  4. Tossed a different set of wheels on the 240 today...
266 Posts 28 Posters 3.9k Views 3 Watching
    On the bright side, it will be an automatic indicator if a wheel gets bent.
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Getting more things done.
      Mocking up the intercooler--not yet mounted.
      Intercooler pipes fitted.
      Roundit 2000 for the harness and misc other wiring
      Odyssey PC680 mounted and other bits
        Good progress!  I like the sneaky battery mounting
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Thanks, I'm going to use a e36 distribution block/positive terminal in the engine bay. Should be a nice little detail.
            I hope you make it out to the E30 meet on May 10th.
            This car is awesome
            • The Full BananaT
              The Full BananaT
              The Full Banana
              If you guys don't mind me bringing a non-BMW, I'd like to swing by. We'll see though, that is two days before I take this car on a 35 hour drive to Portland, OR for a Volvo car show.
                That should be a great drive! Are you taking I80 or I90?
                Did you come up with that oil cooler bracket or is that original?
                • The Full BananaT
                  The Full BananaT
                  The Full Banana
                  We are just going to start figuring out the route now. At the moment, I have no idea... but I'm very open to suggestions! We will probably be stopping in Kansas City on the way out.
                  That oil cooler is a factory piece from a mid-year turbo car. It fits rather nicely with the factory intercooler in place, but the endtanks on this one block it more than I would like. I may try a bit of ducting to direct air to it... or I'll eventually put an oil cooler below the radiator. I have an oil temp gauge so I can keep an eye on it (Not that it should present any problem).
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    I'm tired and it's late so I'm not going to write much.
                    I've been working on this a lot, and had help this weekend. A couple friends came over and swapped in the rear end from the wagon while I worked on other stuff.
                    (oil lines aren't going to just hang there... have to wrap and mount them still)
                    this one is for Dave.
                    Goal was to start it today but that didn't happen because I was missing a few little bits and pieces that local stores didn't have. I'm going to get this thing legal to drive this week... it won't be long now.
                      Looking great!  Did it always have the remote oil filter?
                        The Full Banana said:
                        This entire build was a steaming heap of crap up until the point you installed the brackets powdercoated by bassboy. Bassboy saves the day!
                        Oh, and black-oxide socket head cap screws? NOT EARL APPROVED IN THE LEAST
                        Were the charge pipes part of a kit, or did you select them all yourself?
                          Everything is looking amazing man! Glad the brackets worked out and are looking sharp too! :) Thanks for the pic!
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            Nope, didn't have the remote oil filter, but it was something I swore to add when I had my wagon.
                            With a turbo and whatnot in there, it's way more of a pain to get the filter off the stock location than it should be. In this spot i should just be able to lay on the ground and reach up to get it off. Also the added bonus of there not being anything scalding hot nearby.
                            Stainless bling all over the place is not my thing. Also, this is a car for driving.   ;)
                            The black pipes are some Volvo factory pipes off of a few different early 90s turbo cars that I had laying around and cut for my needs. The silver pipes, couplers, and t-bolt clamps are all from a CX-racing 2.5" IC pipe kit.
                            Thanks! I have some more things in my trunk right now...
                              Feel free to drop them off whenever you would like. Shoot me a text or something.
                                That grill is so sick with the fog lights in there!
                                  I really like the black oxide screws in your case=) Looking excellent Tom
                                    Good call, the e36 cartridge filter setup is awesome but the m20 one up by the exhaust manifolds is silly, would be much better remote mounted.  One thing that may be even better is if you can mount it so the filter hangs vs. sideways, then it doesn't pour all over when removing the old one.
                                    • The Full BananaT
                                      The Full BananaT
                                      The Full Banana
                                      Yeah, I'm a big fan of the e36 filter setup. That'll be the next revision to my setup... when i swap in a m52 in a year or two.
                                      Once I get the fender on I'll see about tweaking the mounting a bit, but that's a good thought.
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        Yeah, i think so too. I'm a big fan of this front end, and it's pretty uncommon.
                                        Thanks, Earl!
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          Brakes are bled.
                                          It's running lean, so I was hunting down vacuum leaks, but ran out of time because this thing is way too loud to run after 9pm in the neighborhood.
                                          Oil filter lines were leaking thanks to the included orings. Replacing with aluminum crush washers.
                                          Hopefully tomorrow I can at least drive it down our street.
                                          what will the wheels look like? nobody knows! actually i'm not sure what wheels i'll actually end up running on this.
