  4. E30 M52
E30 M52
    The PCV hose that goes on that nipple is laying limp in the engine bay.  I have the manifold on and torqued but still need to make all the connections.
      Maybe it's the coolant vapors from the impending head gasket death that are causing premature wear, or your oil is toxic and your rings are shot so you are seeing too much oil through the manifold and it is wearing out the elbow, and don't forget the potential that your power steering pump is leaking and the pulley for it is flinging the fluid up and when you drive the air pushes the fluid back against the elbow.
        Lets not get crazy here WebMD
          I knew it was Lupus.
          FWIW the rubber grommet on my new BMW throttle cable was also cracked.
          Im guessing its just new old stock. Every other piece of rubber old and new is holding up fine. I ran a tightly wrapped strip of electrical tape over the ICV hose and added a hose clamp for good measure.
            I figured I would go on the "SnapPath"
              WebMD lists causes for a cough as being anything from a common cold to heart failure
              When my kids start hacking something up, I reach straight for the Lipitor.
              You gotta plan for the worst case scenario
                May have missed this but did the new alternator fix the temp issue?
                  Not yet determined.
                  I have the manifold on, just need to make the connections to it tonight and will probably give it a test drive tomorrow after work to see how things are going.
                    that just sounds ridiculous when you read it.
                      Agreed... though with all at play in the ongoing @snap saga I am withholding judgement. Who knows. The curse is strong in this one, and meanwhile I wait patiently with my temp gun.
                        I guess I better try to wear all black to the picnic so all the temp guns pointed at me get as accurate of a reading as possible.
                          I got everything back together, charged the battery and went for a half-hour long test drive. The engine ran perfect despite the O2 still not being connected and now I have a different problem. The temp gauge reads too low 😄66A9C5A6-22D4-4873-AB89-85A133C4125B.thumb.jpeg.b2483409de02714cc9184cce955cd7b4.jpeg
                          It sat steady at a tick under 180 or at 180 for the entire drive regardless of electrical load. FWIW I rewired so it no longer shares a power or ground with the other gauges.
                          if the mighty temp gun is to be trusted its about 15 degrees off. The top radiator hose reads 195 F.
                          I sat idling in the driveway for 5 minutes or so and the gauge only climbed to the 190 mark.
                          I will just play it safe and assume the gauge reads 20F too low and anything right of the 12:00 position will be the “shut er down” temperature. Consistently wrong is better than consistently moving around and I will see if I can make it more accurate another day.
                          See you at the picnic!
                            See, you are crazy.  Next time save the theatrics and listen to us!
                              Yes!!!!
                                Awesome! Now you just have to put some miles on before it sells...
                                  noice!
                                  just apply tape with corrected numbers.
                                    noice!
                                    some of us would be tempted to let it reach jessica alba just to see what happens
                                      fantastic-four-2005-movie-review-invisib
                                        I think you know what would happen, you would crack just like your cylinder head.
                                          Commuting in it again.
                                          Im pretty happy with the acceleration. Its faster than any NA E36 M I have been in but thats not saying a lot in this era of hoverboards and fidget spinners. its easy to drive/forgiving off the line when you are wearing dress shoes or are clumsy with the clutch.
                                          These cars look tiny. Doesnt help that im a ‘squatch 😁
