E30 M52
I received a few final pieces to finish rebuilding the oil pump. The new outer rotor has a .002" larger diameter than the old one which in itself will increase/restore pump performance substantially.
The overpressure relief springs had an evident difference in length and stiffness . The new one being longer and stiffer and better for preventing any early bleed-off of pressure. The new o-ring was badly needed as well.
The Achillies upgraded pump shaft comes with a bolt instead of a nut, a new sprocket (has flats instead of splines, a bmw sprocket will not work on this shaft) and safety wire.
I also received the little cam tray dowel I needed. Lets see if I can finally get these stupid camshafts installed this weekend
(Reserved for backhanded comment about you doing torques wrong)
I want to believe you aren't doing something wrong, but I'm having a very hard time doing so.
I've rebuilt many of these motors, and the only time I had a stripped thread was the small torx screws that go into the timing cover.Those cam caps are a glorified hand tight, so I don't quite see how you are having so many issues.
Let me know when you are ready to work on this again. I will stop by and supervise to provide the final word on whether or not you are right or the cylinder head threads are.
You know there are different tightening torques for M6, M7 and M8 bolts right? Are you sure you don't have M6 bolts? Those are only torqued to 7ft/lbs.
How do you have the camshaft? Could you take a picture of what you are doing? I am confused (easily). When I swapped an intake cam I had it turned so only the #1 cylinder lobes were down and tightened that cap first to compress the valve springs and my helper was holding the cam with a wrench to prevent it from turning while I installed the other caps and torqued it down. I think I might have needed longer bolts because the studs weren't long enough to get the nuts started. and then once all of the others were installed I rotated it so there was no pressure on that spot and removed the bolts and put the studs back on. It was a while ago and I was installing an m54b30 cam.
Most definitely M7.
This is exactly how I am doing it. Cyl #1 lobes are the only ones under any valve spring pressure. Bearing cap #2 is installed first with a1/4 turn on each nut until its flush with the cam tray, then all other bearing caps are installed flush, then torqued evenly (1/4 turn on each nut) until it reaches 11 ft-lbs or the threads strip, whichever comes first.
At this point I am planning on having to repair every last one of them. If in some horrible nightmare I manage to start pulling-out the threads on the repaired holes, that's the point at which I will part it out, ban myself, lease a new Prius, and disappear from the car community forever.
Strange. Is this on just one of the cams? Did you remove the studs from the head ever? I'm just speculating, could the studs not be fully seated and the stud is turning in the aluminum rather than the nut turning on the stud? Just grasping at straws. I guess I would just put inserts in all of them at this point.
Thanks. I just spit water all over laughing.
Could it maybe justtttt MAYBE be that your torque wrench is out of calibration? I know you said that it is certified and calibrated, but it can EASILY get out of calibration if you leave it out and your offspring decides to play light saber wars with it or you simply tightened it to 100ftlbs and leave it like that over night for example.
Stripped 6 or so with a small beam type torque wrench, went out and bought this Husky click style specifically so that the torque value I need lands right in the middle of the range and includes a calibration certificate.
The other 4 or 5 have been stripped with the new wrench
