  4. Lifted E30 V2
Lifted E30 V2
    For the tie rods was it e90 inners?
    Yessir
    Sent from my XT1080 using Tapatalk
      Slowly morphing my two favorite vehicles together. XJs and e30s. Love it!
        Progress was creeping on this thing due to the fuel cell situation and running different fuel and brake lines. The fuel cell mounting is primarily complete and welded in, and I seam sealed it last night. Paint will follow and the tank will get mounted up.
        I got the rear brake lines roughly were I want them, and shall adjust later if needed.
        I'm a bit sad that it missed out on the first snowfall, but I made plenty of progress and it shall be ready for the next!
          I finally got this thing running on the new fuel setup.
          I had struggled 2 days ago to get it going, the pump would run intermittently and it would never fire. I verified fuel line orientation and that there was fuel flow, but no firing. I didn't have a ton of time to work on it so I had to leave it until the next day. Overnight I was trying to think of all of the things I did to it so I could go through and figure out why it wasn't running after swapping the fuel system as it had ran before.
          I realized that I had swapped the gauge cluster. I figured that's all it could be and I put the one that was original to the chassis back in the car and it started immediately. Nifty.
          Runs with a slight miss, as always!
          Brakes still suck. I believe it is air in the lines, and it must be in the front lines. The pedal goes pretty far before anything happens, and if I pump the pedal I get reasonable pedal feel for a second or two. Is that a bad booster? I haven't had to trouble shoot brakes before!
          New front suspension feels very good, and handles bumps much better than the last car!
          Having a full interior lifted e30 is odd, it's so quiet now.....
          Next step, New front bumper and skid plate!
            Did you swap the modules from the original cluster to the new one when you switched? Weird that would keep it from starting. Brakes wise Sams car did that and it ended up just being a lot of air that needed to be bled. I have a spare booster if you need one.
              It was a moto to VDO cluster, so I wasn't sure if it would work anyway. Not sure what module you are speaking of, coding plug?
              I shall have to bleed the fronts, and I did keep the booster from the last lifted car so I do have a spare if need be. Thanks for the offer though!
                Yup, the coding plug. I've heard you can't go between motor and vdo which sucks=/ We went through that issue when finding a cluster for Sams car
                  I was just looking to have the 5k tach back, I will probably just end up leaving the stock cluster in now.
                    Can't you just swap over the correct coding plug and be done with it?
                      Not between Motometer and VDO=(
                        That's poopie!
                          Supposed to get 3-5" on Sunday. Hope you'll be around to play.
                          ...and just to clarify, I'm talking about snow.
                            You treat her right, Ben.
                            pls
                              Glad you got it back up and running. I would try bleeding the brakes till you cant feel your calves. Then consider replacing the booster. 😄
                                So it seems like the passenger front caliper is either seized, or there is still a ton of air in the line. The pedal is feeling okay, but in snow the car pulls hard left under braking. I shall try to bleed that side again.
                                Took it out for the first time, and went to get gas. Filling up a car from the trunk is a very amusing thing to do.
                                Stopped in some snow and took a pic.
                                IMG20161212164823210HDR
                                I threw the old bumper on for the time being, just so it had something up front. I also wired up the lights because they are quite bright and convenient to have!
                                IMG20161212163355769HDR
                                received10211553961543838
                                Did a touch of "ditch" banging with sir Spence that night as well, which is always amusing.
                                We are scheduled to get a lot of snow this weekend, so last night I started building an actual exhaust for it in hopes of having it "street legal" for the weekend.
                                I also need to get started on the new skidplate, but my indecision of frame lifting is making me hesitant on that.
                                This has been my scattered thoughts.
                                IMG20161212165700699HDR
                                  When you doing the rear flares?
                                    thats awesome!
                                    "no f*cks given ditch banging" :lol:
                                      I'm not sure.
                                      The rear doesn't actually need flares, and I may loose travel by spacing out the wheel to match the flare. That or I need to stop stance boi'ing it.
                                      I need to go pull another set of front flares to do the rear of the car, as the rear flares didn't line up at all like I wanted them to. They aren't high on the list as it is quite a bit of work lol.
                                        Just anxious for the complete flared look=)
                                          Same. I keep bothering him about it but as he said, it's not high on his priority list. I think it looks incomplete and will look awesome with all 4 flares.
