  3. BMW Discussion
  4. e30 rims advice
e30 rims advice
30 Posts 9 Posters 498 Views 1 Watching
    cpandrewschmidt said:
    That looks good HipMF.  Size rim, tire, offset?  Any fender rolling or spacers?
    more pics here, but no specifics on the wheel size of offset 😃
    http://www.r3vlimited.com/board/showthread.php?t=295505
    I can't figure out all this offset stuff.
    I am assuming you have found the great wheel and tire fitment thread on r3v, thats your one stop shop on what combos fit.
    If you haven't, look here. (link?)
    I like this wheel better but can't confirm anywhere if the offset would work.
    ...the different offsets that I don't really understand what that all means and what the limits are of what can or can't fit.  Thats what i need help with.
    Google it. The offset is a measurement between the center of the wheel, width-wise, and the wheel mounting surface, in millimeters. Lower = more poke, higher = more sunk. Check out the fitment thread(s) on r3v and pick whatever floats your dingy.
    • C
      C
      cpandrewschmidt
      ok, thanks guys for putting up with me, starting to get it.  So higher number = more sunk.  So, wouldnt the 15x8" et25 with the 205/50 R15 tire fit under the fender better than the et 20 with the same size tire?  More sunk into the car should have less chance of rubbing, correct? (but now i have to worry about clearing the caliper or strut?)  I would think pushing the rim out towards the exterior of the fender with a lower offset would lead to rubbing?  Is 5mm really enough difference that'll look stupid too sunk in the fender?
      Just seems like there's never a set answer on certain combinations.  Ugh......might just have to buy and try.  Seems rolling the fender is easier than caliper mods if they dont fit.  leaning towards the 15x8" et25.
        caliper clearance? thats a whole different ballgame and has more to do with rim style than offset. you shouldn't be running into any caliper clearance issues with any of the sizes or offsets that have been discussed here.
        15x8 et25 won't fit, you will be hitting the front strut.
        15x8 et20 won't hit the front strut, and should be fine with the fender with a 205/50 tire.
        as i said before, going wider than 7.5 inches is pointless (unless you have a specific wheel in mind, which it seems you dont), it just causes problems and 205 tires fit fine on a 7 or 7.5" wheel.
          I don't have any "problems" running 16x8's on the girlfriends car.
          • C
            C
            cpandrewschmidt
            thanks everyone a ton!
            yeah I have the AVID AV-05 in mind, which only comes in 8" wide.
            I like the AVID AV-18 more but only comes in these specs: 15x8 et 25 or 15x8.5 et 15, so seems those wont work 😦
              Buy the 15x8 et25 and use 3mm spacers up front. Done.
              • C
                C
                cpandrewschmidt
                Got it.  The 3mm spacer actually subtracts the offset right?  So, it's et22 after the spacer.  Shouldnt I get a 5mm spacer then to bring it back to et20?  Lastly, the center bore is 73.1 where bmw is 57.1.  if i get a hubcentric spacer do I still need to get rings to fill the gap.
                I think I've reached my 20 questions limit 😄
                  A hubcentric spacer is just a spacer with a hubcentric ring provision on it.
                    Avoid the plastic rings if you can, an aluminum or stainless steel ring would be ideal
                    • mmradixM
                      mmradixM
                      mmradix
                      imagejpeg
