M52 or S52 in an E30
Oh jeez, there are more tools required ?!?
️Doing some reading
http://www.pelicanparts.com/BMW/techarticles/E36-Camshaft-Removal/E36-camshaft-removal.htm
And now I understand your 2-person method. Thanks for mentioning that. Now I am trying to understand how the procedure described in the pelican article would even work with the head installed since they are moving the cams in a different position than TDC... (reading continues)
Just don't have the bottom end at TDC and you can spin the cams all you want. There is only a small window where they would collide. You don't need tools for any of it. Just a straightedge to set the cams square with each other, easy peasy. When it's time to do it's can walk you through it.
Also if you take a Chanel lock apart and use the piece with the top jaw, you can use that to turn the exhaust cam sprocket like the vanos removal tool. Or how I did it my first time with no special tools just using a box wrench to loosen the intake cam sprocket nuts to turn it.
So time the cams with the cams at TDC and the timing chains removed and the engine 45 deg off TDC. Then rotate engine back to TDC and attach chains. This is my interpretation
Exactly.
