Non-BMW Stuff on a BMW Forum
    Hey guys- so what am I looking for to check both the universal joint on the driveshaft and the CSB? The driveshaft is out for inspection.
      The joints need to move smoothly with no grit, binding, or increase in resistance. When you grab the yoke and the shaft and check it for freeplay, there should be none.
      CSB should have no cracks in the rubber and the bearing should be tight and quiet as it rotates.
        Got the block back today after a hone. Started cleaning up the pistons. One is kinda done and two others are soaking in carb cleaner for the night. AEE7C8C6-E2A4-41CF-8BB1-8AC561D95601.jpeg
          In regards to the two connectors Chris identified,  the first 2 things to check when an M20 isnt starting after a teardown is
          1. did the fuel lines get swapped?
          2. did those two connectors get swapped?
          IMO Cleaning up an engine is the most satisfying part of wrenching.
            Crank and new main bearings is in and the pistons are all cleaned up.
            Doing the crank was way easier than I assumed it would be. Which always makes me feel like I did it completely wrong. 😩
              After doing some more reading, I’m going to pull the crank back out to clean the bearing seating surfaces a little more thoroughly on the block and caps. And then reinstall the bearings and crank. Better safe than sorry.
                Redid the crank bearings last night and I’m glad I did. I didn’t clean it as thoroughly as I could have before. Cleaned all the piston rings grooves and started measuring ring gaps.
                The Bentley Manual calls for a .012 - .020 gap and all the rings came in at .013 on the first two cylinders. Looks like I might be able to get away without having to do any filing.
                  Did you check clearance with plastigage?
                    Nope. In my mind, if it was fine with the old bearings in there before, it’s going to at a minimum be better with new ones.
                      Not that I haven't done the same, but from a manufacturing standpoint this is terrible logic.
                      I'm glad you get to avoid filing rings, that's a tedious task that usually requires a spare ring or two!
                        I knoooowwwwww. I guess I can check the clearances. I’ve taken back apart once. I know you’re supposed to do it it dry but I’ve already lubed it up. Will I be fine taking the crank out and wiping down the bearings to remove most of the oil?
                        Also, can anyone confirm that the bearing clearance should be between .03-.07 mm?
                        edit: bought some plastigauge. I’ll pull the crank off and wipe down the bearings and measure the clearance section.
                          Pulled the crank back out tonight, cleaned off the bearings, put it back in with plastigauge.
                          .038 across the all 7 caps. Very healthy. At least I know now. Also got three pistons ready to go in.
                            Pistons back in. All clearances are on the bottom end of what is required in the manual.
                              allow myself to introduce...myself
                                I had a panic attack for you and then realized you must mean .038 mm, which is about .0015 inch which I would say is perfect if I remember right.  I think spec is .0008 to .0018 but it has been a while.  How I can remember correct bearing clearances but forget half of the stuff I need when I go to the store I don't understand.
                                  Lol. Yeah. .038mm.
                                  I remember very random car details and then I’m like what’s my kids’ names again?
                                    Slowly but surely. Building our 2yo a playhouse for her 3rd birthday and gotta start on a garden shed so this has taken a back seat unfortunately.
                                      Playhouse build thread time
                                        Lol. Nothing super exciting. But, she’ll be thrilled when it’s done. We’re telling her it’s a tool shed for the lawnmower and she can’t play in it. It’s For her birthday next month.
                                          I wanna make sure this is right or wrong. I’m replacing the front crank seal and it looks like the outer lip of the seal doesn’t sit flush against the crank. Is this right? It doesn’t feel like it should be. It’s an elring seal.
