  4. New Daily Driver - E90 328xi
48 Posts 9 Posters 925 Views 1 Watching
    Pulling the old one off the radiator is also a major pain. It must have taken me 20 minutes of gently prying on the connector portion of it with a screw driver and just rocking it back and for in each direction by hand. I cut it in half to get a better grasp on it as the part that connects by the oil filter housing came off without issue.
    I’m liking the ease of working on this car so far except for the cooling system, which seems to be complicated and fragile for no reason. I’d very much like to go back to rubber hose and hose clamps, but I suppose that’s the way of the world.
      I did the E46 cooling system, which was not terrible, but is also made of out of tooth picks and gum. I am dreading having to do the water pump whenever that gives up the ghost. But all my hoses are still in good condition, still soft and pliable, so not of an immediate concern.
        It was this cars time for the cup holder to be replaced. Last year I discovered the tab on the back of the assembly had broken, but wasn't an issue. I'm guessing with the now firmer suspension, things are a little more evident. Has been rattling a lot more recently, so it was time to be replaced. This is the $25 one from amazon. OE non BMW ones are $80 so figured I would give this a go first.
        This is where you can see the difference of the tab and the broken off tab.
        Finish is good, has the same soft touch rubber as the OE ones do.
        Fit was a little wonky. The bracket on the left was a little too big, so I had to grind it down a little to fit. Even still, kind of had to push it in, where as the OE one just slides in nicely. First drive I didn't notice anything, but we will see how it goes. The cup holder does slide out much faster though, kind of shoots out as opposed to the OE one that gently slides out.
        Also flushed the power steering fluid. I had the reservoir replaced when I had the valve cover done a year ago, but guessing it was just topped up with fluid and not completely flushed.
        I'm not super familiar with power steering fluid wear rates, but I am guessing that this was probably ready for a change. There was really no indication that anything needed to be done, it was just something that was any easy fluid to replace and I had no record of when it had been previously done.
        Brake fluid flush and coolant flush soon and then every fluid in the car should be replaced.
          A lot of sweat labor this weekend. Almost 24 hours between Friday and Sunday to paint correct and coat the car.
          Everything to do the job.
          Chemically and mechanically decontaminated the car before correction. This means strip wash, iron remover, and then clay barred.
          I hav never seen more iron deposits on a car than this one, example below.
          Iron remover doing its job.
          There was a lot.
          This step made a significant difference in the overall color of the car, the color job "popped" a lot more.
          This step took about 6 hours including drying, jacking car up and removing wheels(iron removing them as well) and taping off to prep for correction the next day.
          Found @MPW3RLee's vice grip in the process.
          Start of a long day of polishing and coating.
          I used a Rupes polisher with Meguiars microfiber cutting pads with Jescar correction compound for the first pass.
          I then used a foam yellow pad with Sonax perfect finish to complete the process.
          This is the lightest color car I've ever corrected and it's much more difficult to see where you've been, what you've done, etc. The before and after's are not nearly as dramatic as they were with my E30(that had dead paint though). I didn't take any pictures because it was really hard to show the difference, but the improvements were notable. Much more clarity and depth. Not concurs ready though, it's an almost 15 year old daily so I didn't want to spend 20 hours alone polishing this.
          I followed the correction with Gtechniq CSL for the base layer, with 2 coats of Gtechniq EXO V4 including the wheels. I did this on my E30 and loved the result. Added quite a bit of gloss to the finish as well.
          It probably looks the same as before, but some pictures. I also took the badges off so I could correct everything, and will probable leave them off. I like the clean look.
          Some small details as well.
          New wheel center caps. The existing ones had this gunk on it that I thought was some kind of road grime or hardened fluid, but I think it was actually the plastic corroding. I tried to pick it off and it removed all the finish beneath. Instead of spending $60 or whatever the going rate for real center caps is, cheapo Amazon ones it is.
          Looks much better. If these fail quickly I'll just buy OEM ones. I will need to get new roundels front and back as well at some point as they are showing signs of failure but still relatively good condition.
          And finally, fixing my turn signal. When I took these off months ago to polish them originally, the little metal clip on the back fell into the fender. It's been double sided taped since. Cheapo Amazon to the rescue again, but not for the turn signal itself, but for the metal clip. A new OE turn signal is almost $40, and mine is in good condition, so I bought these cheap ones just to get one of the clips.
          Gross.
          This is what I needed. Threw these in the garbage promptly after. I had to pretty much destroy the plastic stalk to get it out any way.
          I didn't polish the front bumper because of how scuffed it is. I would like to do an M sport bumper this year, but I would also like to do a new set of headlights at the same time as you have to remove the bumper to replace the headlights. I would like to do the projector headlights as well, but I STILL have not found a definitive source of someone completing this swap except for one video that is rather vague despite every thread saying that this has been discussed ad nauseam.
            Was tired of walking everywhere at Road America, so I bought a bike. 29”Specialized Rockhopper comp.
            Needed to get the bike there, so I bought BMW roof rock and a Thule top ride bike rack.
            Bike goes on the rack easy, rack comes off the bars easy. Wasn’t whistling like I’ve heard some people say they can. Only really felt the drag of it when I was passing someone and was doing 75. Other than was smooth sailing.
            Gonna have to check out some of the local trails around here now.
              A friendly reminder that your bike is taller than awnings
              Found that out the hard way once haha
              Now you can shred trails with the rest of the WiBimmers crew!
                Oil change today. Here's what I used.
                Gave one of those friction reducers a try. Cheap enough that if it does something, great, or if it doesn't, who cares.
                Tail pipes had seen better days. Replaced them with some new polished ones. I think it freshens up the rear end.
                • pynaclP
                  pynaclP
                  pynacl
                  This thing is coming along super well! Love the tasteful updates and the paint correction looks well worth the effort. Also didn't realize the exhaust tips were just friction fit and not factory welded to the muffler. Off to go polish / replace mine!
