  4. E30 M52
E30 M52
    So you saved $50ish but gained lead poisoning...
      Dont you worry, buttercup, I wear a full Hazmat suit when I go fishing or to the gun range and I can drive my car with it too. Folks will think im the Stig!
        It doesn't feel the same in your hand
        Phrasing?
            I received a few final pieces to finish rebuilding the oil pump. The new outer rotor has a .002" larger diameter than the old one which in itself will increase/restore pump performance substantially.
            The overpressure relief springs had an evident difference in length and stiffness . The new one being longer and stiffer and better for preventing any early bleed-off of pressure. The new o-ring was badly needed as well.
            The Achillies upgraded pump shaft comes with a bolt instead of a nut, a new sprocket (has flats instead of splines, a bmw sprocket will not work on this shaft) and safety wire.
            I also received the little cam tray dowel I needed. Lets see if I can finally get these stupid camshafts installed this weekend
              Intake cam torqued
              Just kidding, stripped another stud.
                I got a wave of motivation, went out and fixed the stripped threads, re-installed the cam.
                Guess what happened?
                Yep, stripped another one!
                  So are you sure you have the proper torque specs? I don't want to seem like I'm second guessing you but I find it very hard to believe that they would put a torque spec that dangerously close to the yield of that thread in aluminum.
                    11 foot pounds/132 inch pounds, certified calibrated torque wrench that goes from 40 to 200 inch pounds so I am right in the middle of the torque wrench capacity and everything to
                      (Reserved for future post about stripped threads)
                            (Reserved for backhanded comment about you doing torques wrong)
                              No
                                I want to believe you aren't doing something wrong, but I'm having a very hard time doing so.
                                I've rebuilt many of these motors, and the only time I had a stripped thread was the small torx screws that go into the timing cover.
                                Those cam caps are a glorified hand tight, so I don't quite see how you are having so many issues.
                                  I've been a ding-dong many times before but I promise that in this instance I am 100% right and the cylinder head threads are 100% wrong.
                                  Mitch mentioned my torque values may be in yard-pounds [emoji23]
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    Let me know when you are ready to work on this again. I will stop by and supervise to provide the final word on whether or not you are right or the cylinder head threads are.
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                      You know there are different tightening torques for M6, M7 and M8 bolts right?  Are you sure you don't have M6 bolts?  Those are only torqued to 7ft/lbs.
                                        How do you have the camshaft?  Could you take a picture of what you are doing?  I am confused (easily).  When I swapped an intake cam I had it turned so only the #1 cylinder lobes were down and tightened that cap first to compress the valve springs and my helper was holding the cam with a wrench to prevent it from turning while I installed the other caps and torqued it down.  I think I might have needed longer bolts because the studs weren't long enough to get the nuts started. and then once all of the others were installed I rotated it so there was no pressure on that spot and removed the bolts and put the studs back on.  It was a while ago and I was installing an m54b30 cam.
                                          Most definitely M7.
                                          This is exactly how I am doing it. Cyl #1 lobes are the only ones under any valve spring pressure. Bearing cap #2 is installed first with a1/4 turn on each nut until its flush with the cam tray, then all other bearing caps are installed flush, then torqued evenly (1/4 turn on each nut) until it reaches 11 ft-lbs or the threads strip, whichever comes first.
                                          At this point I am planning on having to repair every last one of them. If in some horrible nightmare I manage to start pulling-out the threads on the repaired holes, that's the point at which I will part it out, ban myself, lease a new Prius, and disappear from the car community forever.
