  4. Running Thread of the Daily: 325XI
107 Posts 14 Posters 2.0k Views 1 Watching
    suspenceful said:
    Which lift kit is that?
    Lolol
      The rack doctor steering rack we replaced in 2018 blew its seals and was leaking badly. Utilized their lifetime warranty and got a new one.
      Did an oil and filter change as well as a fuel pump; fuel filter and regulator.  Added e46 M3 RTABs also. All OEM BMW.
        Trans started slipping so got it replaced with a 94k mile trans out of a 325xi. Got the starter rebuilt, new trans filter/gasket. Tensioner & idler pullies replaced.  New oil filter housing gasket and hood latches.
        Mike also made the rust dissappear by the rear wheel arches.  Not bad for a napa rattle can!
        Now we just need some snow!
        All work done at 212k miles.
          You take good care of your stuff. E46 are getting old enough that some of them are approaching 1 failed emissions test from the scrap yard. she’s a keeper!
            You take good care of your stuff. E46 are getting old enough that some of them are approaching 1 failed emissions test from being "kept" outside of Milwaukee County. she’s a keeper!
            I fixed it for you.
              Got an engine light for a cylinder 6 misfire.  Popped in some new plugs and swapped the cylinder 5 & 6 coils.  Fault transfered to cylinder #5 so I swapped that coil with a good used one.  Back on the road!  Have a slight coolant leak I'll be hunting down but everything else is great!
                Maintenance!!!!!
                Slow leak in the coolant reservoir, front diff whining on decel, clunk in front suspension all addressed along with some other items!
                640660667(1).jpgGrabbed a used diff and Mike added new input and output seals.  New o-rings on the trans cooler. New serpentine belt. New locking/hazard button.  New swaybar links. "New" suede steering wheel with white label airbag. New Phillips 4300k xenon blubs.
