  4. E46 Things
E46 Things
359 Posts 23 Posters 5.4k Views 2 Watching
    The HDR setting on my phone turned itself up to 11
    Replaced: Cabin filter, VANOS filter, AC belt
    up next is a fresh oil change
      Fuck, I need to get another E46 again.
      Do you also not have fog lights?
      Reason for Red Line motor oil over Mobil 1? I’m sure it’s not cheap.
        Fogs are not installed. I am still not sure which look I like best. Leaning towards no fogs.
        The typically used 10w-60 oils are Castrol TWS, BMW/Shell TwinPower Turbo, LiquiMoly, Redline.
        Bimmerworld recommends Redline and I can get it locally at Pegasus or Behling if I ever need to top off.
          no fogs and run ducting to the brakes 😈
            1,100 miles in
            Oil changed.
            Rock collection tray cleaned.
            Oil level sender o-ring replaced, though I think whatever small leak exists is coming from elsewhere.
            85C6FB24-DC43-4E26-AC9B-17D5B7C5DF5D.thumb.jpeg.35c48885810d3d8947e5fa49ce25df69.jpegC839B495-6D30-4679-8351-31CA7FD18BA7.thumb.jpeg.3c49dd6a1c752cef88bee02b92e14b19.jpeg
              I am very happy to see you taking good care of this car. It's come quite a long way since it was a cheap fb marketplace find last year.
                You are incapable of not taking things apart.  Nice job.
                  I felt this one.
                  Good work on fixing all of the little annoying stuff!
                    I never got a good look at this thing before you drove off on Saturday 😦
                      Thanks for moving the cone for me though
                        Cough, amber tails, cough.
                          I am having, what would seem to be the beginning stages of a failing fuel pump, leaking injectors, or a cam sensor on the fritz.
                          Occasionally the car does not fire up on first crank attempt. but always does on second attempt as if the mixture/fuel pressure is not right. I do wait for the fuel pump to finish priming before starting and that does not make a difference.
                          I will connect the laptop tonight and see if any codes are stored.
                          It does appear to be a common issue and I did find this posted hinting at summer blend fuel in cold temperatures. Plausible as it was chilly this morning.
                          someone said:
                          SI B 13 01 08
                          Fuel System & Control
                          January 2008
                          Technical Service
                          SUBJECT:
                          M3 S54 - Crank/No-Start on 1st Cold Start Attempt
                          MODEL:
                          E46 (M3) with S54
                          SITUATION
                          The customer may complain that during the first cold start, or after the vehicle has been parked for more then 6 hours, the engine would crank but not start on the first attempt. The engine will start immediately during the second cranking attempt without any running issues. The problem is currently present and reproducible in the workshop.
                          No faults are stored in the DME control module. Testing of the fuel pressure, volume and bleed-down pressure do not detect any problems with the fuel delivery system. Also, further diagnosis of the engine electrical components (scope patterns of injectors, ignition coils, crankshaft and camshaft sensors, etc.) shows that all the systems work as designed.
                          CAUSE
                          Gasoline fuel blends with low volatility (Reid Vapor Pressure or RVP too low for winter temperatures).
                          Fuel volatility is defined by ASTM standards and regulated by federal and state legislation. Volatility in different geographical areas is affected by many factors, including state regulations (for example, oxygenated fuel requirements), local altitude, local temperature ranges, refinery capacity, and distribution logistics. Volatility is not related to gasoline octane rating (AKI).
                          Shifts in fuel volatility occur during seasonal fuel changeover periods. Lower volatility summer fuel (typical range 6 - 10 psi RVP) is changed to higher volatility winter fuel (9 - 14 psi) in the fall, and then back again in the spring.
                          A cold start situation may occur if a non-homogenous summer fuel blend is introduced into the fuel distribution system and thus the vehicle fuel tanks, when winter fuel is needed.
                          CORRECTION
                          Do not replace any components.
                          Advise the customer to refill the vehicle with a brand name TOP TIER detergent gasoline with a minimum octane rating of AKI 91.
                            Probably the head gasket.
                              I will order 2 new head gaskets just in case the first one is defective
                                No start on first attempt condition happens at ~70F ambient temp which rules our the BMW TSB about the summer blend fuel at cold temps.
                                INPA shows codes: 178 196 197 198 204 205 206 213
                                these are misfire and catalyst efficiency codes.
                                Someone else’s experience with the same codes and symptoms confirms the fuel pump theoryFE114401-8EB9-41FB-9540-6161A3C2768D.jpeg.83f6c360b424f6adc3b81be922cf1eef.jpeg
                                  This morning the car fired up on first attempt rather than second but it took just slightly longer to fire up than ideal. I reset codes, reset adaptations, drove to work, everything running perfectly as usual. I checked for new codes when I got to work and there were none.
                                  I will check for fuel pressure bleed-off when I am underneath removing the CDV in the coming weeks and see if by chance the fuel filter needs to be snugged down just a little more even though I had checked for leaks pretty thoroughly after replacement. If things continue/deteriorate, my first check will be to pull the fuel pump and see if the rubber hoses on the pump are leaking before ordering a new pump.
                                  The best price I can find at the moment is Bimmerworld or Tischer for $370
                                    It almost sounds like it's not getting enough air.
                                    I think VF Engineering makes a centrifugal air pump that should help remedy this situation.....
                                      I think he's right.
                                        All is normal for the while. This week it will surpass my van for the title of highest mile vehicle in my household.
                                        (Datsun is a 2006 with 112k, van is a 2006 with 155k, M3 is a 2005 with 155k)
                                        Pointless post, just happy to be driving this car though.
                                          Nearly 2,000 miles on the car this driving season.
                                          CEL illuminated last night. I had my Bluetooth dongle in the center console so I popped it in:  P0420 (meow)
                                          Cat efficiency below threshold.
                                          I checked the Carfax report and the BMW recall for the DME reprogram has already been done back in 2009. It allows more leniency in the rear O2 sensor readings before registering a CEL.  Reset the CEL and did a few full throttle runs to get things nice and rich but it hasn't returned in 3 drives adding up to about 30 miles. Checked codes with INPA and nothing is stored. I'll consider it a fluke for now, at very worst there are plenty of folks upgrading their headers and selling stock cats cheap.
                                          It has been starting just fine, im considering the start on 2nd attempt also a fluke.
