  4. E46 Things
E46 Things
  • i_love_carsI
    i_love_carsI
    i_love_cars
    I lost 8k on this car after all the mods. Worth it to see a friend back in a BMW where he belongs.
    Me putting 500 miles a year on the car wasn't going to do it justice.
    That infotainment screen is indeed the worst travesty I have seen I think as far as that sort of thing is concerned. I'd rather have a non-nav unit in the car but at this point just get a modern double din for it and call it a day.
    2007 Z4MR
    2003 E39 M5
    2002 E46 M3
    2021 X5 40i
      Both wallets are slightly lighter, sounds like a common BMW thing to me.
        More pricey that a standard double DIN but it’s basically plug n play with all the modern features.
        https://avinusa.com/avant-4-for-bmw-3-series-e46-m3-multimedia-navigation-system.html
          There are 2 horn fuses, one is missing. Hopefully thats all I need to remedy to get the horn going again.
          I replaced the air filter. Much to my wife's dismay, she came out into the garage and saw the hood up and parts removed (airbox) . I gave her the least effective advice ever:  “calm down” I also added a bottle of Techron for good measure. (I swear the stuff works)
          The carpets were shampooed. The trunk mat could use another attempt later on but its much better
          The low quality license plate LEDs were replaced with some better/brighter LEDs and an interior LED kit was ordered thanks to a recommendation from @patsbimmer1
            My wife has stopped asking.  Between customer parts and my own parts shipping to my house she just accepts that things will be taken apart and things will be put back together.  Then again, I've never owned an E30 so she hasn't been conditioned like your wife has.
              Woohoo! The horn works!
              some previous owner must have needed a 15A fuse in a pinch and never replaced it. I may need to comb through the fuse list and make sure there isnt a 15A in a 5 or 10A spot though. Never hurts to check.
              I found the tow hook bumper plug in the glovebox and snapped that in place.
              I still need headlight washer nozzles, they have been deleted. I also need a factory lug wrench, jack, and tow hook to complete the trunk kit. Im guessing the E46 only ever came with a can of tire foam instead of a spare. I would like to buy a spare kit eventually.
                I should have a lug wrench laying around
                  Did some more driving. Onramps can be taken a little faster than is possible in my van
                  • i_love_carsI
                    i_love_carsI
                    i_love_cars
                    I love knowing the car is being driven
                    EDIT: i think I have the tow hook for you still it's in my garage I'm pretty sure
                    2007 Z4MR
                    2003 E39 M5
                    2002 E46 M3
                    2021 X5 40i
                      Quick car wash. Checked wheel lug torque. I got to try out the newly replaced horn fuse on someone drunk on Culvers Butterburgers
                        The S54 sounds like a chainsaw cutting through a pile of beer cans.
                        That’s all
                          LEDs installed
                              INPA cable and CD ordered
                              PS reservoir siphoned and filled with fresh ATF. The steering actually feels a lot easier since regular (and dirty) PS fluid was in there. I will siphon and refill again soon just get more old fluid out to help preserve the pump and rack seals.
                              Tires inflated to 35psi. Winter storage and previous track time had them down around 27psi.
                              Reset throttle adaptations for the fun of it/to see if it would make any sort of difference. It may have flattened out the cold idle a bit
                              next on the list is to order a factory aux input cable and new cabin filter.
                              Adjusted door handle for easier opening (4mm wrench through hole shown here after removing the rubber plug)
                                Found a love note stuck under the seat
                                  Couldn't even be bothered to add "M3" Smh
                                    License plates arrived today.
                                    picked up a vent mounted phone mount since there are no good places for a phone  here esp. on days like today where I needed to use navigation.
                                      Did you find a vent mount that actually works? Every one I've bought has been garbage
                                        https://www.iottie.com/Product/Detail/5044/Easy-One-Touch-4-Air-Vent-Mount
                                        Did not fall off while driving this morning. I did have to spend some time finding a good location that worked well though
                                          This, especially if you hook up the power cord.
