91 318 Nostalgia
Got to work on the other car.
The other subframe came down with much less drama, so that was quite nice!
The bushings that were in the 325 show some odd shaping and I'm trying to determine the cause.This is the bottom bushing (facing up though)
This is the top bushing (correct orientation)
The bottom bushing has become concave, and I'm trying to determine if that was the result of me not running a washer on the top of the top bushings.
I think that makes sense, but at the same time it almost makes less sense. The plate that the lower rests on has a raised middle portion so I would expect some deformation, but not quite that much.RTAB's ordered, 4.10LSD located, things are starting to move smoothly on this!
Boom! 4.10LSD obtained.
It's a medium case, which is meh for the car but I couldn't be picky as there were very few options available.I was working on unbolting the CV's, then I realized I can just swap the diff cups over and not have to unbolt anything. I was happy with my decisions.
She's a bit crusty and needs some love.
Noob question. What's the advantage of a small case compared to a medium case?
In this scenario the only disadvantage to a medium case is the weight, which is around 20lbs. In terms of strength, the medium case can handle much more torque.
So it's really not a big deal. -
I set fire to many bushings last night.
Got the old RTAB's out, as well as the old subframe bushings.I also cleaned up the diff a bit and put new fluid in it. The old diff was messed up and makes plenty of weird/bad noises when you spin just one output cup.
If I get bushings today I am hoping to have the car back on its own feet this weekend!
Took this out last night to feel how the new rear end felt, and all feels good! I fixed the PO's terrible exhaust work as well, so now the exhaust actually exits from the muffler!
Sadly I found that what I had thought was diff whine before is in fact a wheel bearing that is close to giving up on life.
I also have hot start issues, and am going to try replacing the FPR as most people claim that's what is common on these.
I want to start daily driving it, but I don't trust it yet.
Good thing e30/e36 wheel bearings are a cake walk=P
Yeahhhh, about that.
Though I have never used a proper tool set, and I believe Mr. Rice has one that I may be able to borrow. -
Arbor press ftw
Arbor press ftw
If you pull the trailing arms out, sure.
Wheel bearing party this weekend? I'll order one for the e34.
I'm booked this weekend unfortunately
I swapped the FPR on the car in attempt to help the hot start, as a lot of people online said that was their issue. It did not fix mine.
I have a CEL for the coolant temp sensor, but the sensor is clearly new, and there is a receipt for it in the car. I don't know if I double checked the number, but it is blue like it should be.
I have a feeling the CLT sensor is the problem, and I will check the sensor itself and then ensure that the wiring from the plug to the ecu is good. If I can fix the hot start issue I would feel much more confident in the car. -
Arbor press ftw
Two bolts ya chump!!!
In addition to the cv (moot point) The brake lines, abs sensor, parking brake cable, shock, spring, and sway bar end link.
Not to mention the difficulty of doing the bolts on the passenger side (fuel filler neck)In short, I did my last one in car.
Fab up a puller
