  4. E46 Things
E46 Things
    I should have a lug wrench laying around
      Did some more driving. Onramps can be taken a little faster than is possible in my van
      • i_love_carsI
        i_love_carsI
        i_love_cars
        I love knowing the car is being driven
        EDIT: i think I have the tow hook for you still it's in my garage I'm pretty sure
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
          Quick car wash. Checked wheel lug torque. I got to try out the newly replaced horn fuse on someone drunk on Culvers Butterburgers
            The S54 sounds like a chainsaw cutting through a pile of beer cans.
            That’s all
              LEDs installed
                  INPA cable and CD ordered
                  PS reservoir siphoned and filled with fresh ATF. The steering actually feels a lot easier since regular (and dirty) PS fluid was in there. I will siphon and refill again soon just get more old fluid out to help preserve the pump and rack seals.
                  Tires inflated to 35psi. Winter storage and previous track time had them down around 27psi.
                  Reset throttle adaptations for the fun of it/to see if it would make any sort of difference. It may have flattened out the cold idle a bit
                  next on the list is to order a factory aux input cable and new cabin filter.
                  Adjusted door handle for easier opening (4mm wrench through hole shown here after removing the rubber plug)
                    Found a love note stuck under the seat
                      Couldn't even be bothered to add "M3" Smh
                        License plates arrived today.
                        picked up a vent mounted phone mount since there are no good places for a phone  here esp. on days like today where I needed to use navigation.
                          Did you find a vent mount that actually works? Every one I've bought has been garbage
                            https://www.iottie.com/Product/Detail/5044/Easy-One-Touch-4-Air-Vent-Mount
                            Did not fall off while driving this morning. I did have to spend some time finding a good location that worked well though
                              This, especially if you hook up the power cord.
                                You have to wire in the abs emergency outer brake light banks so they go on with the regular brake lights.
                                Can't wait to see you drive that thing!!
                                  • TkuhnT
                                    TkuhnT
                                    Tkuhn
                                    Happy to have stumbled upon this 😍 love how much different Ms look from non Ms
                                        that's a cool bit of programming, but lets not encourage auto manufacturers to venture down that rabbit hole.
                                        can you imagine 100 cars ahead of you in rush hour traffic with fricken strobe lights.
                                          Seizures
