  4. Back from the dead or something.
131 Posts 15 Posters 0 Views 1 Watching
    Removable core supports seem like they make engine removal/swaps SO much easier. Sure sucks running into headroom issues then smacking the tail of the trans/shift lever on the floor while angling things in. For my M52 swap i had everything bolted to the subframe and raised it up from the bottom with a motorcycle jack.
    Great progress!
    are you going to rattle can the engine bay while its all out?
      Great progress!
      It's just going to be touch ups with primer. Probably wont go too crazy on the bay til winter. About that same time I plan on painting the entire interior a medium grey. Lots planned, just a matter of money and time, then execution.
        Just out of curiosity who makes the swap guide? What driveshaft are you going to run?
          J!m on the 318ti forum. And I'll be using the driveshaft out of the M3.
            Are you using a medium case diff? We ended up installing a stock 318ti driveshaft in @alexw‘s old car to fix his virbartion issues, he references J!m having some of the same issues. Everything is all in this post.
              I've heard of people just using the whole thing and not having too much of an issue, so I'm going to give it a shot. If nothing else I have the ti drive shaft on standby.
                How’s this going?
                  How’s this going?
                  Motor going into the compact today. Hopefully will move under it's own power today or tomorrow.
                    Best of luck sir! Great progress to you!
                        getting close!
                          getting close!
                          I can taste it. I need a rear subframe though.
                          I did order a DME with all the things deleted today, and I plan on buying an exhaust system instead of cobbling one together. It's just easier. Eventually I'll need a manual wiring harness so I can get rid of all the extra bits from the auto trans that was originally in the M3.
                          Who knew building cars was so expensive?
                          Anyway, gonna be hooking up all the things today, fill with fluids, see if it fires. If so, I'll probably have it driving by this weekend. If not I'll have to wait for my DME to arrive. If anyone wants to come hang out while I connect stuff, all the hard/dirty work is done. It gets lonely under the car.
                            Not fired, but so close. Fluids later today, hopefully it cranks up.20190709175324.thumb.jpg.869dad586dbeb7770d1949752168a00a.jpg
                              BFH spotted
                                BFH spotted
                                Nah that's just a lil tappy boi.
                                  Image result for top gear hammer gif
                                    Perfect
                                    • alexwA
                                      alexwA
                                      alexw
                                      I may have a spare 318ti driveshaft in my garage, unknown condition if you run into needing one. I'd just give it to ya.
                                      alexw
                                      332ti - Work in Progress
                                        Car runs, driveshaft is in, still have to bleed the clutch. Full update soon
                                          Waiting for full limiter burnout.
