefully get here Saturday, so I can get the trans tossed on.
good info on the headers and TOB
forget the lift point, just throw the chains around the spider hose, they are super strong and never break.
I’ll get a comparison shot of the regular zf tob vs the 323TOB. Should be a difference of 4or5mm. Which should make up for the difference of dualmass/non dualmass flywheel. I want the clutch to engage not directly off the floor
lol at spider hose. Should just lift it from the ICV hoses. Those things never break either
As long as you have URO brand you should be fine.
Mitch only buys URO brand. Must be why his cars are always taken apart
️Careful, you are treading dangerous waters with comments like those. I will unfriend you on facebook
Just a slight difference
Right lol
