  4. ‘91 E30
‘91 E30
510 Posts 27 Posters 7.2k Views 4 Watching
    How hard do you suppose those shorties would be to install in a car. Do the primaries block studs?
      I’ll get some better pics for you
        Got sent the wrong TOB. Ruined some stuff on the trans. Slow progress
          Headers are on
          By far the easiest set of aftermarket headers I’ve ever installed on these motors. Room to get to every nut/stud from the top side
            Also needed to fix the lift point. The top most bolt hole for the lift bracket was all blown apart. I wanted to just re tap the remaining area, but I Was not able to get a tap through whatever material that threaded portion was. Could barely drill it out to the right size.
            Decided to buy a stud and just jb weld the cock sucker in because it only needs to work one more time anyways. Had to re tap that lower lifting bracket bolt hole as well because the threads were junk.
            Also got a rethreaded brown temp sensor so the dash temp gauge will work. Had to chase those threads as well. I’m getting very familiar with my tap set lately.
            Correct TOB and new reverse switch hopefully get here Saturday, so I can get the trans tossed on.
              Oh and swapped out the pilot bearings for the larger one to accommodate the zf. In case anyone is curious about your shaft size I have included a pic of the difference
              side note: 20ftlbs always seems like next to nothing for the pressure plate bolts
                good info on the headers and TOB
                forget the lift point, just throw the chains around the spider hose, they are super strong and never break.
                  I’ll get a comparison shot of the regular zf tob vs the 323TOB. Should be a difference of 4or5mm. Which should make up for the difference of dualmass/non dualmass flywheel. I want the clutch to engage not directly off the floor
                  lol at spider hose. Should just lift it from the ICV hoses. Those things never break either 👀
                    As long as you have URO brand you should be fine.
                      Mitch only buys URO brand. Must be why his cars are always taken apart 🤷🏼‍♂️
                        Careful, you are treading dangerous waters with comments like those. I will unfriend you on facebook
                            What is this "Facebook" you speak of? Did you mean unfriend me on Myspace? Oh no, please, no.
                              TOB comparison
                                Just a slight difference 😂
                                  Right lol
                                    Some progress. Just have the rest of everything to finish
                                      Goal is to make it to shawano autox on the 22nd. Brooke offered up her evo for co-driving and these just showed up so it may be difficult to want to drive the e30 instead
                                        The engine install looks a bit like Hungry Hungry Hippos. Drive both cars and exchange for a run each. I’d love to see it somehow beat Dr. Evo
                                          Getting closer
                                          Pretty much just have engine bay stuff to do and torque every nut/bolt on the car. Exhaust is halfway installed
